Old May 07, 2012, 05:48 PM
schusterjo is offline
Find More Posts by schusterjo
United States, IN, Lebanon
Joined Oct 2011
How to make perfect wing rib....
Is there a relatively cheap way to make perfect rib every time (scratch built with a pattern)? Mine to seem to be inconsistent as well have nicks... I know back in the day in shop I used a pattern an had some kind of router device that I could just run around the outer edge of the patter an it would cut what ever shape the patter was underneath. Anyways i need to make many spars an would like for them to be all the exact same preferably making many all at once.. a machine? a router way? ???? any???
schusterjo is offline Find More Posts by schusterjo
Old May 07, 2012, 10:28 PM
Thermalin is offline
Find More Posts by Thermalin
I'm a pilot, 100 yrs too late
Thermalin's Avatar
USA, FL, Palm Harbor
Joined Jan 2005
I dont think you will easily beat what you can get at te LHS for dimensional accuracy across spars. A router is more used for edge design. A table saw would be a better choice but a bit dangerous as your basically shaving 1/4" or whatever size strips off te main piece. Also when you do that you usually end up with some bowing as they cure due to the drying rate of the outside portion of the piece compared to the inside portion.
How many do you need and of what size
Thermalin is offline Find More Posts by Thermalin
Old May 08, 2012, 03:02 AM
slipstick is offline
Find More Posts by slipstick
Staffs, UK
Joined Nov 2003
Are you sure you mean spars ? A spar is normally just a long straight piece of wood and as Thermalin says it's much easier just to buy the correct size rather than "make" it.
Steve
slipstick is offline Find More Posts by slipstick
Old May 08, 2012, 07:18 AM
Joined Oct 2011
Steve
sorry, its the rib I would like to accomplish.. been a very long few days
Old May 08, 2012, 08:11 AM
Al Offt is offline
Find More Posts by Al Offt
Boston, MA subburb
Joined Sep 2004
You may find this site to be interesting. The particular link http://www.airfieldmodels.com/inform...ribs/index.htm is a way to make uniform ribs.
Alan
Al Offt is offline Find More Posts by Al Offt
Old May 08, 2012, 12:56 PM
eflightray is online now
Find More Posts by eflightray
An itch?. Scratch build.
eflightray's Avatar
South Wales U.K.
Joined Mar 2003
For parallel chord wings, (all ribs the same), the sandwich method is probably the easiest without using special machinery.
You need two templates with a number of slightly over size blanks in between, then just sand to shape, and cut-out the spar slots with a junior hacksaw.
I have created sets of balsa ribs that way for years, now everyone seems to have their own personal CNC machine, or knows someone who has one.
Addition. - It can also be done for tapered wings, but the ribs will need individual truing as they will likely have angled edges. But it's still an easy method.
eflightray is online now Find More Posts by eflightray
Old May 08, 2012, 01:11 PM
eflightray's Avatar
South Wales U.K.
Joined Mar 2003
I found some pictures and text of the sandwich method - http://www.scale-models.co.uk/tutori...wing-ribs.html
Old May 08, 2012, 01:45 PM
BMatthews is offline
Find More Posts by BMatthews
B for Bruce
BMatthews's Avatar
The 'Wack, BC, Canada
Joined Oct 2002
Small shaping errors are not as important as having a smooth progression from one rib to the next... .at least small errors are not important unless you're making a high performance sailplane. For regular sport models the airfoil shape only has to be "close enough". By this I mean within the thickness of a pencil line or so.
For myself I cut out a hard sheet stock or plywood template which is purposely cut out about a pencil line out from the final desired shape. I cut out all the ribs using this template for the outline with no spar notches at that point.
Once I have enough blanks they are stacked and either pinned or bolted through some drilled holes with long machine screws. The hard templates being on either end. I sand down this block of ribs so they are smooth and as accurate as I can given the use of hand tools and bleary eyeballs filled with balsa dust. Usually this means being able to decently split the line on the templates for the final shape. At that point the spar notches are rough cut with a Zona or similar saw and some small coarse cut metal files that have non cutting smooth edges on one or more sides are used to trim the notches to a nice firm finger push fit to the spar stock.
As the ribs come off the stack I number them from one end to the other so they can go into the wing in the same order. This automatically graduates any final slight errors evenly along the span so the spar notches at least are in a straight line the whole way.
If you want or need anything more accurate than this you're looking at laser cutting or CNC routering. But unless you're doing something very exotic you really don't need anything better.
BMatthews is offline Find More Posts by BMatthews
Old May 08, 2012, 05:47 PM
Joined Oct 2011
how much a small cnc cost? including software or whatever is needed to complete? another words everything to be able to have it making ribs?
Old May 08, 2012, 06:34 PM
Captain Dunsel is offline
Find More Posts by Captain Dunsel
United States, NJ, Southampton Township
Joined May 2005
For constant chord wings, I make a stack of blanks bigger than the pattern (which is glued to the top blank), then jig saw almost down to the line. I then use a sanding block made from a scrap of spar stock with sandpaper glued to it to get the spar slots open.
Next, scraps of spar stock are wedged into the spar slots, and the whole sandwich gets block sanded on a power sander.
As a side note, when I use the ribs, I alternate them from one end of the stack, so if the stack is not perfectly square, any taper that snuck in is matched on both wing panels.
Tools requried: Jig saw (Mine is a 30+ year-old Dremel), power sander, and sanding blocks.
Almost forgot: I print my plans out on an old LASER printer, then glue the templates in place with a glue stick.
CD
Captain Dunsel is offline Find More Posts by Captain Dunsel
Old May 08, 2012, 11:51 PM
B for Bruce
BMatthews's Avatar
Joined Oct 2002
A helluva lot more than an Xacto knife, a couple of sanding blocks some pins or long bolts, a little harder balsa or plywood for templates, a few other handtools mentioned already and about an hour of your time.
Compared to building the rest of the model cutting out and shaping the ribs isn't that big a deal. You want painful and difficult? Making up and installing the servo mounts and pushrods is WAY more time consumning and difficult.
Old May 09, 2012, 04:09 PM
rcav8r2 is offline
Find More Posts by rcav8r2
rcav8r2's Avatar
United States, PA, Beaver
Joined Sep 2001
Bare Bones machine ~ $400 to ~ $1000 and more depending on size, speed, etc.
Driver software Free (need Linux) , or about ~$150 for Mach3 (Windows).
Driver board - ~$100-$500 depending on a lot of factors
Steppers - Typically 3 needed. ~$20 to ~$ 100 a piece.
CAD software... Free to thousands of $$
CAM software - Free to Thousands of $$
Motor tool --- ~$50 - ~$300
PC to run it. You will want a dedicated one with a parallel port . ~$50-100 used
Other Misc stuff (stand for it, limit switches, wiring, cutting bits, etc) - ~$100 - $200
I built a CNC machine because it's something I always wanted to build. They always fascinated me. It was actually easier that I though and works really well. I didn't built it to save time or for more accurate parts. I still manually cut out simple shapes and parts I forgot to add to my drawings as it is easier than setting up just one or 2 parts for CNC.
But before that I hand cut everthing, and as BMatthews said, cutting the ribs out are a cake walk compared to other tasks you will need to do. Also most wood is only nominally dimentioned... That is an 1/4" x 1/4" spar stock isn't always 1/4" square. When cutting by hand you can adjust for a nice fitting spar. With CNC you need cut smaller than what you think it will be and sand to fit anyway. At least that's what I do as I draw first, then order the wood so I have no idea what it REALLY is.
Unless you want to do CNC for the fun of it, it really won't save you any time for cutting out parts for a plane. This is particularly true when building from a physical set of plans. YOu need to digitize them, and if your not careful, the sizing can be way off. Now tab and slot stuff for a keel built self designed fuselage... Yea, a CNC is real nice
rcav8r2 is offline Find More Posts by rcav8r2
Old May 10, 2012, 04:32 AM
RC Trainer plane is offline
Find More Posts by RC Trainer plane
Balsa builder and balsa basher
RC Trainer plane's Avatar
Joined Apr 2012
This is a relatively cheap way to make wing ribs exactly the same it's explained fully in this link. http://www.airfieldmodels.com/inform...ribs/index.htm
also to make exact spars here's a product you might be interested in from my local hobby store avicraft.
Avicraft - Balsa Cutter demo (5 min 18 sec)
if you want to buy it here's the link to their store http://www.avicraft.co.uk/tools/hand...-to-58mm-.html
hope i helped
RC Trainer plane is offline Find More Posts by RC Trainer plane
Old May 11, 2012, 12:05 PM
madbomber is offline
Find More Posts by madbomber
Hatters gonna hat.
madbomber's Avatar
United States, CO, Denver
Joined Apr 2011
Ive found this way to work wonderfully for hand cutting out wing ribs.
http://www.rcgroups.com/forums/showp...&postcount=101
madbomber is offline Find More Posts by madbomber
Old May 11, 2012, 12:31 PM
rcav8r2 is offline
rcav8r2's Avatar
Joined Sep 2001
I forgot about this web page I did YEARS ago.....
http://home.comcast.net/~daverc102/spookmain.htm
Cutting the Parts 1, 2, & 3 (left frame) show how I manually cut ribs....
Question How do you make the perfect servo pocket? eteet Hand Launch 16 Mar 26, 2015 02:25 PM
Build Log Making laminated spar caps Anker Sailplane Talk 14 Jul 05, 2012 05:13 PM
Discussion How can i make perfect lightening holes in balsa? fezzgig Electric Motor Design and Construction 9 Jan 18, 2010 11:29 AM
Discussion How to make a perfect solder join flystoolow Power Systems 10 Jan 31, 2008 11:11 PM
Idea how do you make The perfect transportable single fin... flybaby2000 Slope 24 Dec 04, 2005 12:40 PM
