Old Oct 31, 2003, 11:57 AM
JoshFlies3d is offline
Find More Posts by JoshFlies3d
Sacramento, CA
Joined Sep 2003
Question
Whats the cleanest way to mount a B20 to a Profile depron fuselage?
What is the cleanest way to mount a Hacker B20 15L onto a Profile Depron fuse?
Pictures and ideas would be appreciated.
Josh
JoshFlies3d is offline Find More Posts by JoshFlies3d
Old Oct 31, 2003, 01:15 PM
RCAV8R13 is offline
Find More Posts by RCAV8R13
I'm goin' Falcon nuts
RCAV8R13's Avatar
White Salmon, Wa
Joined Oct 2003
Re: Whats the cleanest way to mount a B20 to a Profile depron fuselage?
Josh
Hi Josh,
I don't know if it is the cleanest way but here is how I did it on my Vertigo Pro. I filed a flat notch in the carbon tube for the motor to sit on and just zip tied it there.
RCAV8R13
RCAV8R13 is offline Find More Posts by RCAV8R13
Old Oct 31, 2003, 01:26 PM
Sacramento, CA
Joined Sep 2003
That looks real clean to me
Thanks, That's how I will mount mine.
Josh
Old Oct 31, 2003, 03:37 PM
STRINGFLY is offline
Find More Posts by STRINGFLY
STRINGFLY's Avatar
Little Rock Regional, Arkansas, United States
Joined Sep 2002
landing gear.
I do a lot of profiles.. and a nice shot of your landing gear install would be great also. Thanks.......
String
STRINGFLY is offline Find More Posts by STRINGFLY
Old Oct 31, 2003, 04:08 PM
kepople is offline
Find More Posts by kepople
Real Men Fly Pink Planes...
kepople's Avatar
United States, TX, Rockwall
Joined Jun 2001
Thats CLEAN!
I used a GWS mounting stick which is drilled at one end and epoxied to the CF support rod. Then I use the Stevens aero mount for hackers, and the GWS box just likeds on. The reason is that I can switch between the 3 times as powerful Hacker and the Razor 400 in a GWS gear box.
Kirby
kepople is offline Find More Posts by kepople
Old Oct 31, 2003, 09:00 PM
FASTBEN is offline
Find More Posts by FASTBEN
Cumulus Altimus
FASTBEN's Avatar
United States, TX, Keller
Joined Feb 2002
rca,you got pm
FASTBEN is offline Find More Posts by FASTBEN
Old Oct 31, 2003, 09:15 PM
RCAV8R13 is offline
RCAV8R13's Avatar
White Salmon, Wa
Joined Oct 2003
Re: landing gear.
String
String,
Here's a pic of the L.G. install on the Vertigo Pro. I made a small 1"x1"x1/4" lightply block glued into a cut out in the fuse. I then capped each side with 2"x2"x1/32 ply. I Dremeled out a small groove for the wire to sit in, drilled four holes and zip tied the grear on. It's light and strong and I can take it off if I want.
RCA
Old Oct 31, 2003, 10:41 PM
Sacramento, CA
Joined Sep 2003
Slick!
Im going with no gear on my Foam Edge im building right now, But maybe next one!
Josh
Old Nov 01, 2003, 07:57 AM
STRINGFLY's Avatar
Joined Sep 2002
thanks....
THanks for the gear shot... I have tried a few methods but have not been very pleased with them... Will give that a try... Thanks again................STRINGFLY
Question Whats the best way to mount pushrods inside of the boom?? RandyK1 Electric Sailplanes 20 May 28, 2006 04:26 PM
Whats the best way of forming foam? Aubrey Foamies (Kits) 0 Feb 28, 2002 01:19 AM
down thrust, right thrust, Whats the best way to do this? hawkeye_abm Beginner Training Area (Aircraft-Electric) 5 Feb 08, 2002 09:23 AM
Best way to mount an Endo/E3D motor? ScotY Sport Planes 19 Dec 06, 2001 06:22 PM
aggg, whats the best way to connect 2 computers?? TheSpruceMoose Life, The Universe, and Politics 23 Aug 01, 2001 01:06 AM
