Old May 08, 2012, 04:14 PM
RPatrick is offline
Find More Posts by RPatrick
RPatrick's Avatar
Hurst, Texas USA
Joined Jan 2002
Can sunlight blister foam airplanes ?
In another thread I read about someone's black foam airplane developing "alligator skin" from being in the sun.
I have known that hot air can cause foam to blister up but never really thought about direct sunlight doing the same thing. I'm wondering if black painted foam is the only type to really worry about, or can this happen to any foam airplane ?
RPatrick is offline Find More Posts by RPatrick
Old May 08, 2012, 04:37 PM
hoppy is offline
Find More Posts by hoppy
Space Coast USA
hoppy's Avatar
Space Coast
Joined Oct 2000
Black is the best heat absorber. If the plane was on the dashboard in the direct sunlight in a closed car in the south on a summer day, the temp could be near 180-190F which would cause the alligator skin. I've measured that temp doing a test on the possibilitiy of a lipo igniting in a car if left on the dash.
White or other light colors should not be affected as they won't get as hot especially if not in the direct sunlight.
This applies to EPP and EPO foams. EPS is not affected that way.
hoppy is offline Find More Posts by hoppy
Old May 08, 2012, 06:29 PM
RPatrick is offline
RPatrick's Avatar
Hurst, Texas USA
Joined Jan 2002
Thanks for the comment.
In this particular case, I believe the plane was just out in the open in direct sunlight. If there is not much breeze I suppose the black surface could get hot enough to cause problems. I'll probably start carrying a towel with me when I fly my favorite foamy with black areas just in case.
Old May 08, 2012, 07:29 PM
dkrhardy is offline
Find More Posts by dkrhardy
United States, FL, The Villages
Joined Oct 2010
Good idea! "Gator" skin does apperar when foam planes are sitting in the sun!
Don
dkrhardy is offline Find More Posts by dkrhardy
Sold Nutball Foam Airplane - BNF bstussie Aircraft - Electric - Airplanes (FS/W) 1 Apr 13, 2012 02:12 AM
Discussion Can I use picoboard and heli motor and servos on a foam airplane? Rooster619 Beginner Training Area (Aircraft-Electric) 8 Apr 10, 2012 08:05 AM
Discussion Philips 7" slave LCD - Looks black and white/washed out in sunlight? slowjett FPV Talk 0 Mar 31, 2012 12:28 AM
Discussion Desperately require a small monitor,sunlight friendly? clive thurgood FPV Talk 1 Feb 06, 2012 03:39 AM
Alert Leaving goggle unuse under direct sunlight can dammage them VRflyer FPV Talk 10 Mar 05, 2008 06:54 PM
