Old May 08, 2012, 04:01 PM
jasper7821 is offline
Find More Posts by jasper7821
United States, AZ, Tucson
Joined Mar 2008
Help!
I have a Wookong issue with my DX8 and AR8000, not enough channels for everything
I just got my WKM and my second F550 yesterday and wanting to see if there's any solution to my problem with not enough 3 position switches.
On my DX8 I have 3 AUX channels, two 3 position switches and a dial.
I have AUX3 dial connected to the X3 on my MC to control my gains.
X1 is for the PMU
and X2 on the MC is on X2 on the TX for OFF/ Course Lock/ Home Lock
I have AUX1 (3 position switch) on the TX connected to control the shutter and video for my Sony Nex5n.
I have U channel (Manual/ATTI/GPS ATTI) on my gear switch and was only trying to use ATTI and GPS ATTI since I have no interest to fly in Manual.
The manual states that if you use it on a 2 position switch, I should be able to use ATTI and GPS ATTI.
The problem I'm having is I can't get one of the end points to go from manual to ATTI, the slider will only to to the Fail Safe and not make it to ATTI.
Is there any solutions, or do I need to put the camera cable on a 2 position switch and only have video or photo control.
The only other 3 position switch I have is the Flight Mode switch. Is there a way to possibly use that instead of the gear switch. Since there's a Gear input and not a F Mode input on the AR8000 I don't know if there's anything I can do.
jasper7821 is offline Find More Posts by jasper7821
Old May 08, 2012, 04:16 PM
cdi3d is offline
Find More Posts by cdi3d
Brushless
cdi3d's Avatar
Joined Mar 2009
Ken - I am running the DX8 with my Wookong and NEX5N with no problems - I am not finding I need to adjust my gains - set it and forget it - So I have camera tilt on Aux 3 GPS/ATTI?MAN on Aux2 and camera video on Aux 1 - Gear is set to failsafe
cdi3d is offline Find More Posts by cdi3d
Old May 08, 2012, 04:35 PM
Joined Mar 2008
Ok,
Thanks Mike,
So you have AUX2 on the U channel.
So maybe you're not using the IOI feature and that's how you can operate everything ?
Old May 08, 2012, 10:00 PM
cdi3d is offline
Brushless
cdi3d's Avatar
Joined Mar 2009
Yes I am using AUX 2 on the U channel - since it is 3 position switch - what is the IOI feature? I dont like messing with gains - I find that if properly tuned in the beginning it will not need adjustments - Some others may argue but I like the KISS method
Old May 08, 2012, 10:19 PM
Joined Mar 2008
Mike,
Are you sure you're not talking about the NAZA ?
I solved one of my problems but can't fix another.
See below the post I made in the Wookong thread
Oh Ya, the IOI is is in step 4 of the Autopilot tab. It's Intelligent Orientation Control. Options are OFF/ Course Lock/ Home Lock. I figured that since you said you can use your Sony on an AUX channel then you must have the IOI inhibited.
Ok, one more WKM question.
I have the U channel on the gear switch since the other two 3 position switches on my DX8 are used my the IOI for OFF/Course Lock/Home Lock and the other three position switch for my GentLed for my camera.
I don't care about Manual Mode so the U channel being on my 2 position switch is fine.
With the endpoints I wasn't able to get position to ATTI.
I adjusted the sub trims then went back to the endpoints and now the slider will go from GPS to ATTI on my gear switch.
What I can't get to operate is the Failsafe, My DX8 was already set up to 10% throttle from my last F550/NAZA.
When I turn the TX off the slider goes to the middle which is ATTI mode.
How do I get the pointer to go BLUE under Fail Safe ?
Old May 08, 2012, 10:35 PM
Adidas4275 is offline
Find More Posts by Adidas4275
manual flying apologist
Adidas4275's Avatar
United States, CA, Fresno
Joined Mar 2011
You can set any switch to any channel on the dx8
You have:
Flight mode (3 position)
Gyro (3 position)
Aux 2 (3 position)
Then (2 position)
Gear
Mix
With knob left over
Just assign them to what you want.
Adidas4275 is offline Find More Posts by Adidas4275
Old May 09, 2012, 05:31 AM
slidins15 is offline
Find More Posts by slidins15
Australia, NSW, Wollongong
Joined Aug 2011
how are you guys controlling you nex from your rc transmitters?
slidins15 is offline Find More Posts by slidins15
Old May 09, 2012, 07:53 AM
Jeffem62 is offline
Find More Posts by Jeffem62
Jeffem62's Avatar
United States, TX, El Paso
Joined Apr 2012
My question also, how are you controlling the nex shutter thru the radio. Please describe the set up in detail, and what is needed.
Jeffem62 is offline Find More Posts by Jeffem62
Old May 09, 2012, 08:13 AM
Joined Mar 2008
On my cell so I dont have a link.
Just google GentLed, its only $35.
Is infra red bulb on a wire that plugs into a free 3 position switch on your radio.
Middle is off, flick the switch up or down and it takes photos, flick it the other way and it controls video.
Very awesome little gadget.
Old May 09, 2012, 09:59 AM
cdi3d is offline
Brushless
cdi3d's Avatar
Joined Mar 2009
Ken - I am talking about the Wookong-m - I do not use the course lock or home lock while using the camera shutter video controls via my gentled live I find them useless and more confusing to deal wiith while trying to frame the shot - I would recommend reading the DX8 failsafe procedure in the manual and rebinding your radio using these failsafe settings. Also make sure your throttle is in the middle blue area as well when you go into failsafe settings. Adidas is correct that you can program any switch on your radio - Thanks Adidas!
Also Ken you many want to think about setting up to be able to switch to manual mode I have found it needed in higher wind situations to get the copter back to where you want it
I do have my Ele DR switch and Ail Dr switch setup to control forward flight and piros -
Gentled link 0- http://www.gentles.ltd.uk/gentled/liveview.htm
Old May 09, 2012, 10:42 AM
Steph280 is online now
Find More Posts by Steph280
1.21 Gigawatts!
Steph280's Avatar
Irvine, CA, USA
Joined Oct 2000
Holger Buss of Mikrokopter demonstrated his upcoming camera control device in his latest "Zoom" video where he can also control the camera zoom remotely. Supposedly this device will work for all Sony cameras/camcorders, including NEX series. But it's unclear if this is a firmware for the Mikrokopter FC, or an actual widget.
I really wish the WKM has more channels available. When they made it compatible with Futaba S-BUS, they should have known that these S-BUS RX can handle up to 18 channels. With basic flight modes and camera gimbal controls taking up all 7 channels, there are no channels to control gains and other neat stuff like camera pan, retracts, LED controls, etc.
Steph280 is online now Find More Posts by Steph280
Old May 09, 2012, 11:22 AM
Joined Mar 2008
You have:
Gyro (3 position)
Aux 2 (3 position)
Then (2 position)
Gear
Mix
With knob left over
I got it all figured out. I cannot activate the F-Mode switch, maybe it has to be in heli mode.
So I have everything operating including the fail safe when TX is turned off.
I have U on my gear switch and only have ATTI and GPS ATTI which I'm ok with.
Then AUX1 for the Sony, and AUX2 for OFF/Course Lock/Home Lock
AUX3 for gains.
So all is good now.
I wish I could have the F-Mode on U then I could have manual too but I tried for a long tome to activate it but it will not so I'm guessing it's only available in heli mode.
I could start all over in heli mode but I'm good for now.
Old May 09, 2012, 11:27 AM
Joined Mar 2008
Thanks for the assistance, I read the manual about F-Mode setup but it's in inhibit and when highlighted nothing happens when I turn the roller which made me think it only works in heli mode.
I've flown in pretty heavy winds and took off fine in ATTI mode so I'm good there. I tried taking off only one time in Manual and it was too squirrly and I have some expo.
Old May 10, 2012, 02:02 AM
topgearuk is offline
Find More Posts by topgearuk
topgearuk's Avatar
United Kingdom, London
Joined Dec 2003
AUX3 for gains.
So all is good now.
My f-mode works fine in plane mode. You just need to assign that switch in settings on the TX. No need to use heli
topgearuk is offline Find More Posts by topgearuk
Old May 10, 2012, 08:39 AM
cdi3d is offline
Brushless
cdi3d's Avatar
Joined Mar 2009
Ken - In order to get your fmode switch to work you need to inh your gear channel (or whatever channel you want to use it for) then set the fmode switch to replace the gear switch - Easy - Hold down the selector wheel - turn tx on - scroll down to switch select - and set it
Discussion dx8 with ar8000 flaps not working carp886 Radios 1 Feb 10, 2012 10:50 AM
Sold DX8 with AR8000 and TM1000 sent into Horizon in Jul2011 with updates $360 legobrains Aircraft - General - Radio Equipment (FS/W) 3 Nov 13, 2011 05:03 PM
Sold Price Reduced...Telemetry Unit and AR8000 from my DX8 Package mondo1948 Aircraft - General - Radio Equipment (FS/W) 0 Jun 10, 2011 06:42 PM
Sold Spektrum DX8 with new AR8000 DSM2 Rx and Spektrum 7.4 LiPo TX battery crosby Aircraft - General - Radio Equipment (FS/W) 1 Dec 15, 2010 11:54 AM
Sold NIB Spektrum DX8 8CH Transmitter with AR8000/TM1000 moxjett Aircraft - General - Radio Equipment (FS/W) 6 Oct 31, 2010 07:23 PM
