Old May 08, 2012, 03:37 PM
Damuelson is offline
Find More Posts by Damuelson
Joined May 2012
Noob quad queries
Hi I been flying a tricopter for a while and am now going to build a quad however I need some real basics on the set up like do I wire the motors up different to get opposit rotation ? What size props should I use arms are 500 mm long from centre ? And can I wire 2 separate battery packs together to give longer flight time many thanks any links to the answers would be great cheers
Damuelson is offline Find More Posts by Damuelson
Old May 08, 2012, 08:23 PM
Dave8888 is offline
Find More Posts by Dave8888
United States, AZ, Seligman
Joined Nov 2011
Yes if quad is set-up in + mode, then front and back motors turn in one direction and the 2 side motors turn in the opposite direction. Look at firmware to see which 2 are CW and which 2 are CCW.
I used 10 x 4.5 on my 500mm, but I think I should have used 11 x 4.7.
Yes you can wire 2 batteries in parallel, but you will not get double the flight time because of the added weight. It will take more power to hover. I used 2 3S 2200 20C batteries in parallel and didn't like the loss in power.
Dave8888 is offline Find More Posts by Dave8888
Old May 09, 2012, 02:34 AM
Joined May 2012
Cheers that's just whati needed to clear my Tain of thought so better getting just one big battery I was starting out with11 4.5 props so I'm hoping there be man enough on dk750 motor and just swapping 2 wires to set rotation direction I'm set to start crashing many thanks
Old May 09, 2012, 09:15 PM
Dave8888 is offline
Joined Nov 2011
When you say "dk750 motor" do you mean dt750 if so, that is what I am using with 10 x 4.5 cheap ebay props and tricopter weight is 860 grams. It hovers at about 55% to maybe 60%. 11 x 4.5 should work great on these motors.
Help! Im so confused!! noob quad help. jabu32 Multirotor Talk 63 Jul 10, 2012 06:53 AM
Discussion A noob wants to build a quad tech69x Multirotor Talk 4 Apr 23, 2012 02:19 PM
Discussion Noob builds a quad Azarr Multirotor Talk 12 Jul 16, 2011 07:31 AM
Build Log UAVX noOb Quad Build SX_ Multirotor Talk 73 Jul 11, 2011 04:00 PM
Question How difficult is a quad / tri copter to fly (for a noob)? gobigkahuna Coaxial Helicopters 8 Jun 22, 2009 04:29 PM
