United States, MN, New Hope
Joined Aug 2010
Exactly the same thing happened to mine if you look at the other post on the CC. Mine did it the first time in my LHS. Replaced the servo and checked everything out while it was split in half and on the second flight the elevator servo jammed and it nosed into the ground. No longer fixable!
So I guess the lesson here is we should never pre-order or buy the first run of the HH micros?!!
Seems like every time a new one is released, there's a host of problems that people go through. ![]() Although these servo probs - they're the same servos HH has used for years, you'd think they'd get the right by now!!! |
Wonder how HH is taking this? Looks to me they'll be replacing alot of CC. Mine was the right aileron servo it not only seized up and made alot of weird noises but the motor got HOT and thne the servo motor mount was split and not glued on properly. Sending it back to my LHS and have them give me a new one and will check it BEFOREleaving the store to make sure all is working right. Look forward to hearing what HH explains this mess. Hope this doesn't reflect on the coming planes like the glider,spitfire and mig cause if it happens thne they'll have some serious sales issues .
These are actually new servos that have only been around since December, and these servos are being asked to move around much more than the old ones.
Latest blog entry: AR6400 guillows Space Shuttle
They are different from the Corsair servos, but all of the things that could go wrong with the corsair servos can go wrong with these + much more (larger motor, different rack design, constant movement)
My flap servo was temperamental out of the box, but seemed to sort itself when I followed advice on the main thread and reduced the servo travel. The problem came back though and now the servo has gone altogether, cub only has one flight on it.
Gotta say the Horizon ultra micro foamies i've had, a T-28, UM Stryker and now the Carbon Cub have been a bit of a mixed bag for me. First lets just say they've all been brilliant when it comes to the flying, the Stryker in particular has been a laugh and i'm really impressed with the AS3X in the Cub. The downside to all three models i've owned has to be the build quality and overall finish. I don't think the lightweight materials used in these models is ideally suited to mass production as a great deal of care is required on assembly to end up with an ideal finish. All of my models came out of the box with various issues. Fingernail marks, dents and creases in the foam parts, misplaced, misaligned or bubbled decals, glue all over the place etc. Sure these things wont matter a few crashes down the line, but it just takes a little polish away from a brand new out of the box model. This isn't just a Horizon issue mind, you also read alot on these forums of quality issues with these mass produced RTFs. Maybe i'm just being picky, maybe a decade of building static scale models made it so, dunno, but sometimes I just with Horizon would sell these models as nice complete kits for the people who like to build stuff. |
my elevator locked in neutral position during control-check before maidon, along with some binding issues. my lhs got 2 CCs in, 1 was my pre-order, the other was my replacement.. thank the lord the 2nd CC was still sitting on the shelf today!
! control-checks on the 2nd CC seem to be spot on. look to maiden tomor weather permitting.
Joined Aug 2010
Joined Aug 2010
No, the return was via the website form and they e-mail a pre-paid UPS label. Put receipt, printed form in the box and go to UPS. Mine was at UPS 15 minutes after I hung up the phone. They told me they are currently at about 8 days backlog but since it is a UMX they might get to it quicker. We shall see
Got my CC yesterday and have problems with the flap servo.
First it runs the flaps a few times (with interruptions), than suddenly the motor gear plopps off and made his way into the fuselage. ![]() After opening the fuselage and inspecting everything I saw a little of the black glue (they used to glue the wing on the cabin/fuselage) on the big gear and the small gear ( motor) was splitted. ![]() I seperated the servo from the wing and the work began. The small gear was damaged so bad that no repair was possible. When running the servo motor without the gear it got hot after only a few seconds turning down the rpm on itself - fail. I think the resistance on the first runs (because of the glue) was too much for this tiny motor, so I decided to use a servo motor from my mCPX and soldered it on to the servo board - now everything is fine. After opening the fuselage I saw the linkage for the elevator which made a bow inside the fuselage between the servo and the linkage support at the rearend. ![]() Now I think I know why several CC had a failing elevator servo. ![]() Tolerances during the assembly can cause the linkage to make a bow instead of a straight line causing too much resistance and shorten the life time of these tiny servomotors. The ruder linkage scrubs again the elevator depending on the whole you are using for the ruder arm, causing resistance, too. Everyone should check this on his CC to prevent damage ! Rolf |
Bavaria, Germany
Joined Nov 2008
Hi all...
I maidened mine yesterday. I flew great for about 4 min, then I lost control and it went into a tree. Got her out ok, some scratches though...only to find out that the elevator was not responding any more. The elevator got stuck in a dive position. The travel adjust was set to 90% before the maiden flight since I read about servos getting stuck. Back at home at close inspection I now hear the servo motor of the elevator servo spin freely. Looks like the gear got shot... Since it's a brand new plane I am not going to open her, will just send her back for repairs... cheers Uwe |
Inspect every linkage to be friction free,
this is in my opinion the reason number 1 for the servos to stuck. When I changed my aileron linkages to the most inner hole, the linkages both scrubed against the upper end of the servo and what do you think ? Right, they got stucked here and there at different positions. I adjusted the linkages so that they got free motion and everything went perfect. Have a look at the aileron plastic cover, if they aren't glued in the right position with a nice bow in the middle, the servo can scrub against these from the inner side, which is difficult to see ... EDIT 13.5.2012 Got a stucked elevator servo during my 4th batterie - hit a tree at the top... ![]() After 20 minutes we managed to get her free, some bump and dents at the fuselage and on the wing. Elevator got stucked several times then went on with no problems - I'm not amused... Will bring her back to my lhs. Rolf |
Hi
I got my carbon cub on release day, had to wait a few days due to weather. I maidened it with no problems until evevator failed on 5th flight. It went down into a collection of small trees! Took me a while to find it, i used the noise from the aileron servo's as a kind of plane locator lol. Only 2 small nicks in the wing but i left the crash site not realizing one of the wing struts was missing doh! I made a real nice set out of 2mm carbon fibre rod i was going to use for my mcpx tail extention. I think my servo rod was binding on the body just after it comes out of the plastic eyelet so i cut away a little of the polystyrene, also lubed the rod and servo cogs with light oil. I have since flown it 7 or 8 times with no problems. I love this plane in calm conditions but nothing can beat the beast 3d for wind handling! i use miniaviation 210mah batteries along with the stock battery set my timer for 8 mins with mixed cruising and sport flying. cheers for now... |
Here's what I experienced. Right out of the box two of the plastic fittings on the wings were completely loose and laying in the bottom of the box. A third had barely a spot of glue holding it on and was about to come off. One of the wing struts had come loose from the fuselage and during shipment to the US had dug some holes in the side of the fuselage. It came loose because of the wing plastic fittings which were not glued in place appropriately.
On the third flight an aileron servo stuck and the plane flew into a tree. Doesn't seem to me that HH quality is up to par on this plane. I'll be calling them Monday. Gordon |
Bavaria, Germany
Joined Nov 2008
...mine is on it's way back to the dealer, from there up north to Horizon. It's really a shame, such a good looking plane and such a brilliant concept...and now such quality issues. I hope to get a replacement soon.
I will also send a letter to Horizon Germany requesting the warranty to be kept valid even if either they or myself open up the new plane, inspect every single piece of electronics, adjust and re-glue if needed and then re-assemble. I hope they will agree...after all it's not HH Germany's fault if the Chinese produce crap. I would again like to congratulate Horizon R&D for the design and the innovations that went into this little marvel...if they now fix their production line issues they will once again have a million seller I am sure... In the hope of becoming a CC pilot soon again... cheers Uwe |
For those who bought their CC from HH shouldn't have to pay for RETURN broken planes HH should be nice to have them shipped back at their expense. You already paid $169 for it now how much is it costing you? Then they will determine if it's a fault of theirs or yours hopefully they will give you a new one and simply not repair the broken part. That's why I buy from the LHS and they can get it replaced form me at no extra cost. Lesson learn here right! I would not pre order from HH as you pay the same price at the LHS(not unless you live in the middle of no where and that online is the only way) Anyway why give HH the whole price and profit whne they get them cheap and not let a LHS stay in business
United States, NJ, Brooklawn
Joined Jul 2008
So is there general agreement that this isn't an electronic issue; but more a physical one wherein the gearing on the servos (mostly elevators it seems) is either gummed up at the factory from sloppy QC, -or- the servo is put under un-due load due to jamming on the control cable?
The latter seems most feasible, as the issue manifests itself after a few flights for most people, enough time for the accelerated wear to catch up with the already heavily loaded servo. I ask because I'd rather that than bad electronics (which we can't fix/pre-emptively correct for). I Haven't maidened mine yet, but now I'm scared to
Over 20 hours of flight-time on my CC & the servos are fine.
Joel |
Latest blog entry: Eflite UMX Sbach 3D on 3s - 2300Kv/5043...
Joined Sep 2010
Joined Sep 2010
Joel - don't remember you saying, did you clean yours first or just use right out of the box. No big deal, just curious - I know that I only worked on the one that was hanging and did not bother the rest of them. I guess I'm sort of a don't fix it if it ain't broke guy.
I didn't clean them. I set ATV on the servo channels to +/- 98% & cycled the servos a bunch of times on the ground before the maiden. They worked as I expected them to. Like you, I saw no reason to fix what wasn't broken. BTW - the mCP X is the only UM on which I've cleaned the servos (so far). The servos tend to get jittery every so often, and the bird no longer holds altitude. A shot of DeoxIT in each servo solves the problem for another few hundred flights or so. Hence, why servo cleaning is a part of my standard PM routine on that aircraft. None of my other UMs have shown any signs that the servos need cleaning. I've owned 23 UM aircraft, with a total of 64 UM servos. Of those, 15 are AS3X servos, 12 of which are fixed-wing. I have been flying these UMs since the original UM Sukhoi was first released. In many thousands of flights, I have had two servo failures. Elevator on one V1 Beast locked-up after about 50 flights, and an aileron servo went nuts during the maiden on another V1 Beast. That's it. My mSR has over 1000 flights in the original servos. I have a couple V1 Beasts with well over 500 flights on the original servos. The original servos in my mCP X are still going strong after nearly 1000 flights. One of my B3Ds is over the 500 flight mark. The servos are fine - and I fly that one on 3s, so AS3X is definitely giving them a workout. I still don't see anything new, here. The CC uses the same tail servos as the B3D & Gee Bee. Read the first 20 pages or so of those threads right after the release & you'll see a quite a few reports of servo problems. Same thing in the V1 beast & Sbach threads. The CC appeals to a far broader audience than the Beast, Gee Bee, or Sbach. Hence, the increased number of servo-failure reports. I'm thinking that the percentages are about the same with all of the above planes. Joel |
| Thread Tools | |
| Poll Eflite Carbon Z Yak54 stock servo failure poll | Raydee | 3D Foamies | 4 | Jun 18, 2012 07:12 AM |
| New Product UMX Carbon Cub SS | masonjee | Electric Plane Talk | 2 | Apr 30, 2012 01:32 AM |
| Help! Binding Issues Super Cub DSM | PatrickRC | Beginner Training Area (Aircraft-Electric) | 14 | Apr 20, 2012 05:23 PM |
| Poll POLL: What servo connectors do you use the most? | nemoskull | Indoor and Micro Models | 0 | Feb 15, 2012 10:03 AM |
