Old May 07, 2012, 11:17 AM
neddis is offline
Find More Posts by neddis
Fixed wing fanatic
neddis's Avatar
United States, OR, Hermiston
Joined Apr 2011
How far is too far back for the CG?
I recently acquired a PA Extra MX. I am working with the CG to get it just right. I have been flying it pretty far back, which allows for some pretty cool walls, spins, and tumbles, but it also causes an issue because of having so much down trim that when I flip it inverted, it will almost do a loop if I don't give elevator input. I don't have the plane in front of me, but if I remember correctly the CG is at about 5" from the leading edge. How can I determine the correct location via flying characteristics? I know some of the hardcore 3D guys use a CG that is pretty far back, but do they just live with these kind of flight characteristics in order to have that instability when they fly? Thanks guys.
neddis is offline Find More Posts by neddis
Old May 07, 2012, 11:23 AM
Doc Austin is online now
Find More Posts by Doc Austin
Team Extreme Flight
Doc Austin's Avatar
USA, FL, Largo
Joined Dec 2005
Generally, start at the front of the range that the manufacturers recommends, and then work the battery back 1/4 at a time until you are happy with it. Remember that everyone likes something a littrle different.
Generally I like the plane to dive a little when I go inverted. I trim it at full throttle upright, and then roll it over. If it stays level or climbs, that's too tail heavy for me. I like them to drop at least a little, but then again, that's just me.
Personally I have found that once I get to nuetral or further back, flying any kind of precision is nearly impossible. Not only that, but even in 3D the plane becomes more squirrely than I like. Personally, I just don't like them too tail heavy.
Doc Austin is online now Find More Posts by Doc Austin
Old May 07, 2012, 10:27 PM
Mr Kamikaze is offline
Find More Posts by Mr Kamikaze
I'm torquing to you!
Mr Kamikaze's Avatar
Wattle Grove NSW Australia
Joined Nov 2006
+1 on Docs comment for me.
Mr Kamikaze is offline Find More Posts by Mr Kamikaze
Old May 08, 2012, 01:14 AM
732002 is offline
Find More Posts by 732002
732002's Avatar
United States, OR, Lake Oswego
Joined Dec 2003
I took Scott Stoops advise in Mastering Radio Control Flight.
For precision pattern, upright I have the same amount of up elevator as
down elevator inverted.
3D, neutral upright and inverted. Like Doc said too far back and it just gets too twitchy.
732002 is offline Find More Posts by 732002
Old May 10, 2012, 03:01 PM
neddis is offline
Fixed wing fanatic
neddis's Avatar
Joined Apr 2011
Awesome. Thanks for the input guys. The Extra MX is my first REAL 3D plane so I am still trying to figure out the details in the setup stuff. I moved the CG forward a tad today and it flew better.
Discussion Parkzone T-28 , CG experimentation, how far back did you go? danford1 Parkflyers 4 Sep 01, 2011 12:37 PM
Discussion Spirit 100 (Kit) CG - How far back can it go? areid Sailplane Talk 2 Jan 01, 2009 08:31 AM
Discussion How far back should the CG really be??? flystoolow 3D Flying 2 Apr 09, 2007 06:46 PM
Question CG How far back? Kaan Thermal 46 Mar 12, 2007 04:07 PM
