Old May 07, 2012, 04:50 PM
4stroker is offline
Find More Posts by 4stroker
Closed Account
Joined Dec 2004
Who can laser cut wing ribs ?
I want to use the NACA 23012 on the Trittle Pitts 14 . Who cuts ribs , is it expensive ?
4stroker is offline Find More Posts by 4stroker
Old May 07, 2012, 06:57 PM
PETERRAKE is offline
Find More Posts by PETERRAKE
Norfolk, England
Joined Sep 2001
You'll either need to prepare a CAD file of exactly what you want, or be prepared to pay someone (the cutter) to do it for you. Don't forget that every different rib has to be plotted and then nested onto a wood size panel. That alone can take several hours, depending on how many different ribs there are. The last time I got any done for me they charged about 40 ($60) an hour. Frightening, isn't it?
Pete
PETERRAKE is offline Find More Posts by PETERRAKE
Old May 07, 2012, 07:42 PM
spog is online now
Find More Posts by spog
Joined Mar 2006
It's so easy to make your own, just as good as laser cut. For that kind of money, it's worth learning how to do.
spog is online now Find More Posts by spog
Old May 07, 2012, 10:11 PM
4stroker is offline
Closed Account
Joined Dec 2004
Can you point me to this information ?
Old May 08, 2012, 12:15 AM
arcarius is offline
Find More Posts by arcarius
Troy Bowman
arcarius's Avatar
United States, UT, Woods Cross
Joined Sep 2011
Wait, you mean with a hobby knife, right?
arcarius is offline Find More Posts by arcarius
Old May 08, 2012, 12:31 AM
portablevcb is offline
Find More Posts by portablevcb
Neophyte hacker
portablevcb's Avatar
Albuquerque, NM USA
Joined Sep 2003
If you can't do the CAD work yourself it is obscenely expensive. When I can find time for it I charge $50/hr. But, I rarely have time for it.
We have tried to find a regular to do CAD work, but, they either work for peanuts and get burned out, or, they charge a reasonable fee and no one wants to pay that much.
For the Pitts you should consider cutting your own. Most of the ribs will have the same outline with just a couple of variations. Make a ply template and get/make some hole punches (for servo leads and such).
The method I use is to bandsaw/jigsaw out a stack of ribs (just the outline). Then use the template. Cut notches with a knife (or on the bandsaw). Punch holes where needed.
You can also use two templates, clamp the stack of ribs between them and sand down to final dimensions. Then use a template for notches/holes.
charlie
PS yes, it is even easier for me to cut ribs sometimes rather than designing it on CAD and making the cut file. The difficult part is to convince Vicki to cut them for me on the laser
portablevcb is offline Find More Posts by portablevcb
Old May 08, 2012, 04:49 AM
spog is online now
Joined Mar 2006
I print out the rib on an inkjet printer. I glue two pieces of balsa together with a couple dabs of CA at the center of where the rib lightening holes will be, then I CA the pattern onto the ribs. Rough cut with a saw, finish off the edges to the pattern line on a bench sander. Then when you cut out the lightening holes with a scroll or zip saw, the ribs will separate from each other. I have made 8 ribs at once with 1/16" balsa, just make sure that you have a 90 degree angle on the sander's base. A sander does a very nice job and it's easy to get perfectly cut ribs.
Old May 08, 2012, 09:21 AM
Santoneski is offline
Find More Posts by Santoneski
Santoneski's Avatar
Canada, ON, Hamilton
Joined Feb 2009
buy a band saw and make a template.
Santoneski is offline Find More Posts by Santoneski
Old May 08, 2012, 10:16 AM
Bill Smudge is offline
Find More Posts by Bill Smudge
Bill Smudge's Avatar
United States, KY, Bowling Green
Joined Jul 2011
Tack glue your rib stock together, I use purple Elmers stick glue, make a copy of your rib. Glue the rib copy to your stack of rib stock.
I then use my table top disk sander to sand down just to the paper template, ribs come out smooth and darned near perfect. Cut spar notches with band-saw or other very fine toothed saw.
Bill
Bill Smudge is offline Find More Posts by Bill Smudge
Help! Who can laser cut parts from plans ?? deanz406 The Builders Workshop 9 Dec 31, 2011 09:12 AM
Help! Who can Laser Cut Coop 3D Flying 3 May 18, 2006 08:13 PM
Bird of Time Laser Cut Rib Sets now available! gavoss Product Announcements 1 Aug 09, 2003 08:43 PM
