Old May 07, 2012, 05:35 AM
SudorracMechEng is offline
Find More Posts by SudorracMechEng
Joined May 2012
wiggle drive propulsion
Hi, i was looking at using the wiggle drive for a surfboard application - whereby two fins could be oscillating and a system will be in place to lock the fins in initial position once desired speed is achieved.
I am a final year mechanical engineering student, I am wondering which principle is used for the following: (ill try my best to explain)
The two fins will be Vertically mounted, they will flap from left to right and the pitch will be around +- 15 degrees.
It will be running off the same idea as this video
Swashdrive™ Fin propulsion 2 (1 min 21 sec)
SudorracMechEng is offline Find More Posts by SudorracMechEng
Old May 07, 2012, 06:58 AM
jackerbes is offline
Find More Posts by jackerbes
Jack
USA, ME, Ellsworth
Joined May 2008
500W at 35A, is that at full throttle?
And is that continuous clanking noise an inherent component of the power system?
Is the motor running wet? Partially submerged?
Jack
jackerbes is offline Find More Posts by jackerbes
Discussion Kjell-Wiggle-Drive KJELL Ornithopters 12 Apr 10, 2015 12:44 AM
Discussion Looking for a belt drive or gear drive for BIG motors BL5055 or BL5065 size 8mm shaf C|aymore Power Systems 0 Apr 22, 2012 03:06 PM
Wanted wanted big jet drive or stern drive timv Boats (FS/W) 4 Apr 08, 2012 01:02 AM
Discussion Crank vs. Wiggle drive? Socalfusions Ornithopters 38 Feb 02, 2012 03:15 AM
Help! Belt Drive vs Shaft-Drive kingofking1 On-road Cars 17 Jan 20, 2012 07:52 AM
