Old Oct 17, 2012, 01:24 PM
Mr_westie is offline
Find More Posts by Mr_westie
Down under under
New Zealand, Auckland
Joined Nov 2007
Originally Posted by ArturARM View Post
I have update the new firmware, I clibrated all settings ,but my copter cannt fly stabil. Every time it fly to right or back(Real servo position Elevator begin change from pull1 to pull 6), that problem in all mode(manual,manual altitude, GPS) When I start motors and truttle is under 20% in date menu real servo position Elevator is in MP ; when the truttle is more 21%(23% copter in ground ) , the Elevator begin to change the pull1 and more pull9, I think it will be from motors electrical noise and unplug the motors power and but it is same.can anybody know whats problem?
X650 V4 MT3506 Funfly 18A 13x4.7 prop. YS-X6, 3S
If you try to lift off slowly if may flip.
You have to lift off quick.
Slowly raising the throttle will do this
ys X6 problem (2 min 51 sec)
Note I have scrapped this frame due to vibration issues.
I can have a look at you hj file too.
Please post a picture of your system and a video.
This will help a lot with troubleshooting.
Mr_westie is offline Find More Posts by Mr_westie
Old Oct 18, 2012, 02:34 AM
Andre6553 is offline
Find More Posts by Andre6553
Vulcan skyhook multirotor
Andre6553's Avatar
South Africa, GP, Pretoria
Joined Feb 2011
Originally Posted by hdworld View Post
Anybody tested YS-X6 with Xaircraft 650V4 ?
more than 1 month cannot fly stable , always drifting, moving front, back, left , right ?
i think some quantity produced with some hardware problems, recently this problem can be meet very often .
is your magnetic declination set correct?
Andre6553 is offline Find More Posts by Andre6553
Old Oct 18, 2012, 02:46 AM
KariY is offline
Find More Posts by KariY
Finland, Uusimaa, HKI
Joined Jan 2012
http://www.youtube.com/watch?v=8sWJ26kfH5M
Agree, mine is flipping very easily in take off in man mode 1, and i always do fast climb to the air. When it's in the air it flies fine. Actually i take off always in gps or atti mode 2 as problem for me is only at mode 1, and my copter is balanced as perfectly it's possible. I think it is a kind of bug and should be listed to bug-list too.
KariY is offline Find More Posts by KariY
Old Oct 18, 2012, 02:53 AM
robone is offline
Find More Posts by robone
South Africa, GP, Johannesburg
Joined Sep 2010
And I always take off only in Manual mode 1
robone is offline Find More Posts by robone
Old Oct 18, 2012, 03:01 AM
KariY is offline
Joined Jan 2012
Yes i know and i'm confused how you do it.
Old Oct 18, 2012, 04:36 AM
robone is offline
Joined Sep 2010
I 1st give a bit of throttle to see which way it is going to tip, and then as I take off I adjust and get it into the air quickly. Difficult to explain, but I have used this method on all the FC's I have flown, as they all tend to tip one way or another, until you get it off the ground. I just think it is too slow in the other 2 modes, as the motors rev up.
Old Oct 18, 2012, 05:19 AM
Salocin is offline
Find More Posts by Salocin
Salocin's Avatar
Joined Aug 2012
When I start up, first time for the day, I'll take off in manual mode 1. It feels slow to respond to stick, so I throttle hard then flick over to gps auto hover mode before nearly stacking it. It's as if it's a bug. If i land, start over in mode 1, works perfectly. Perhaps I need to go into gps hover mode first before taking off in mode 1
Salocin is offline Find More Posts by Salocin
Old Oct 18, 2012, 05:30 AM
hdworld is offline
Find More Posts by hdworld
hdworld's Avatar
Joined Feb 2012
Magnetic declination had been set according to the manual's link.
value is 5.8
hdworld is offline Find More Posts by hdworld
Old Oct 18, 2012, 05:45 AM
Andre6553's Avatar
Joined Feb 2011
value is 5.8
where you live northern or southern hem
i live in southern and mine on my location is set -17
Old Oct 18, 2012, 05:51 AM
hdworld is offline
hdworld's Avatar
Joined Feb 2012
Live in northern ,
what is your frame ? 650V4 too ? and what motors and props using ?
Old Oct 18, 2012, 06:57 AM
david.scarbrow is offline
Find More Posts by david.scarbrow
Joined Oct 2011
My RC (Futaba 12FG) seems to be very touchy now in particular left or right. I only need to just about touch the stick and the aircraft will go in the correct direction...but at what speed. Consequently when the stick is released the aircraft will continue in the chosen direction for just a little longer before it settles down to a halt. The control does not seem to be as nice and smooth to operate as it was before a recent crash/rebuild. I guess I have done/set-up something incorrectly but I cannot see what it could be at this time...anyone got any ideas ?
Regards
David.
david.scarbrow is offline Find More Posts by david.scarbrow
Old Oct 18, 2012, 06:58 AM
Snoopyboy is offline
Find More Posts by Snoopyboy
Joined Sep 2012
I saw in some post they set the esc to start up as 'hard' and not 'soft', maybe that will help someways.
Snoopyboy is offline Find More Posts by Snoopyboy
Old Oct 18, 2012, 07:08 AM
richkphoto is offline
Find More Posts by richkphoto
United States, MN, St Cloud
Joined Jan 2012
Is there a new firmware upgrade?
richkphoto is offline Find More Posts by richkphoto
Old Oct 18, 2012, 07:23 AM
hdworld is offline
hdworld's Avatar
Joined Feb 2012
Yes, there is 20121005 ,
but in my case it doesnt help for stable fly. always moving .even we sent hj file to Zero support, they couldnt find any errors , fails, so if they cannot , it means we should try by ourself solve , They are beginner ,but i am sure here there are more professional guys .
Old Oct 18, 2012, 08:49 AM
robone is offline
Joined Sep 2010
Hi guys, the latest FW and GCS updates are normally posted here http://www.rcgroups.com/forums/showthread.php?t=1697842 and here http://www.zerouav.net/kefu.aspx. I do see that on their Chinese site they have a later version, and in English, but that site is geared for their Chinese market and the FW and GCS is different, so I would wait until they post a version on the two sites mentioned.
I have sent them an email asking what is happening.
Rob
Discussion YS-X6 testing GotHeliRC Multirotor Talk 1200 Aug 08, 2013 09:23 AM
New Product Test video of YS-X6 Autopilot system pzhang Multirotor Talk 141 Jun 07, 2012 06:50 AM
Discussion New UAV System from Zero UAV alishanmao UAV - Unmanned Aerial Vehicles 2 Apr 19, 2012 09:02 AM
New Product YS-X6:A coming new king in the multi rotor heli world yiny0730 Multirotor Talk 13 Mar 28, 2012 11:28 PM
