Old May 09, 2012, 10:20 PM
Gregor99 is online now
Find More Posts by Gregor99
Revolectrix Ambassador
Seattle
Joined Sep 2007
Originally Posted by mrforsyth View Post
Agreed that the PL6 will have lower total charge times, but not by ~33% when charging 6S lipoly from a 24 volt source.
As discussed in more detail in the test, this was done to show the maximum power output of Powerlab6 on a 24v vs other chargers such as the 306b which have a 30 amp limit. This chart was intended to compare the wattage and charge times for the bulk charging phase, where maximum power is important.
I deliberately left off the balancing and constant voltage stage. This was done because every charger has slightly different balancing current as well as balancing behavior. Also different chargers have different current cutoffs for the CV stages as well as tolerances for current values. As the test was only intended to show the maximum wattage, including the balancing and CV stage would include unnecessary and misleading data.
A ~15-20% increase in charge power does not equate to a ~33% reduction in charge time.
The chart is using real data recorded from actual charges. Both tests were done with the same pack, from the same state of charge using the same power supply.
From that data, we see that a charger's maximum wattage cannot be defined by a single number, as many believe. For instance the PL6 example is 860 watts from start to finish. Whereas the 30 amp limited (ala 306b) starts around 700 watts, reaching its peak of 756 watts at the end of the charge. So if the 306b is only putting out its max wattage at the last minute of the charge, 760 watts it can not be fairly compared to Powerlab6 that is putting out 860 from the start of the charge.
While I did attempt explain this in the test, I know that boiling this down to a single number (CC stage in minutes) seemed a much simpler way to summarize the wattage differences.
Gregor99 is online now Find More Posts by Gregor99
Old May 09, 2012, 11:03 PM
mrforsyth is online now
Find More Posts by mrforsyth
So. Cal.
Gotcha and understand.
Note however, that CV stage will be longer with higher current so a portion of the minutes saved during CC stage will then be lost during CV stage. Other variables obviously come into play as well (charge lead length and gauge, battery internal resistance, etc.) that could further reduce the differences. I do completely agree that the PL6 will offer greater power and lower charge times off 24 volts than the 306B. A 15% reduction would be a reasonable expectation, in my estimation.
Have not followed the PL6 thread for a bit but wondering if Tim and company are pondering a firmware update that will raise the input current limit to, say 50A, in similar fashion when the PL8 power was increased via firmware update. I'm sure this would make a lot of folks happy...
Mark
mrforsyth is online now Find More Posts by mrforsyth
Old May 10, 2012, 11:24 AM
DenverJayhawk is offline
Find More Posts by DenverJayhawk
Epoxy & CA Investor
DenverJayhawk's Avatar
United States, CO, Denver
Joined May 2010
Mark - i'm using your power supply with the 306B. I parallel charge 6 4s 4000 lipos at 30A. So i'm only pulling about 444Watts?
DenverJayhawk is offline Find More Posts by DenverJayhawk
Old May 10, 2012, 11:39 AM
So. Cal.
When charging 4S lipoly at 30A, wattage from PS estimate as follows:
4 (# cells in series) x 4.2 (volts/cell) x 30 (charge current) = 504 watts (charge power at batteries)
Include about 15% losses within charger DC-DC converter, charger output lead, charger input lead, etc.: 504 / .85 = ~ 600 watts.
I typically like to have a good 20-30% headroom in my power supply. As you can see, you have a LOT of headroom and could even power a second charger quite easily.
Mark
Old May 10, 2012, 02:28 PM
Epoxy & CA Investor
Joined May 2010
so i could in theory, probably power another 306B at 30A depending on the batts i'm charging. This is assuming the PS puts out about 1200W, right?
Old May 10, 2012, 03:21 PM
So. Cal.
Absolutely. Your particular PS will do 1200 watts all day long.
Mark
Old May 11, 2012, 12:10 AM
Epoxy & CA Investor
Joined May 2010
thanks, Mark. BTW, the PS is working out beautifully.
Old May 17, 2012, 10:54 PM
Tree Rat RC is offline
Find More Posts by Tree Rat RC
Joined Apr 2012
Hey I just put a 3010B into operation today and have an issue.
When I plug a some 3S BATT's into a Progressive RC parallel board the charger is intermittently sensing a 4th cell and displaying a low voltage error when I try to balance charge. This ocurrs with multiple BATT's on the board or singles.
I checked all the set-ups and could find nothing out of order. Is my parallel board suspect?
Greg
Tree Rat RC is offline Find More Posts by Tree Rat RC
Old May 18, 2012, 12:30 AM
So. Cal.
It definitely sounds as though there is either an issue with your parallel board or the balance board that connects to your 3010B. The issue can be isolated by using a continuity tester to verify that all connections within each board are correct and that there are no shorts or intermittents. You can also remove the bottom or each board and perform a visual inspection as well to ensure that there are no loose conductive particles.
Presume that you have no issue when charging a single 3S pack directly to the charger's balance board and main output?
Mark
Old May 19, 2012, 06:30 AM
gulio is offline
Find More Posts by gulio
That's a funny word
NE Ohio
Joined Apr 2003
Neat topic , it would be nice to be able to select a higher cell count on LIPO for an unbalanced charge to take advantage of the 42 volt output capability. OR allow the 306 B to have 40 amp current , 35 maybe?
gulio is offline Find More Posts by gulio
Old Apr 20, 2013, 06:06 PM
Electromagnetic is offline
Find More Posts by Electromagnetic
Joined Feb 2013
Great thread you got here, I am trying to make a decision between these 2. Does the 306B have 2-6 balancing jacks already on the side? I see a picture on New Zealand's ICharger site. Is there a main ICharger site? I cant seem to find anything except the New Zealand site
http://www.icharger.co.nz/Products/306B.aspx
Electromagnetic is offline Find More Posts by Electromagnetic
Reply With Quote  (Disabled)
Old May 07, 2013, 07:23 PM
Joined Feb 2013
I bought the 306B and what a great little charger it is. I can now finally do some quick storage charging. I like the simple layout with the 4 metal buttons. No scroll wheels! Yippee! For now I just bought an inexpensive 10 amp power supply to get going. I will get a bigger one later, I may want more of these 306B's.
Old Feb 22, 2014, 01:56 PM
Evanspa is offline
Find More Posts by Evanspa
United States, CA, Camarillo
Joined Sep 2007
I just got the 306b. I have a Q. If I set the discharge rate to 10A it only does 3.5A. How do I get a discharge rate higher than 3.5A?
Evanspa is offline Find More Posts by Evanspa
Old Feb 22, 2014, 02:24 PM
So. Cal.
You'll have to use "regenerative discharge" or "expanding discharge" mode in order to discharge at higher current with your specific pack as the 306B is limited to 80 watts internal discharge power. Both of these methods are covered in the manual as well as in this forum.
Also, deleting your cross post would make the moderators happy.
Discussion iCharger 1010B+, 106B+, 208B, 206B, 306B and 3010B junsi Batteries and Chargers 16025 May 02, 2016 10:39 PM
For Sale Power supplies/Charging setups 306b TP820 3010b PL8 PL6 500/100w 700/1400w 12/24v paulpeffly Aircraft - Electric - Batteries & Chargers (FS/W) 2 Feb 22, 2012 08:24 AM
For Sale Power supplies/Charging setups 306b TP820 3010b PL8 PL6 500/100w 700/1400w 12/24v paulpeffly Aircraft - Electric - Batteries & Chargers (FS/W) 0 Feb 16, 2012 11:55 PM
Found Trade my 3010B 1000W iCharger for 2 smaller iCharger's invert Aircraft - Electric - Batteries & Chargers (FS/W) 5 Oct 28, 2011 12:49 AM
