Espritmodel.com Heli Air
Old May 08, 2012, 01:16 PM
Gemini2's Avatar
United States, NJ
Joined Aug 2011
Folding Prop Substitution for Fixed - Questions
I first posted this over at NoFlyZone's blog a week or so back, but it looks like he really is on vacation, so I will try my luck here.
I will be building an Old Time converted FF rubber model with a direct drive & folding prop for slow stooging around & now & then heading way up, cutting the motor & letting the thermals take over.
I have run the data through Webocalc 1.5.2 & got to the magic '1.00 Approx gear ratio', for 2 fixed props.
I haven't figured how to get the Webocalc image up here, so I have the core left hand side data [imperial] from Webocalc, as follows:
RTF Weight: 28 oz; WS: 64"; WA: 464; MPS: 15, FM: Gentle; DTS: 36, DT: 21, ME: Avge Outr, 75%; Batt: L 3S 20C; BV: 10.8, DCM: 8.7; KV: 570
This pops out the APC-TE 12.0 x 8.0 & the GWS-HD 12.0 x 8.0 with the "1.00" AGR.
Now, I am looking at the Aeronaut Cam folding prop range & wonder if I can put a pair of 12.0 x 8.0 blades (AN-7234-50), on a 52mm yoke & that will be the best I can do??
Or whether using a 52mm yoke means I need to tweak the blades away from the 12.0 x 8.0's to compensate for yoke size??
Or, are there any other factors associated with using a folding prop ilo of a non folder I should consider in prop choice??
Thank you
G2
Gemini2 is offline Find More Posts by Gemini2
Old May 08, 2012, 08:32 PM
We want... Information!
Bruce Abbott's Avatar
Hastings, New Zealand
Joined Jan 2001
Using a 52mm yoke increases prop diameter by 0.4 inches (compared to a 42mm yoke) which will cause about 8% higher current draw. If your motor and ESC can handle this then it shouldn't be a problem, otherwise use 12x6.5 blades.
Bruce Abbott is offline Find More Posts by Bruce Abbott
Old May 09, 2012, 08:40 AM
Gemini2's Avatar
United States, NJ
Joined Aug 2011
Thanks Bruce, exactly what I was looking for.
G2
Question !3x6.5 folding prop or 14x8 folding prop? hog2soar Power Systems 4 Feb 02, 2012 04:39 AM
Question Aeronaut Cam Folding Prop Question smewr Electric Sailplanes 17 Jan 19, 2012 12:04 AM
Help! Folding prop question. dr_serious Electric Plane Talk 3 Jan 03, 2012 11:56 AM
Question Drella mod for folding props? MrE Electric Sailplanes 5 Sep 27, 2011 03:06 AM
Discussion Folding Prop question-should it fold when landing? HIGHFLYER99 Electric Plane Talk 18 Mar 27, 2006 04:55 PM
