Old May 08, 2012, 11:01 PM
7oneWo1f is offline
Find More Posts by 7oneWo1f
AMF Years
7oneWo1f's Avatar
Joined Nov 2011
iCharger 3010b and iCharger 306B
These are rated at 1000 watts, and the 306B is a 6S charger...but they both have a maximum charge current of 30 amps.
To get 1000 watts into 6S at 30 amps, each cell would have to be 5.56 volts.
What am I missing?
Granted, the 3010b can do 10S, and at 3.7 volts/cell, you hit 1000 watts at 27 amps.
But I don't think the 306B can't hit 1000 watts charging 6S lipos at 30 amps. At 30 amps and 3.7 volts/cell, you're only hitting 666 watts.
7oneWo1f is offline Find More Posts by 7oneWo1f
Old May 08, 2012, 11:19 PM
mrforsyth is online now
Find More Posts by mrforsyth
So. Cal.
You are a savvy man!
The 306B will only do 1000 watts when charging 10-12S LiFE in unbalanced mode.
When charging 6S lipoly in balanced mode, it'll approach ~780 watts output at the transition from CC to CV stage.
Mark
mrforsyth is online now Find More Posts by mrforsyth
Old May 08, 2012, 11:34 PM
crusey_aus is offline
Find More Posts by crusey_aus
Melbourne
Joined Aug 2010
306b
1000 watts is not a lipo specific limit
12 Life cells - 43.2v (23.1 amps for 1000 watts)
30 amps @ 25.2v (756 watts) is the 6s lipo limit
Cheers
crusey_aus is offline Find More Posts by crusey_aus
Old May 08, 2012, 11:43 PM
7oneWo1f is offline
AMF Years
7oneWo1f's Avatar
Joined Nov 2011
Thanks guys.
What is a better charger? By better, I mean least $/effective watt when charging multiple 6S lipo batteries using a paraboard or similar (and can stand up to repeated high amp usage)? The Powerlab 6 does 40 amps, enough to charge 6 3300mah batteries at 2C, but I am afraid there is something I'm missing.
Old May 08, 2012, 11:57 PM
Gregor99 is offline
Find More Posts by Gregor99
Revolectrix Ambassador
Seattle
Joined Sep 2007
The Powerlab6 will require 30v input to achieve 40 amps output on 6s. However on commonly available 24v server supplies, it still does quite well and comes close to 40 amps. See this test for more details.
http://www.rcgroups.com/forums/showt...h#post20578347
If you definitely need the full 40 amps on 6s with a 24v supply, the Powerlab8 is the just the ticket.
Gregor99 is offline Find More Posts by Gregor99
Old May 09, 2012, 12:03 AM
So. Cal.
When charging 6S, the PL6 will indeed offer higher power output if your power supply has sufficient voltage. IIRC, the PL6 will do somewhere around 850 watts on 24 volt input. Almost 30 volt input is required to hit 1000W output as it has a 40A input current limitation. The 306B is limited to 30A output so it'll take a bit longer to charge your 6S packs.
The 3010B offers nothing over the 306B when charging 6S lipolys. As such, it'd be wasted $, IMO, if one never planned to go above 6S lipoly.
It'd be a tough decision for me personally. I have 4 iChargers (1 x 306B, 3 x 106B) and absolutely love them. I almost always run them at full current output and they have all been flawless. That said, I would love to have a PL6 for the extra 10A.
Mark
Old May 09, 2012, 12:05 AM
Gregor99 is offline
Seattle
Joined Sep 2007
24v Supply - PL6 vs 306b
Old May 09, 2012, 12:06 AM
7oneWo1f is offline
AMF Years
7oneWo1f's Avatar
Joined Nov 2011
Thanks gregor99, excellent reference.
Old May 09, 2012, 12:20 AM
So. Cal.
A little misleading. A ~15-20% increase in charge power does not equate to a ~33% reduction in charge time. A fair test would be to do repeated tests with an actual 306B compared to a PL6 using the same batteries discharged to the same voltage.
Agreed that the PL6 will have lower total charge times, but not by ~33% when charging 6S lipoly from a 24 volt source.
Mark
Old May 09, 2012, 12:21 AM
So. Cal.
deleted.
Rayne is offline
Find More Posts by Rayne
"Landing" in a tree somewhere
Rochester, NY
Joined Sep 2009
Also realize that most paraboards are only rated for 30A. There is a 40A paraboard made for the Power Lab 6/8 but it only has JST-XT and T-Plugs and it costs $60.
Rayne is offline Find More Posts by Rayne
Old May 09, 2012, 12:28 AM
7oneWo1f is offline
AMF Years
7oneWo1f's Avatar
Joined Nov 2011
I think they dropped the price on the 40A, and expanded the offerings. (I just received some.)
Old May 09, 2012, 12:30 AM
Rayne is offline
Rochester, NY
Joined Sep 2009
Really, from where?
Old May 09, 2012, 12:52 AM
7oneWo1f is offline
AMF Years
7oneWo1f's Avatar
Joined Nov 2011
epbuddy.com
Old May 09, 2012, 01:39 AM
Rayne is offline
Rochester, NY
Joined Sep 2009
epbuddy.com
Huh, guess I didn't see that.
Well epbuddy has the power lab 6 with a paraboard and the usb interface for $198 + shipping. The 306b (which includes usb) comes with a free paraboard for $160 + shipping. The 306b has ~50A input current limit compared to the PL6's 40A, meaning you won't need as much voltage from a dc power supply. If you've got a 30V+ power supply I'd go with the PL6. But if you're going to use a 24V or less dc supply I'd get the 306b. With a 24V supply you'd only get approx. 32.38A of charging current on the PL6, not much faster really. If you've got smaller than 6s batteries then you might like the extra 10A of charging current you'd be able to get that the PL6 has.
Discussion iCharger 1010B+, 106B+, 208B, 206B, 306B and 3010B junsi Batteries and Chargers 16194 Sep 21, 2016 08:07 AM
For Sale Power supplies/Charging setups 306b TP820 3010b PL8 PL6 500/100w 700/1400w 12/24v paulpeffly Aircraft - Electric - Batteries & Chargers (FS/W) 2 Feb 22, 2012 08:24 AM
For Sale Power supplies/Charging setups 306b TP820 3010b PL8 PL6 500/100w 700/1400w 12/24v paulpeffly Aircraft - Electric - Batteries & Chargers (FS/W) 0 Feb 16, 2012 11:55 PM
Found Trade my 3010B 1000W iCharger for 2 smaller iCharger's invert Aircraft - Electric - Batteries & Chargers (FS/W) 5 Oct 28, 2011 12:49 AM
