Old Oct 15, 2012, 07:33 AM
Snoopyboy is offline
Find More Posts by Snoopyboy
Joined Sep 2012
Im using Prolink WNR1012 and managed to connect sucessfully.
Sometimes u have to reset the ys-x6 after setting up the router. In your andriod phone, select wifi, make sure you can see ys x6 in your wifi list.
If you can get the same router, then i believe its easiler to track what went wrong.
Snoopyboy is offline Find More Posts by Snoopyboy
Old Oct 15, 2012, 02:38 PM
maximus-rc is offline
Find More Posts by maximus-rc
RTF copters maker
maximus-rc's Avatar
South France
*hi all,
While I can get HJ folder on Android systems, I cannot found it on Ipad or iphone ???
Nothing found on WinSCP tree...
I can get all informations on the GSC on Iphone/pad
Any idea ?
Cheers
MAximus
maximus-rc is offline Find More Posts by maximus-rc
Old Oct 15, 2012, 02:52 PM
KariY is offline
Find More Posts by KariY
Finland, Uusimaa, HKI
Joined Jan 2012
Originally Posted by maximus-rc View Post
*hi all,
Any idea ?
Cheers
MAximus
Should be found here:
/var/mobile/Documents/YSwifi/hj
Kari
KariY is offline Find More Posts by KariY
Old Oct 15, 2012, 03:04 PM
RTF copters maker
maximus-rc's Avatar
South France
Kari,
In /var/ folder, I don't have Documents/YSwifi/ folders, but only "Media", Applications and LIbrary folders.
The only "YSWifi" file is the exe. one placed in
/var/stash/Applications ...
Maximus
Old Oct 15, 2012, 03:10 PM
KariY is offline
Joined Jan 2012
Kari,
Maximus
Yes but in: /var/mobile/documents....
Don't you have /mobile/ in /var/?
Sorry just noticed you said YSWifi.exe? Are you talking about iPhone/ipad? It should be YSWifi.app.
Old Oct 15, 2012, 03:14 PM
RTF copters maker
maximus-rc's Avatar
South France
Here are the folders...
Old Oct 15, 2012, 03:15 PM
robone is offline
Find More Posts by robone
South Africa, GP, Johannesburg
Joined Sep 2010
Kari,
Maximus
Using Windows 7, If you do a search for hj it comes up with the location of the files. The location all depends on where your main file is kept.
Mine is kept here C:\Users\Rob\Downloads\YS-X6\YS-X6 PC-GCS-V1.0\YS-X6 PC-GCS-V1.0\Hj
Rob
robone is offline Find More Posts by robone
Old Oct 15, 2012, 03:48 PM
KariY is offline
Joined Jan 2012
Rob
But this is iPhone/iPad folder hierarchy right? Maximus have you had YSWifi.app running in your iPhone/ipad while flying?
Old Oct 15, 2012, 04:13 PM
RTF copters maker
maximus-rc's Avatar
South France
yes, it is IOS hierachy.
GCS runs perfectly on my Iphone (with hexacopter) or Ipad of client (with octo)...
But no hj folder anywhere !!!
On Android system, I found it immediatly !!!
Old Oct 15, 2012, 04:21 PM
robone is offline
Joined Sep 2010
My mistake. I saw someone mention a .exe file and I immediatly thought win 7.
Rob
Old Oct 16, 2012, 02:08 AM
ArturARM is offline
Find More Posts by ArturARM
Armenia, Yerevan
Joined Sep 2012
The Zero update new firmware
ArturARM is offline Find More Posts by ArturARM
Old Oct 17, 2012, 08:35 AM
ArturARM is offline
Armenia, Yerevan
Joined Sep 2012
I have update the new firmware, I clibrated all settings ,but my copter cannt fly stabil. Every time it fly to right or back(Real servo position Elevator begin change from pull1 to pull 6), that problem in all mode(manual,manual altitude, GPS) When I start motors and truttle is under 20% in date menu real servo position Elevator is in MP ; when the truttle is more 21%(23% copter in ground ) , the Elevator begin to change the pull1 and more pull9, I think it will be from motors electrical noise and unplug the motors power and but it is same.can anybody know whats problem?
X650 V4 MT3506 Funfly 18A 13x4.7 prop. YS-X6, 3S
Old Oct 17, 2012, 08:59 AM
KariY is offline
Joined Jan 2012
Which radio system do you use? And have you calibrated your radio with ground station software and see values are correct? If you try without props copter static on the ground, do you see elevator and aileron both servo values changing or only real servo values?
Old Oct 17, 2012, 10:04 AM
ArturARM is offline
Armenia, Yerevan
Joined Sep 2012
using Futaba 8TG radio with S-Bus , calibrated many times , replaced even ESCs , and motors ,
ONLY REAL SERVO values changing itselfs when throttle more than 20%. it doesnt matter copter flying or on the ground , values always changing itselfs.
about 1 month the problem exists ,even ZERO's support couldnt find out reason, i have sent HJ file to them again, hope they can find the reason. I doubt FC has factory quality problem .
After-sale support is very important but it is too long my problem exist, before i had DJI WKM and it was very easy setup and fly without any problem , but this one 2 times i already crashed my props beacuse of FC,
Old Oct 17, 2012, 12:35 PM
hdworld is offline
Find More Posts by hdworld
hdworld's Avatar
Joined Feb 2012
Anybody tested YS-X6 with Xaircraft 650V4 ?
more than 1 month cannot fly stable , always drifting, moving front, back, left , right ?
i think some quantity produced with some hardware problems, recently this problem can be meet very often .
hdworld is offline Find More Posts by hdworld
Discussion YS-X6 testing GotHeliRC Multirotor Talk 1200 Aug 08, 2013 09:23 AM
New Product Test video of YS-X6 Autopilot system pzhang Multirotor Talk 141 Jun 07, 2012 06:50 AM
Discussion New UAV System from Zero UAV alishanmao UAV - Unmanned Aerial Vehicles 2 Apr 19, 2012 09:02 AM
New Product YS-X6:A coming new king in the multi rotor heli world yiny0730 Multirotor Talk 13 Mar 28, 2012 11:28 PM
