Cbear,
Yes, I said give the rudder & elevator servos a shot or two - but that doesn't imply that one should spray the entire brick. Regarding corrosion - the CC is most definitely not suited for flying off saltwater. As is the case with everything when you live on the coast - corrosion is a concern. However - many tens of thousands of people fly RC in coastal areas. It just takes a bit more preventative maintenance. BTW - there is no salt in regular fog or morning dew, as the salt stays behind when saltwater evaporates. I suppose that at only a half-mile away, you still see some wind-whipped salt-fog, though. Do you have corrosion problems with cars, outdoor antennas, etc. in your neighborhood? If not, you will be just fine when flying on wheels. If so, you may want to clean the servos more often. Joel |
Latest blog entry: Eflite UMX Sbach 3D on 3s - 2300Kv/5043...
Well...being a skier I thought I would mod the CC water floats for snow (ROS). I had a problem with the stock floats. They worked well until the snow warmed and softened. In new loose snow I could taxi about and really carve some nice turns. In warm snow all the floats would do is go straight. I have my rudder control horn on inner hole.
My plan was to shave down the floats so the bases were flat like snow skis. I was amazed at how heavy the floats made the plane fly so a little weight off them seemed good also. I cut the floats down to the shape shown in the photo. Results were: I only lost 2 grams of weight total for both but the plane does feel a bit lighter and I don't need to trim the elevator for the weight now. No difference in the tracking though. It was 10 degrees at flight time with 2 inches of new so I'm not definite on any improvements but it didn't seem much different. So all I got from this mod was floats a bit lighter. Really having a great time landing on snow. Very good for my glide path and soft touch landing practice. No worries about lining up runway as it's unlimited with the snow on the field. I'm thinking it's going to be odd landing on tarmac someday when the snow leaves us. Mike |
Here's another tip for turning on snow. When I attempted to taxi in snow conditions that made turning impossible at normal taxi speeds, I found that taxiing fast enough to take some weight off the floats solved the problem. Also - extending the flaps to the take-off position will generate the required lift at a lower taxi speed.
Joel |
Just completed my test fights with the 0503 prop and tp325 battery. I could not tell if the 5030 prop was any more efficient or not but I can tell you one thing for certain. THat prop is much more durable to blade strikes than the stock prop was.
As for the battery, I like the duration you get from it. It does seem to fly slightly faster with it but landing is much easier with the extra weight. THe approaches are faster and tend to nose over less when no flaps are used. With flaps deployed, I am sure the approaches are still faster but it is hard to tell the difference. The added weight seems to keep the plan from dropping like a brick immediagly once you flair out. It still will stall out but the time between flair and stall seems to be a little wider. With the 180 pack, I had to make approaches on a 30 degree decline ((no flaps) in order to keep from stalling and nosing over when it touched down. Seems my approach may be in the aea of 25 degrees or so. Slightly better. Any one else notice that this plane is easier to fly heavy? |
I'm thinking that if the tape starts coming off I'm going to try shaping the edges rounder to reduce tracking. I still have plenty of foam left. Thanks to all for the advice. Looks like it might be awhile before I ROT (roll on tarmac?) My Beast and Sbach are gathering dust. Mike |
Rscarawa,
I also think it flies better with a bit more weight. The TP 325 65c pack is my favorite in this plane. RCBabbel's custom lightweight version provides the highest thrust-to-weight of any pack that will fit. Of course, the CC has power to spare for any maneuver even with lesser packs, but I'm always interested in maximizing efficiency, and the TP 355 65c is definitely the most efficient UMX pack so far. Joel |
hey A RDNEK , i love that name , funny but there are days around here that id take you up on the switch thing, ive got alot of projects going on right now here at home , i have the only house for miles with no sod in the yard,installed a bulkhead and the trachoe tore it up and now im getting used to not haveing to mow the grass, kinda nice
and joel, i make it a habit never to argue with a rocket sciencetist, but i cant resist, when you say quote...if it made it to the brick...sorry but to me that means brick, your words not mine.please can we let this dog rest..also id like to clear the air about the term salt air. its true what you said about evap and salt, sodium chloride has a very low vapor pressure and will not evaporate or subline except at exceedingly high temputures, however, the action of wave or as i like to call it surf throws tiny droplets of salt water into the air, when the water evaporates it takes nano ( very teenie) scale particles of sodium chloride(salt but very teensie)in the air, carried by the wind dependant of speed and temp for miles(pretty far)or my house so durring high humid or fog conditions there are in fact trace par. tic.cle of sodium choride in the air...hence the term salt air. and now the cc, why we all are here.to offer constructive advice and share a comon love for model avation.imo if you bring a plane to the market, offer a float kit, cut a air hole 3/4 of a inch away from the reciever(brick) and then have countless failures thats just (plane) PUN INTENDED stupid. ive been in this hobby since 1965, my father flew rc when test tubes lit up your hands and a controlled crash was the best you could hope for, to defend something because you sleep with it is just silly, is this a cute plane, do we like the way it looks and flys,heck yeah, but there is a issue with the boards, be it dissimilar metals, galvanic corrosion, or mabe the leadfree soder train wreck thats heading our way. dont know, dont care, if they get the bugs worked out , im all in, would buy another in a new york minute, but today mine went back for a full refund, gona miss the plane, just not the bs
![]() Had a record January last year, though... 18 days above freezing... was new to the hobby and had my mcx2 and 120sr helis outside alot
Question about tail feather repair. My rudder and elevator have crease lines on them and are getting a little deformed. What can be done to extend the life of these parts? I saw someone replaced the parts with balsa mock ups. Short of replacing these parts, does any one have good patch methods for these?
http://www.rcgroups.com/forums/showt...85631&page=352 The Varathane he used... water based polyurethane (wbpu) is similar to a water based finishing resin by Deluxe Materials called EZE Kote that I just used a couple of days ago, along with 24g cloth, to glass my Super Cub's wing tips. Very light weight especially if you don't use the cloth... which I wouldn't on something as small and CG sensitive as the CC. Some guys like the Minwax Polycrylic which is an acrylic (the "poly" stands for polymer... it's not polyurethane) hardened wood finisher like the wbpu. |
So on that note, the balsa is much more durable.
Joined Aug 2012
| Thread Tools | |
| New Product E-Flite UMX Carbon Cub SS | fragje | Micro RTF | 6889 | Yesterday 01:03 PM |
| New Product UMX Carbon Cub SS | masonjee | Electric Plane Talk | 2 | Apr 30, 2012 01:32 AM |
| New Product E-flite UMX Carbon Cub SS BNF with floats! | Firehawk989 | Waterplanes | 8 | Feb 28, 2012 01:48 AM |
| Wanted UMX Carbon Cub SS BNF | GOOBERSEPTEMBER | Aircraft - Electric - Micro & Indoor Airplanes | 6 | Feb 15, 2012 06:31 PM |
