New Zealand, Auckland
Joined Nov 2007
If you are up for another device grab this
![]() http://www.hobbyking.com/hobbyking/s...idProduct=4575 Or with only wires http://www.hobbyking.com/hobbyking/s...dProduct=10487 Or locally? if you are in a hurry. http://www.fast-lad.co.uk/store/eagl...0-p-16951.html Suggested test without the eLogger, using what you already have. Fully charge batteries. Hover for 2 mins on each pack. 2? 2m+ Altitude. Charge them and note the mAh put back in. Swap the FC back to the Naza. Do the same. If the mAh is vastly different, > 5% then we can only conclude something is wrong with the way the X6 is driving the esc. Video all runs from a tripod if possible. The only thing I could think of that would make the X6 use more power is if it is not tuned properly and wobbling. Using more power than if it was in a stable/solid hover. Having to adjust thrust all the time may do it. |
Joined Sep 2012
[QUOTE=aok;23105462]
Welcome to ys-x6 they have a long way to go before it is explained right like lets say a naza system.... Did you set end points on motor and esc individually? Do you have led lights? Do you have wifi and phone/tablet can you see telemetry in gcs? Pull both stick at the same time left to the left bottom and right to the right bottom and motors should arm. I have not seen your prior post so do not know where you are at in setting it up. All these things must be checked and done first. |
Joined Dec 2011
[QUOTE=platinumhobbies;23106267]
The LED blik three times red. I have connection between android phone and the heli. ![]() PS. Nothing happen when I try to arm the motors.. but I can see I have connection to the radio in GCS. |
Joined Nov 2007
It should still arm up even if you have not done this. They may not spin up together and lead to poor performance. http://www.rcgroups.com/forums/showt...c#post22426755 A quick video showing your stick movement and values in the PC GCS would really help. |
Joined Sep 2012
Ok everything is working except load way points. I am getting telemetry through gcs. When upload way point the red dot does not change color or blink like it is suppose to do.
Now I did have a minor crash a few weeks back did a flip no major damage gracked landing skid, gps got a few scratches on it that's all. now I can not load way points at all. Any suggestions? |
Joined Dec 2011
Here you have video of the madness.....The parameteres go in all directions....
Okey its bad picture but I hope you see what you need
(I have an S800 with wookong an it so mutch easyer!!) |
Joined Nov 2007
YS-X6 User Manual V1.2 Pg29 |
| Thread Tools | |
| Discussion YS-X6 testing | GotHeliRC | Multirotor Talk | 1199 | Feb 22, 2013 07:48 PM |
| New Product Test video of YS-X6 Autopilot system | pzhang | Multirotor Talk | 141 | Jun 07, 2012 06:50 AM |
| Discussion New UAV System from Zero UAV | alishanmao | UAV - Unmanned Aerial Vehicles | 2 | Apr 19, 2012 09:02 AM |
| New Product YS-X6:A coming new king in the multi rotor heli world | yiny0730 | Multirotor Talk | 13 | Mar 28, 2012 11:28 PM |
