Old Nov 12, 2012, 05:57 PM
airpower is offline
Find More Posts by airpower
Have fun
airpower's Avatar
United States, CA, Mission Viejo
Joined May 2007
Is the prop on backwards?
Letters face the front.
airpower is offline Find More Posts by airpower
Old Nov 12, 2012, 10:49 PM
Archi Bald is offline
Find More Posts by Archi Bald
United States, TN, Crossville
Joined Aug 2012
Originally Posted by Gator187 View Post
Not quite my experience. It's more like full throttle or die!!! Sure it slows down to a walking pace for perfect landings, but full throttle seems like 5-10 mph. I have the complete UMX line, and of course I expect this one to be the least aerobatic, but I dare not fly in ANY wind unless I want the plane to travel backwards. Just tried the 5030; which has noticably improves the others (sbach, beast, Geebee), but there was no noticable difference with the CCub No way would I even attempt aerotow with the ASK-21. Is it possible I have a bum motor? My packs are hyperion 240 25c. They perform amazing in all the other umx planes.
I just flew mine in a 30mph wind and it had plenty of power to pull through it.
Archi Bald is offline Find More Posts by Archi Bald
Old Nov 12, 2012, 11:46 PM
Justwingit is online now
Find More Posts by Justwingit
We got some flyin' to do!
Justwingit's Avatar
United States, TX, Fort Bliss
Joined Apr 2012
Hmmm....
I just flew mine today in a little bit of wind, with a slightly chopped down prop no less, and she was a banshee...
Mine flys straight and level, hands off, at 45-50% throttle. Takes off in less than two plane lengths at full throttle (no flaps) and climbs out at a respectable 45 degree angle. Loops. Rolls.
Dunno what to tell you...
Justwingit is online now Find More Posts by Justwingit
Old Nov 13, 2012, 12:00 AM
Gator187 is offline
Find More Posts by Gator187
Gator187's Avatar
Joined Mar 2010
...a legitimate response, but prop is installed correctly.
I'll try to fly soon with another with the CCub and record the other one doing loops around mine as I bury the throttle.
Gator187 is offline Find More Posts by Gator187
Old Nov 13, 2012, 01:58 AM
airpower is offline
Have fun
airpower's Avatar
Joined May 2007
Honestly have heard of one of these umx bl motors being bum from the factory. Is it rubbing on something?
Call HH.
Old Nov 15, 2012, 10:40 AM
Joined Aug 2012
I put a Rimfire 200 2400kv motor on mine with a 6x3 prop and love it. its quiet and has the power to climb strait up with a hyperion 320mah battery. Im able to fly it a lot slower too without flaps on
Old Nov 15, 2012, 01:32 PM
microheli is offline
Find More Posts by microheli
microheli's Avatar
Joined Jul 2006
She should perform like this:
http://www.rcgroups.com/forums/showthread.php?t=1670703
microheli is offline Find More Posts by microheli
Old Nov 15, 2012, 02:28 PM
turboparker is online now
Find More Posts by turboparker
Gopher huntin' stick jockey
turboparker's Avatar
Joined Jul 2009
Gator,
As Microheli noted - a CC with the 2300Kv motor, 5030, and a Hyp 240 pack should have no trouble hanging on the prop. Here's a checklist:
  1. Verify that the motor isn't rubbing on something.
  2. Make sure that the prop isn't slipping.
  3. Verify that your throttle travel is set to 100% & that you don't have low rates, throttle-cut, or any throttle mixes accidentally programmed.
  4. Calibrate the ESC.
  5. Verify the integrity of the motor wiring, power wiring, and the connectors.
If you've done all of the above & the problem still exists, it is either the motor or the brick.
Joel
turboparker is online now Find More Posts by turboparker
Old Nov 15, 2012, 02:40 PM
knifeedge63 is offline
Find More Posts by knifeedge63
There is Victory in the Lord!
knifeedge63's Avatar
United States, GA, Locust Grove
Joined Feb 2011
Originally Posted by turboparker View Post
gator,
as microheli noted - a cc with the 2300kv motor, 5030, and a hyp 240 pack should have no trouble hanging on the prop. Here's a checklist:
  1. verify that the motor isn't rubbing on something.
  2. make sure that the prop isn't slipping.
  3. verify that your throttle travel is set to 100% & that you don't have low rates, throttle-cut, or any throttle mixes accidentally programmed.
  4. calibrate the esc.
  5. verify the integrity of the motor wiring, power wiring, and the connectors.
if you've done all of the above & the problem still exists, it is either the motor or the brick.
Joel
+1
knifeedge63 is offline Find More Posts by knifeedge63
Old Nov 16, 2012, 06:51 PM
shastamike is online now
Find More Posts by shastamike
shastamike's Avatar
United States, CA, Mt Shasta
Joined Jun 2010
Finally got my 2300kv motor for my Beast. It seems to be about the same level of noise as the new CC's 2500kv which was surprisingly quiet. I wonder if the new 2500's need re-testing? I"m glad the new CC is so quiet. This summer when I go lake flying I don't want to upset the ambiance.
shastamike is online now Find More Posts by shastamike
Old Nov 21, 2012, 01:21 AM
Joined Aug 2012
Modified UMX Carbon Cub with Rimfire 200 2400kv Motor & 6X3 prop
Flies verry smooth with the Rimfire 200 2400kv motor with the 6X3 prop and a hyperion 450mah 2s lipo 13 to 15 minut flights. Gona try the watterfloats next time.
Modified UMX Carbon Cub with Rimfire 200 2400kv Motor & 6X3 prop (3 min 26 sec)
Old Nov 23, 2012, 07:21 AM
ScottGridley is offline
Find More Posts by ScottGridley
United States, MA, Rutland
Joined Oct 2011
Just a quick pic
My cub, fixed up and flies like new!
ScottGridley is offline Find More Posts by ScottGridley
Old Nov 24, 2012, 04:16 PM
shastamike's Avatar
Joined Jun 2010
Looking good. What's it parked on? Weird surface. What did you fix up?
I swore I was going to keep my Cub perfect, only scale flying, but today ran it into it's box and put a big right angle ding in the wing. I never leave the box out on the tarmac, but this morning the grass was wet and so the box was out and the plane went right for it.
Old Nov 25, 2012, 06:29 PM
Joined Feb 2011
new spinner
Here is the Shapeways Sbach spinner on my Carbon Cub. I painted it, but the colors dont quite match... I will fix that soon. I just love the look of this spinner on here, it favors the looks of a Husky now Next is droop wing-tips..
Old Nov 25, 2012, 06:43 PM
Joined Oct 2011
It's on a baseball field. Some kind of sandy gravel stuff...I call it scale river bank.
I'm the same way with mine, really wanted to keep it pristine. But how long could that last!?
I was wind surfing the other day, going backwards at altitude in fact. Tried a loop, but coming over the top the wind flipped her around pretty quick, I lost orientation and flew her into a tree branch. Only major damage was the prop which was toast, but it turned out the prop angle was way off causing constant climb under power. A little steam behind the firewall and all is back to normal...
New Product E-Flite UMX Carbon Cub SS fragje Micro Ready-to-Fly 13091 Today 02:15 PM
Article Horizon Hobby E-flite Albatros D.Va 32e ARF Review Michael Heer Electric Warbirds 14 May 21, 2014 11:35 AM
New Product UMX Carbon Cub SS masonjee Electric Plane Talk 10 Mar 14, 2014 01:03 PM
New Product E-flite UMX Carbon Cub SS BNF with floats! Firehawk989 Waterplanes 8 Feb 28, 2012 01:48 AM
Wanted UMX Carbon Cub SS BNF GOOBERSEPTEMBER Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 6 Feb 15, 2012 06:31 PM
