Old Sep 28, 2012, 09:31 PM
Mr_westie is offline
Find More Posts by Mr_westie
Down under under
New Zealand, Auckland
Joined Nov 2007
Another weekend, another crash.
But this one is bad. Real bad.
Possibly terminal for the YS-X6.
35m drop onto asphalt.
BIts of the cover were spread out over 20m.
crash 3k 720p (2 min 46 sec)
Perfectly calm day.
Overcast.
Took off.
While manoeuvring craft into position, YS-X6 cuts motors.
I am stumped why it did this.
Not glitch
Not wind/shake
Not tilt.
Not manual motor shutdown
Not low battery
Wifi module would not power back.
Have not tested FC on it's own via the comport.
Damage: lots
But the frame came off fine this time.
Loving the low shake value of the new frame.
edit:
Check all YS components.
All DOA
Hopefully I can get it replaced under warranty as I can not see it being a user error this time.
Mr_westie is offline Find More Posts by Mr_westie
Old Sep 28, 2012, 11:50 PM
Snoopyboy is offline
Find More Posts by Snoopyboy
Joined Sep 2012
Magnetic declination: 0 14' EAST
Declination is POSITIVE
Based on the above, what is the number i should enter? -14?
Snoopyboy is offline Find More Posts by Snoopyboy
Old Sep 29, 2012, 12:08 AM
Salocin is offline
Find More Posts by Salocin
Salocin's Avatar
Joined Aug 2012
Originally Posted by david.scarbrow View Post
Anyone had any problems of quad motors spinning up unevenly ? I know it is not the motors as I have moved them around on the quad...eg... plugged port m1 into port m4, etc. And by unevenly I mean not as I would expect them to...ie...all at the same time. Motor 4 is almost at 30 - 35% before it starts to spin up. This happened once before some time ago but went away...I don't know why but I figured that I must have carried out something incorrectly. The YS-X6 driven quad has been sitting idle for the most part of 6 weeks while waiting for a new quad boom to arrive from the manufacturer (it got modified a bit following a drop of around 20 feet. The YS-X6 is well protected in this quad frame and I am fairly sure it did not suffer any external damage but maybe a jolt like that did some internal damage to the FC, etc. Any views, ideas, etc. would be most welcome.
I have this issue sometimes, but I just kick it in the guts and take off. It's fine.
Salocin is offline Find More Posts by Salocin
richkphoto is offline
Find More Posts by richkphoto
United States, MN, St Cloud
Joined Jan 2012
Westie sorry to hear about your bad luck again.
richkphoto is offline Find More Posts by richkphoto
Old Sep 29, 2012, 12:18 AM
Joined Jan 2012
GPS Glitch
I was flying with 2 4sx5000 batteries for the first time(still minus my WIFI antenna) and it was flying fine at about 10 minutes into the flight (I had been hovering at about 5 ft just to see how long the batteries would last when al of a sudden it just started darting off on it's own. I brought it back let go of the sticks and the same thing happened. I had a solid green light at the time. I tried to switch to either manual mode and the green light stayed on and it started behaving like it had a mind of its own. Finnally I had to bring it down hard breaking my landing gear and when I walked over to it I had a solid white light. Would the missing WIFI antenna cause this or does anyone else have any ideas what would. I tested my batteries when I got home and they tested at 3.75 per cell.
Old Sep 29, 2012, 12:35 AM
Salocin is offline
Salocin's Avatar
Joined Aug 2012
Perhaps it was trying to return to home on low voltage?
Old Sep 29, 2012, 02:04 AM
Joined Jan 2012
If it was it didn't try to climb to the return home height and it was flying 180 degrees from home(the complete wrong wasy
Old Sep 29, 2012, 02:28 AM
Down under under
Joined Nov 2007
There is no RTH on low voltage.
It just crashes.
Without a Hj/log file there is not much we can do.
From manual pg 47
"When the Speed data got from the Kalman filtering data fusion using the GPS
data is too large the LED will be solid white ,need to land the aircraft urgently ."
Could mean there was a gps issue.
Should not have affected manual 1/2.
http://www.rcgroups.com/forums/showp...&postcount=475
Originally Posted by redridinghood View Post
3 red flashes = no GPS sat
no red flashes = GPS good
No lights = Manual with good gps
Blue light = Hover mode
Green light = Position hold
If it was staying solid, it was not switching modes properly.
Are you sure you manual mode switch works?
Old Sep 29, 2012, 07:55 AM
Joined Jan 2012
Yes. I test it every time before I take off
Old Sep 29, 2012, 08:32 AM
Joined Jan 2012
I'm not sure how to post an HJ file?
Old Sep 29, 2012, 01:08 PM
eladberger is offline
Find More Posts by eladberger
Joined Aug 2012
Originally Posted by KariY View Post
I connect via mywi app and get hj files
which iPhone do you have and what iOS?
eladberger is offline Find More Posts by eladberger
Old Sep 29, 2012, 02:02 PM
KariY is offline
Find More Posts by KariY
Finland, Uusimaa, HKI
Joined Jan 2012
4S and 5.1.1 works like charm.
KariY is offline Find More Posts by KariY
Old Sep 29, 2012, 02:34 PM
Down under under
Joined Nov 2007
Best to email to interested parties as it contains your serial and flight location.
pm'ed.
For those that do not want to fly with a gcs but still want logging.
This would be a possible solution.
https://www.sparkfun.com/products/10216
Logomatic v2 Serial SD Datalogger
Old Sep 29, 2012, 03:08 PM
Andre6553 is offline
Find More Posts by Andre6553
Vulcan skyhook multirotor
Andre6553's Avatar
South Africa, GP, Pretoria
Joined Feb 2011
http://youtu.be/UdDH6DKAd4A
Perfectly calm day.
Overcast.
Took off.
Not glitch
Not wind/shake
Not tilt.
Not low battery
Damage: lots
edit:
All DOA
Maybe your craft has one crash to many maybe the gyros is hay wire.
I would sugest mount the GPS the way it is intent to be mounted on the pole post.
Do a fresh build motors right way up and start from scratch and take it step by step.
Or invest In a
Copter airbag system LOL
Andre6553 is offline Find More Posts by Andre6553
Old Sep 29, 2012, 03:14 PM
Joined Aug 2012
I've got the 4 with 5.1.1 maybe that's why
Discussion YS-X6 testing GotHeliRC Multirotor Talk 1200 Aug 08, 2013 09:23 AM
New Product Test video of YS-X6 Autopilot system pzhang Multirotor Talk 141 Jun 07, 2012 06:50 AM
Discussion New UAV System from Zero UAV alishanmao UAV - Unmanned Aerial Vehicles 2 Apr 19, 2012 09:02 AM
New Product YS-X6:A coming new king in the multi rotor heli world yiny0730 Multirotor Talk 13 Mar 28, 2012 11:28 PM
