Old May 05, 2012, 10:15 PM
Riodiler1 is offline
Find More Posts by Riodiler1
United States, CA, Livermore
Joined Jan 2005
Question about aileron rudder mix function
This is my first time trying to use aileron and rudder mixed with my radio. I used the mix function on my Spektrum DX7s radio and the resulting control surface directions are as follows:
I move the aileron stick to the right and the right aileron moves up and the rudder moves slightly to the left. Are these the correct directions for mixing these two functions? My initial thought would be that the rudder would need to move right when giving right aileron but I wasn't sure.
Riodiler1 is offline Find More Posts by Riodiler1
Old May 05, 2012, 10:28 PM
aero550 is offline
Find More Posts by aero550
United States, OH, Tipp City
Joined Oct 2011
You want the rudder to move to the right in this case. You want the rudder to move towards the same direction as the bank you are inputting. Right bank, right rudder. Left bank, left rudder.
Two things can cause the results you are getting:
1. Your rudder servo is operating in the wrong direction to start with. What does it do when you move the rudder stick to the right? does the rudder move to the right? If not, then that servo needs to be reversed in the transmitter. Then your mix will work the way you intended it to.
If that is operating correctly, then:
2. You are using a negative percentage for your mix. If you crank the percentage up to a positive number, your mix will work the way you intended. (or vice versa. Sometimes, the negative/positive doesn't necessarily mean anything, you just need to roll the scroll button one direction or the other to get the desired results).
Hopefully that all makes sense...ask again if it is still confusing.
aero550 is offline Find More Posts by aero550
Old May 06, 2012, 02:33 AM
Threshold is offline
Find More Posts by Threshold
Threshold's Avatar
London UK
Joined Jul 2004
why do you want to do this?
Threshold is offline Find More Posts by Threshold
Old May 06, 2012, 08:58 AM
ChrisBowker is offline
Find More Posts by ChrisBowker
RC Bum 4 Hire
ChrisBowker's Avatar
United States, NM, Albuquerque
Joined May 2004
+1
IMO, mixes of this kind should be used to correct a control coupling issue like in KE flight. EG: if the plane rolls in or out of KE when rudder is applied a mix from rudder to ailerons can be used to correct this.
If you are thinking about using a mix to "help your model turn faster" by mixing in a "coordinated turn" then its probably a BAD idea...Doing this creates a crutch that will keep you from becoming a better pilot, Its an old rumor that this is hard and or takes years of practice to learn... typically spread by pilots that don't want you to be better than them.
Is there another reason you want to use this mix on your model?
PS. depending on which direction you set the mix up + or - will determine the direction of the rudder or slave channels movement.
ChrisBowker is offline Find More Posts by ChrisBowker
Old May 06, 2012, 09:21 AM
E-Challenged is online now
Find More Posts by E-Challenged
E-Challenged's Avatar
United States, CA, Garden Grove
Joined Oct 2000
I use rudder/ileron mix most of the time for relaxed flying of high wing scale models. I can switch it off or override it (give extra rudder throw) when needed or desired. Aileron/rudder mix counters "adverse yaw" where the down-going aileron makes drag on that wing which fights turning in the desired direction. It is good to practice manual coordination of rudder and ailerons for use in aerobatic maneuvers or general flying. Use of "differential ailerons", where ailerons go up a lot and down very little is another way to counter adverse yaw and make turns easier and smoother. Differential ailerons requires two aileron servos connected to two channels and programmed mixing. Aileron/rudder mix is a nice feature to have available if you want to use it . Comes in handy for landings and takeoffs as well as graceful turning with aileron-equpped planes. Ercoupes used coupled ailerons and rudder for easier and safer flying. Tricycle landing gears are a real "crutch". GPS is another crutch. Electric starters on cars and motorcycles were called "crutches"
E-Challenged is online now Find More Posts by E-Challenged
Old May 06, 2012, 10:46 AM
aero550 is offline
Joined Oct 2011
The OP's question was about whether his mix function was working or set up properly, not about whether he should be "allowed" to use it or not. That would be a debate for another thread.
I could see using this mix to get a nice scale model around the circuit in a safe, secure, easy manner. On the other hand, this mix would corrupt the handling of a full-on aerobat. It all depends on what you are trying to accomplish, and that is totally up to Riodiler.
That is why this hobby is great and cursed at the same time. We have the freedom to do it the way we want...but tend to have a lot of people telling us why we are doing it wrong.
Old May 06, 2012, 10:51 AM
scottieusa is offline
Find More Posts by scottieusa
scottieusa's Avatar
United States, OR, Albany
Joined Oct 2011
Sooooooooo true
scottieusa is offline Find More Posts by scottieusa
Old May 06, 2012, 09:29 PM
GooberSB is offline
Find More Posts by GooberSB
An Ordinary User
United States, VA, Fluvanna
Joined Jan 2011
I've never noticed a need for mixing rudder in with ailerons. But I have considered mixing opposite aileron with rudder to prevent the inside wing from lowering during turns. For now I do it manually after the turn is complete. I'd like to be able to do it during the turn but I always give too much...
GooberSB is offline Find More Posts by GooberSB
Old May 06, 2012, 11:38 PM
Joined Oct 2000
High wing models definitely need rudder input along with aileron deflection, either manually applied or using aileron/rudder mix. Low wing models i.e warbirds and sport models, generally turn well with aileron and elevator inputs, rudder inputs are optional. During landings, ailerons become ineffective at low airspeeds but rudder remains effective for keeping wings level.
Old May 07, 2012, 12:32 AM
zeezee is offline
Find More Posts by zeezee
Yea, I fly dusty planes..
zeezee's Avatar
United States, LA, Angie
Joined Apr 2009
My SE5a needed rudder input along with ailerons to turn correctly and I'm glad I have a computer radio to help me. Without it it seemed like the tail wanted to drop and fall out of the sky. I use whatever helps me have a good experience. I like having a gyro on the rudder of my H9/P-51. I use it for takeoffs, gear up and gyro goes off.
zeezee is offline Find More Posts by zeezee
Old May 08, 2012, 01:36 AM
Threshold's Avatar
London UK
Joined Jul 2004
Well the OP was clearly confused about this asking about the direction of the rudder deflection so before going into long winded discussions about the idea I thought it wise to ask him why he wanted to do it? It seems it was just on a whim as he has not bothered to look at the thread again instead leaving us all to argue about the merits of the idea.
Old May 08, 2012, 05:35 AM
rcmaverick is offline
Find More Posts by rcmaverick
rcmaverick's Avatar
Australia, NSW, Sydney
Joined Mar 2012
Rudder Aileron Mix
I have a 3 channel easystar and feel more comfortable using the aileron control for rudder. On 4 Channel I use the Ailerons most of the time so i dont need to rewire my brain.
rcmaverick is offline Find More Posts by rcmaverick
Old May 09, 2012, 06:53 AM
Threshold's Avatar
London UK
Joined Jul 2004
Yes but I was asking the OP. There are many reasons for coupling aileron to rudder. By finding out what he was after a better answer could be given even if it meant it was not a good idea for him in his case.
Discussion Noobie question about using rudder and ailerons together Riodiler1 Foamies (Kits) 0 Apr 29, 2012 02:56 PM
Discussion Question on Aileron to Rudder Mix Bohh33 Hand Launch 10 Jun 25, 2008 11:31 PM
Discussion Newbie Aileron-Rudder Mix Question Flying Pez Electric Warbirds 0 Dec 28, 2007 01:11 PM
Futaba Super 8 aileron/rudder mix question Danny Troy Radios 0 Nov 10, 2005 01:10 PM
Flash 5X Rudder/Aileron Mix question MAKODS Hitec/Multiplex USA 3 Aug 24, 2003 05:11 PM
