Old May 07, 2012, 04:11 AM
mrcosmo's Avatar
Australia, VIC, Melbourne
Joined Nov 2009
Engine choice for the Flyline Fairchild 22
I have a Flyline Models Fairchild 22 waiting to be built soon.
The recommended engine is 09-15 with a flying weight of 2-3lbs. I was planing to put an Enya 09 in it but I've been wondering if I could get away with a Queen Bee 074 or preferably one of my various 061's.
I'll build it light and with lightweight radio gear I don't see why if I keep it to around 30-40oz all up (maybe less) with engine and radio that an 061 with a 7" prop would be enough for it?
- Should I wait until it's near finished and weight it up then
I don't think it needs the weight of an 09 to balance it, looking at the plans the nose is fairly long and I'll move the radio forward and keep the tail light.
What does everyone think about that?
mrcosmo is offline Find More Posts by mrcosmo
Old May 07, 2012, 10:06 AM
Canada
Joined Nov 2000
Only one I ever saw fly was fitted with a 15, it wasn't a floater model type flight.
But that was 30+ years ago and my memory can be suspect.
Bare is offline Find More Posts by Bare
Old May 08, 2012, 12:11 PM
Master of the Figure "9"
hogflyer's Avatar
Wichita, Kansas
Joined Dec 2005
If you can keep the weight to around 27 ounces or less, that Enya .09 should be fine for it. If it's going over 30 ounces, I'd consider a .15. But if you're going to be closer to 24 ounces (and no real balance issues), then possibly a Norvel .074 would be a good choice since it has close to the power of the Enya .09.
Also consider your balance. With the Enya .09 will you need to add nose weight? If so, then the .15 may be the better option. It'll give you more power with the weight, and that will be better adding lead to the short nose.
Just my 2 cents worth.
Hogflyer
hogflyer is offline Find More Posts by hogflyer
Old May 08, 2012, 01:19 PM
surfer_kris's Avatar
Sweden
Another thing to consider is the propsize. While the Norvel .074 is a great engine it doesn't like any larger than a 7x3 prop. The enya on the other hand will happily swing 7x4-8x4 props.
The Queen Bee will at best swing a 6x3-6x4 prop, and is weaker than a Norvel .061...
surfer_kris is offline Find More Posts by surfer_kris
Old May 09, 2012, 03:43 AM
mrcosmo's Avatar
Joined Nov 2009
Thanks for all the input. I've heard that the Queen Bee isn't the greatest, and it seems as though an 061 won't be enough. I think I'll wait until the build is well progressed to weigh it up - will probably go with my Enya 09, it's a great engine.
Old May 16, 2012, 06:55 PM
United States, NY, Ithaca
Joined Sep 2007
I built my Petite Parasol with an old Enya 09 III and just could not believe the power and climb it had. It was not over the top, just much better than I expected. And that was with an 8x4. It had a 42 inch span and weighed 27 oz, which I was quite proud of. The original in the magazine article weighed 33 oz with an old escapement single channel.
I would go with the Enya .09. The 8 inch prop with look better, and it's a little bigger airplane than mine was, so I think the power would be good. You might regret a small high revving engine. Plus the Enya 09 sounds so great on idle coming in for touch and goes.
Nice airplane! Jim
buzzard bait is offline Find More Posts by buzzard bait
Old May 16, 2012, 08:02 PM
What's a "Petite Parasol"?
skaliwag is online now Find More Posts by skaliwag
Old May 16, 2012, 08:56 PM
Western KY
Joined Sep 2003
Here's a pic.
andrew
Andrew0820 is offline Find More Posts by Andrew0820
Old May 16, 2012, 09:14 PM
PAW .09 diesel--Only way to go !!
LittleRock is offline Find More Posts by LittleRock
Old May 16, 2012, 09:21 PM
Cutie... any drawings available?
Old May 17, 2012, 03:22 AM
mrcosmo's Avatar
Joined Nov 2009
Thanks alot guys I now want to build the Petit Parasol damn it!
Buzzard bait, I looked up your build on the other channel, very nice indeed.
I feel like keeping the Fairchild 22 kit in the box and ordering the Petit Parasol plans instead! But it's such a classic, gotta love those Flyline kits.
Old May 20, 2012, 01:54 PM
Joined Sep 2007
Thanks Mr Cosmo, and yes, Andrew has it right. MAN still carried the plan last time I looked, not too long ago. I saved that magazine from when I bought it at a news shop in 1966, and finally built it about 40 years later. Good grief, I'd better build faster or I won't get 'em all done!
Jim
Old May 20, 2012, 05:53 PM
Western KY
Joined Sep 2003
Jim --
You did a really nice job on the struts. Those all wire setups are hard to get aligned and hold in place for soldering. I think wrapping with copper wire is the only way to go.
I really liked the blue and white scheme you used. You should post some more pics of your plane from the RCU thread.
Sold Diels Engineering and Flyline kits Hemikiller Aircraft - General - Miscellaneous (FS/W) 0 Mar 05, 2012 08:53 AM
Sold Flyline Models and Diels Engineering kits Hemikiller Aircraft - Electric - Airplanes (FS/W) 4 Feb 13, 2012 06:47 AM
Discussion Engine Choice for Current Build delamite Fuel Plane Talk 22 Oct 14, 2011 01:27 PM
1/4 scale fairchild 22 + bonus vett Aircraft - Fuel - Airplanes (FS/W) 0 Aug 31, 2003 06:30 AM
1/4 scale fairchild 22 vett Aircraft - Fuel - Airplanes (FS/W) 0 Mar 10, 2003 06:29 AM
