Old May 06, 2012, 06:03 AM
vengeance111 is offline
Find More Posts by vengeance111
vengeance111's Avatar
United Kingdom, England, Tedburn St Mary
Joined Apr 2012
Help!
Tail rotor not spinning
Hi everyone my honey bees tail rotor has randomly stopped working, I don't think its the 4 in 1 as ive tried connecting the tail rotor to the main rotor output and it doesnt work
Am i going to have to replace the tail rotor and how do I go about doing this ?
vengeance111 is offline Find More Posts by vengeance111
Old May 06, 2012, 08:09 AM
rangamatchstic is offline
Find More Posts by rangamatchstic
Mt helena western australia
Joined May 2009
test with multimeter for voltage across the wires to check
rangamatchstic is offline Find More Posts by rangamatchstic
Old May 06, 2012, 08:34 AM
wlee1017 is offline
Find More Posts by wlee1017
wlee1017's Avatar
Joined Jul 2011
how many flight you have and do you ever replace main motor and tail motor. May be it's timer to replace worn out brush motor
wlee1017 is offline Find More Posts by wlee1017
Old May 06, 2012, 09:43 AM
Joined Apr 2012
Bought it used and it had a xtreme tailmotor installed
Old May 06, 2012, 09:52 PM
Joined May 2009
probably a burn out, just test it as i decribed and if there is a voltage held across the wires then you have a burnt out motor
Old May 07, 2012, 06:31 AM
Joined Apr 2012
I fixed it, on one of the 2 little orange blobs at the top of the motor, one of them had cracked slightly and you could see the metal inside so I covered it with blu tac works fine now
what are these orange things ?
Old May 07, 2012, 09:02 AM
Joined May 2009
there non polarized capacitors, they smooth out the motor abit and the blue tac........i actualy cant beleive they work =O sounds very odd, but if the blutac doesnt hold up, get the code off the capacitor, go and buy one (they are only 10cents) and solder it on, its non polarized so it wont blow up if you put it on the wrong way.
Old May 07, 2012, 10:38 AM
Joined Apr 2012
If you just straight on solder the wires to the motor will it effect much ?
Old May 07, 2012, 11:47 AM
wlee1017 is offline
wlee1017's Avatar
Joined Jul 2011
I suggest no. Those capacitor are noise suppression capacitor, used to suppress the high frequency noise (electrical noise) from rotation of brush motor. Without noise supression capacitor, high frequency noise will cause interference.
Here you will find more about noise suppression capacitor, though article not for rc brush motor but the principle is the same,
http://www.okaya.com/images/noise/1100.pdf
Same question, I wonder how crack on capcitor caused tail motor malfunction. your capacitor is not burnt, puffed or burst.. Unless the crack capacitor exposed metal parts and in touch with motor case... ..
Old May 07, 2012, 11:55 AM
Joined Apr 2012
Beats me ?
Old May 07, 2012, 12:04 PM
wlee1017 is offline
wlee1017's Avatar
Joined Jul 2011
Beats me ?
just want to know if capcitor burst already before or exposed metal parts short to motor case.
Old May 07, 2012, 12:40 PM
Joined Apr 2012
I was just mid flight and it started spinning crazy,probably broken before just didnt notice
Old May 08, 2012, 05:41 AM
Joined May 2009
maybe the capacitor was losing charge to the air? sounds far fetched but possible, causing the tail to go crazy.
Old May 08, 2012, 12:38 PM
Joined Apr 2012
the motor it self didnt go crazy just didnt work at all, but it cut out mid flight spinning the thing round loads
Help! Top Rotor Not Spinning Properly Dusty88 Coaxial Helicopters 9 Aug 21, 2013 08:10 PM
Discussion Venom Ozone Elite tail rotor only spins forward behrensmr Electric Heli Talk 0 Apr 07, 2012 12:01 AM
Discussion Art Tech Miniwolf SE Bottom Rotor Not Spinning, Help Appreciated. TSXChef Coaxial Helicopters 0 Oct 21, 2011 05:24 PM
Discussion Motor driven tail rotor spin the same as belt driven tail? BowerR64 Micro Helis 4 Mar 17, 2008 11:53 PM
My Tail rotor won't spin, how to mix? Help jasoncy2k Micro Helis 1 Aug 17, 2005 03:18 PM
