| Thread Tools |
| This thread is privately moderated by Cash Traylor, who may elect to delete unwanted replies. |
P-51D Mustang ARF Kit, Top Flite Gold Edition, NIB, LPU
P-51D R/C Balsa (Not a cheap foamie) Model Mustang ARF (Almost Ready to Fly) Kit. $200 Local Pickup - North Dallas Area, Preston and The George Bush Turnpike.
This kit is NEW, IN BOX, only opened to verify parts and condition when I got it, everything original from Top Flite and it is a BEAUTIFUL plane. The kit is in new condition, stored indoors, all parts still in original bags. I intended to convert this to electric power (that's all I fly) but I no longer have a place to fly something this size and have scaled back my hobby. Breaks my heart to sell this because it is beautiful. I have seen this plane powered by a 60 or 90 size e-flight brushless and 6 cells and it was really impressive, as it is a light well built kit. Here is the manufacturer link and info on the kit. http://www.top-flite.com/airplanes/topa0950.html ****This plane, although I intended to convert it to electric power is actually a fuel powered kit so I have duplicated it in the fuel section. Once it sells I will close both posts. Thank you for your interest, please feel free to ask any questions.**** Thank you for looking! Description This is the radio controlled" glow powered almost ready-to-fly 1/7 scale Top Flite P-51D Mustang 60 size Sport Scale Airplane with Retracts. For Intermediate to Advanced Modeler/Fliers. Eligible to compete in the Fun Scale class in AMA competition. FEATURES: Construction: Built up balsa and light ply fuselage and wings Wing: One-piece with built-in flaps Covering: Factory applied Top Flite MonoKote Radio Compartment: Easily accessible plywood reinforced Cowling: Pre-painted fiberglass Air Scoop: Pre-painted fiberglass Canopy: Vacu-formed clear pre-painted Landing Gear: Mechanical retracts made of high-quality composite Wheels: Main two 3.25" (83mm) one 1.25" (31.75mm) tailwheel Dual Wing Servos: Two servos per wing half (1 Flap 1 Aileron) Spinner: 4" (100mm) pre-painted aluminum with adapter for 5/16-24 crank shaft Cockpit Kit: Instrument Panel Seat Back Dummy P51 Radio and Battery Building Time: Ready to fly in only 18-25 hours Warranty: Top Flite Models guarantees this kit to be free of defects in material and workmanship at the date of purchase. This warranty does not cover any component parts damaged by use or modification. INCLUDES: Pre-built and covered wings fuselage and tail assemblies pushrods retractable main landing gear 3.25" (83mm) main wheels 1.25" (31.75mm) tailwheel adjustable engine mount painted canopy 14oz (420cc) fuel tank pilot bust instrument panel dummy radio and battery seat back belly pan fiber glass air scoop fiber glass cowl ABS exhaust stacks extensive hardware package and photo-illustrated instructions machine guns landing gear strut covers full set of colored decals REQUIRES: Engine: .60 - .91 cu in (10 - 15cc) 2-stroke OR .90 - 1.20 cu in (15 - 20cc) 4-stroke Radio: 6-channel Servos: 7 Standard (2-Aileron 1-Elevator 1-Throttle 1-Rudder 2-flap servos) 1-Retract Servo 24" Servo Extensions: Two (one for each aileron servo) Dual Servo Extension: Two for flap and aileron servos Receiver Battery: 1000mAh minimum Misc. Items: Glow plug ¼" foam rubber padding medium fuel tubing fuel filter propeller building and field equipment. SPECS: Wingspan: 64.5" (1640mm) Wing Area: 721 sq in (46.5 sq dm) Weight: 8.75 - 10lb (3970 - 4540g) Wing Loading: 28 - 32 oz/sq ft (85 - 98 g/sq dm) Length: 56" (1420mm) Airfoil: Fully-symmetrical low-wing Center of Gravity: 5-5/8" (143mm) Back from the wing's leading edge Control Throws: High Rate Low Rate This kit is covered in the following Top Flite MonoKote colors: Olive Drab TOPQ0510 Aluminum TOPQ0205 Black TOPQ0208 Jet White TOPQ0204 |
Reason: Price lowered
Older models have a battery hatch that was covered over right in front of the canopy when the company was going to offer an electric version. Does the fuse have the battery hatch that only needs to be cut out?
Latest blog entry: This season's 3D line up...
| Thread Tools | |
| Sold P-51D Mustang ARF Kit, Top Flite Gold Edition, NIB, LPU | Cash Traylor | Aircraft - Fuel - Airplanes (FS/W) | 10 | Sep 19, 2012 05:15 PM |
| For Sale Top Flite Gold Edition P-51D Mustang ARF, NIB - LPU | Cash Traylor | Aircraft - Fuel - Airplanes (FS/W) | 0 | Feb 21, 2012 01:09 PM |
| Sold Top Flite P-51D Mustang Giant Gold Edition Kit 84" WS/Robart Retracts $600 CONUS | purcilas | Aircraft - Fuel - Airplanes (FS/W) | 2 | Jan 05, 2012 12:29 PM |
| Found Top Flite P-51D Gold Edition 60-1.20 1/7th scale sport kit | proteus_x3 | Aircraft - Fuel - Airplanes (FS/W) | 4 | Oct 10, 2011 10:25 PM |
| Wanted Top Flite gold edition P-40 kit 1/7 NIB | stuart warne | Aircraft - Electric - Airplanes (FS/W) | 0 | Sep 29, 2011 11:07 AM |
