Old May 08, 2012, 04:25 PM
Frogman
Stoughton, WI
Joined Jun 2009
What's this function called
I am a tricopter flyer and this last weekend I got to fly a friends higher end quad setup. I was scared out of my mind as it I worried about keeping track of the front. It had a white tailboom for orientation but what do you do when you can't see the white or it is flying in front of the sun and it's a shadow?
I remember reading somewhere here on these forums about a function for multirotors where not matter how the copter is turned it senses where the signal is coming from and pushing the elevator stick forward goes forward and backward brings it back and the same with the roll and yaw controls no matter where the actual "front" of the copter is.
Anyone know what this is called. I wanted to research it a little but I have no idea what to search for.
I know for higher end AP/AV work most flying has to be done with some FPV gear but I haven't conquered that yet and still like to see my machine in the air. When I get far away it's so easy to get mixed up even with a tricopter. I have no idea how you hex and octo flyers keep track of it when they are round.
frogman1206 is offline Find More Posts by frogman1206
Old May 08, 2012, 04:29 PM
United Kingdom
Joined Nov 2008
CareFree
may be other names ...
Mike Barton is offline Find More Posts by Mike Barton
Old May 08, 2012, 04:52 PM
Z06 Tony's Avatar
Rochester NY
Joined Sep 2008
Checkout my HexaKong kit that comes with a Wookong-M-> http://www.rc-drones.com/hexakong-650-wookong.php
Right now we are offering a free DJI F450 ARF kit with every Wookong-M purchase OR $140 off.
Z06 Tony is offline Find More Posts by Z06 Tony
Site Sponsor
Old May 08, 2012, 05:00 PM
A new day, a new gadget
Brighton, UK
Joined May 2006
Yes, orientation is a big issue - amazing how quickly it turns into a bunch of random sticks!Many say that LED's help, or that as long as it's stable you can reorient by seeing how it responds to a particular control input but that needs a cool head and if a breeze is blowing it rapidly away from you...
Or the GPS systems have a Return To Home feature; I have a Wookong M as Tony suggests but it's a bit spendy.
Garry s is offline Find More Posts by Garry s
Old May 08, 2012, 05:58 PM
Linux Compatible
machina's Avatar
United States, DC, Washington
Joined Dec 2007
It's called carefree. It uses a onboard compass and knows its direction and maintains that direction as 'front' either with a switch being flipped, or from startup.
I found it easier to either tie something between the front two booms, or to use a spider frame in order to differentiate what is front a far distances.
I've found practice helps as well. If you know better what the quad should do it becomes an easier job determining what should be front based on previous inputs. You give your inputs based on what you know it will do, rather than constantly correcting based on it's current position and orientation. It kind of hard to explain, but keeping orientation is much easier with practice either by flying or by sim.
machina is offline Find More Posts by machina
Discussion Easystar Camerapod - what´s this part called? jesse78 Video Piloting (FPV/RPV) 0 Apr 20, 2012 12:41 PM
Discussion Mr. Obama Called Bush's Debt Unpatriotic! So What Is His Debt? LcJ Life, The Universe, and Politics 35 Jan 14, 2012 10:42 AM
Suggestion What is this called? ctrout Site Suggestions / Complaints 4 Dec 19, 2011 02:36 PM
Question Can someone tell me what this is called? 3d astronaut DIY Electronics 0 Oct 13, 2011 12:21 AM
Question What effect on the characteristics of an airfoil does the position of the maximum thi RobZ Modeling Science 4 Sep 25, 2008 05:48 PM
