Nov 01, 2003, 03:25 PM
Joined Jun 2002
I don't think you want to put the template at the edge of the foam because that's were the most stress is in the foam.
I like to put the templates in the middle of the foam (or offset from the middle if I think I can get two cores out of a thickness of foam). I then use the following technique:
I put the hot wire bow in a vise and hold the foam in my hands.
To make the first cut, I hold the wing with the leading edge toward me, the wire above the wing. I cut down toward the wing and have the wire hit the template about an inch or so back from the leading edge of the wing. It hits at a bit of an angle because I want it to be moving along the wing when it hits so that i don't burn extra deep as I stop and change directions.
I slow down when I get to the trailing edge, but keep moving. After falling off the trailing edge of the template, I cut down, then pull out of the block at the rear.
For the next cut, I keep it the same side up, but hold the trailing edge toward me. I again make a flying start and I hit the template about 3/16" from where I hit the template the last time. This leaves a pointy ridge of material on the top of the wing that I have to sand off later, but it allows the wire to go through some foam before getting to the template, cooling the wire a little.
I continue cutting toward leading edge of the wing (with the wire on top of the wing) and go around the leading edge and start cutting the bottom of the wing with the wire under the wing. After I get an inch or so back from the leading edge, I flip the wing while still cutting without stalling the wire so that I can finish again with the wire on top, pulling the core toward me as it exits at the trailing edge again.
This technique allows me to make thin trailing edges without melting things because I don't stall at the trailing edge.
I hope this helps.
- Brad
