Old May 06, 2012, 08:47 PM
sirocelot is offline
Find More Posts by sirocelot
No plane is safe around ME!
sirocelot's Avatar
United States, WA, Fairchild AFB
Joined Apr 2012
Help!
Old HZ super cub RTF radios - evidently not so good
I've had my HZ cub for a year now, and I've loved it. I purchased it at a discount, mostly because it has the old electronics (72 MHZ I believe) with the servos linked to the receiver via a four-wire cord. It came with ye olden TX, a three channel black transmitter that *ahem* sucks. The radios were fine when I first purchased the bird, giving plenty of range to learn to fly. Over time and usage, though, (and possibly because of a small lipo fire), the radios have worn themselves down to the point to where they have an effective range of about 100 yards. If the cub flies past that point, the engine and control surfaces start acting seizuric. They both become nonresponsive for around a second, then regain control. This makes it EXTREMELY hard to control. I just had one of the worst wrecks I have ever had today because I got it too far away.
The problem has worked its way to the point where I NEED to do something about it. I have a brand new tx (spectrum dx6i), so I have been thinking about switching to spektrum electronics. This should solve the problem. Also, if I do that, then I will need help getting an ESC as I know nothing about them. Please reply, because of the problem 2 out of the 2 flights I got in today ended in a crash.
sirocelot is offline Find More Posts by sirocelot
Old May 06, 2012, 09:34 PM
HELModels is offline
Find More Posts by HELModels
HELModels's Avatar
Joined Aug 2003
This guy was looking for a brushless motor and the consensus is a 40 amp ESC with a 480 brushless and 2100 3s lipo. He's looking to carry weight like cameras. If your looking to keep your stock motor, than I dont know. What's the hobbyzone site say about the stock motor. That might give you a clue as to what brushed ESC to get.
Here's the brushless motor info:
http://www.rcgroups.com/forums/showthread.php?t=1645002
HELModels is offline Find More Posts by HELModels
Old May 07, 2012, 07:44 AM
ggcrandall1 is offline
Find More Posts by ggcrandall1
ggcrandall1's Avatar
USA, GA, Marietta
Joined Aug 2005
When you change to the DX6i and brushless motor you will have to change everything in the plane. That includes the Rx, ESC, motor, and servos.
HS-55 servos would be a good replacement. Or any other 9gm servo if you think the HS-55 is too expensive.
Lots of DX6i compatible receivers to choose from.
Glen
ggcrandall1 is offline Find More Posts by ggcrandall1
Old May 07, 2012, 12:04 PM
PittSpecial is offline
Find More Posts by PittSpecial
Right Rudder
PittSpecial's Avatar
USA, FL, Orlando
Joined Nov 2010
sirocelot,
I have seen some professional grade 27Mhz for RC Aircraft and they are rock solid. The trouble with the BLACK BOX (72Mhz version) on the Super Cub is the (Unless of course they have fixed this issue) antenna whip cord is soldered on one side of the integrated Circuit card but, not on the opposite side and it is then, allowed to twist and will eventually cause range problems and glitches.
Also, the old 72Mhz was known for Field Effect Transistor (FET) to pop out during a Propeller Strike due to high current draw and the following picture you can see the Antenna at the corner of the circuit board where it is soldered on one side and not the other allowing the wipe antenna to twist and cause a solder crack and lose contact thereby, the model losing RF communication with the Transmitter.
I would just buy the AirFrame and decor per my liking unless you see a super deal somewhere like in eBay.
Going with 2.4Giga has its learning curve issues so, take a look at lots of Video on "How-To" before you fly your model using this newer Radio gear.
Best of luck,
PittSpecial is offline Find More Posts by PittSpecial
Old May 08, 2012, 06:53 PM
sirocelot's Avatar
Joined Apr 2012
Thanks. I might just buy the airframe and piece it together from there. Thanks all.
Discussion Mikrokopter First and Second FPV vids... first Good... second... not so good :( chargenut Aerial Photography 9 Apr 22, 2012 04:39 AM
Discussion how to bind a super cub dsm rtf back to radio jpwb360 3D Flying 2 Apr 05, 2012 09:30 PM
Discussion want lights for HZ super cub lp dsm rtf. skarface Parkflyers 7 Oct 06, 2011 11:14 AM
Discussion HZ Super Cub LP not uncrashable and indistrutable happydog500 Foamies (Kits) 0 Oct 07, 2009 04:47 PM
Discussion Maiden HZ Super Cub flight in perfect So Cal sunset! finchkid24 Beginner Training Area (Aircraft-Electric) 12 Feb 10, 2008 06:08 PM
