Old May 06, 2012, 01:57 PM
iCrap is offline
Find More Posts by iCrap
iCrap's Avatar
United States, MD
Joined May 2012
KK 5.5 Board won't arm?
Im trying to fly my new quadcopter, but i can't get my board to arm. Im using a Spektrum DX7 and the regular spektrum receiver... the quad just beeps and the rotors twitch a tiny bit (i assume that means its ready) but the blue arm LED isn't on and i cant throttle up. I aleady tried holding the stick on the bottom right.
Any ideas?
iCrap is offline Find More Posts by iCrap
Old May 06, 2012, 02:48 PM
iCrap is offline
iCrap's Avatar
United States, MD
Joined May 2012
I got the blue light to flash now by only plugging in the throttle and rudder only... why is this? and what does the blue flash mean? I can't find any info on this anywere.
Old May 06, 2012, 03:29 PM
N_O_V8_R is offline
Find More Posts by N_O_V8_R
USA, NE, Waverly
Joined Feb 2011
Make sure all three trim pots are set to 50%
Plug in battery
Move throttle stick to lower right corner and hold for 5 sec.
If this didn't work, try the lower left corner.
If neither worked try lowering your throttle trim, all the way if needed, but usually only required several clicks.
If you are using Futaba, you will have to rev. throttle, Spektrum/Jr = normal.
Hope that helps!
N_O_V8_R is offline Find More Posts by N_O_V8_R
Old May 06, 2012, 03:49 PM
iCrap is offline
iCrap's Avatar
United States, MD
Joined May 2012
Ok, now when i turn it on, and ptu the stick to the lower left corner it turns solid blue (the kk board) and i get rapid beeps. Pots are 50%, alieron, elevon channels are set to reverse.... so at least its doing somethig else now.
My reciever is Spektrum DX7 btw.
Old May 06, 2012, 04:05 PM
sirbow2 is offline
Find More Posts by sirbow2
Emress
Joined Nov 2011
if its normally armed in lower right, and you arm it in lower left, your Yaw channel is reversed.
"so at least its doing somethig else now."
something else wrong?
sirbow2 is offline Find More Posts by sirbow2
Old May 06, 2012, 04:11 PM
iCrap is offline
iCrap's Avatar
United States, MD
Joined May 2012
How do i reverse the yaw channel?
Well before it would just flash blue once and no matter what i did with the stick nothing would happen, now i get rapid beeps when i put the stick to the bottom left. The motors still won't move though.
Old May 06, 2012, 04:14 PM
sirbow2 is offline
Emress
Joined Nov 2011
http://rcexplorer.se/page14/kkguide/kkguide/quad.html
Old May 06, 2012, 04:30 PM
iCrap is offline
iCrap's Avatar
United States, MD
Joined May 2012
ive read that page but it dosen't say what to do if the board dosent arm and it dosent explain the very rapid beeps.
Old May 06, 2012, 06:34 PM
vcazan is offline
Find More Posts by vcazan
vcazan's Avatar
Canada, ON, Markham
Joined Apr 2012
Yes it does if you read it:
1. Check if the throttle stick
This is to ensure that the throttle stick is moving the right direction and have enough trow to initialize the flight-controller.
Never perform this step with the props mounted!
- Turn on the transmitter and then the flight-controller
- Move the throttle/rudder stick to the down-right corner
- The LED should turn on, if it doesn’t:
- Try adding a bit of “down” trim on the throttle channel
- Try increasing the EPA on the throttle channel
- Try reversing the throttle channel
vcazan is offline Find More Posts by vcazan
Old May 06, 2012, 06:37 PM
iCrap is offline
iCrap's Avatar
United States, MD
Joined May 2012
I've tried changing the trim and reversing the throttle channel. What is EPA?
But still, that page dosen't explain the rapid beeping. I will upload a video to show what i mean.
Old May 06, 2012, 06:39 PM
sirbow2 is offline
Emress
Joined Nov 2011
end point adjustment on tx
why i love MWC: it has a gui that you can see live TX values in setup! makes it so much easier to configure..
Old May 06, 2012, 06:41 PM
2400RDR is online now
Find More Posts by 2400RDR
Out of helis, sanity returning
United States, FL, Lake City
Joined Feb 2009
Have you calibrated the end-points on your ESCs?
2400RDR is online now Find More Posts by 2400RDR
Old May 06, 2012, 06:42 PM
vcazan is offline
vcazan's Avatar
Canada, ON, Markham
Joined Apr 2012
Go to servo setup, throttle, travel and set the points to 105% 105% and try arming again
Also check this and make sure you reverse the right channels:
Setting transmitter channels
Aileron Elevator Throttle Rudder
REVERSE REVERSE NORMAL REVERSE
Old May 06, 2012, 06:51 PM
iCrap is offline
iCrap's Avatar
United States, MD
Joined May 2012
I quickly recorded a video showing what i am talking about:
http://www.youtube.com/watch?v=PH6zZ...ature=youtu.be
Old May 06, 2012, 06:57 PM
iCrap is offline
iCrap's Avatar
United States, MD
Joined May 2012
I did something i read where i put the yaw pot to 0 and turned the tx on with throttle full, then down, then it beeped then turned everything off and set pots to 50%. Is taht what your talking about?
Just tried that, same results.
Help! X-525 Kit, KK Controller 5.5 Won't Arm *SOLVED* MrKite Multirotor Talk 9 Nov 10, 2012 01:33 PM
Help! KK Board won't arm - Tried everything! flyandi Multirotor Talk 30 May 05, 2012 04:15 PM
Help! Kk 5.5 won't initialize Garrett1234567 Multirotor Talk 0 Mar 31, 2012 12:54 AM
Discussion KK board won't power up. HELP!!! BOILER1 Multirotor Talk 26 Mar 15, 2012 02:13 PM
Sold KK 5.5 clone board, blowout!!! Have 20 boards that need to go!!! tc3wins Aircraft - Electric - Multirotor (FS/W) 20 Jan 27, 2012 02:38 PM
