Old May 05, 2012, 09:50 PM
Evan03 is offline
Find More Posts by Evan03
Mtn Home, Idaho
Joined Feb 2010
tower 46 on the bench
i feel im rich on the low speed but its running ppretty good. its running a power box muffer with baffle removed.
i havent flown the wood prop or muffler since removing the baffle
http://www.youtube.com/watch?v=B96vNu_LW_c
Evan03 is offline Find More Posts by Evan03
Old May 07, 2012, 05:56 PM
jjkupinski is offline
Find More Posts by jjkupinski
TigreJohn
United States, CA, Corona
Joined Aug 2008
Have a little patience. Your activating the throttle too quickly (time span wise). Let the engine idle for 30 to 45 seconds. If your right, the crankcase will load up with it excess fuel. Then hammer the carb to full throttle. If the motor hesitates initially in acceleration, your right.
jjkupinski is offline Find More Posts by jjkupinski
Old May 07, 2012, 10:25 PM
GeetarJoe is offline
Find More Posts by GeetarJoe
Who Dat!
GeetarJoe's Avatar
United States, LA, New Orleans
Joined Sep 2011
low speed needle is too lean. dont try to squeeze every drop of RPM out of the engine. see how the engine hangs a bit when you cut down to idle after running wide open? youre running too lean.
GeetarJoe is offline Find More Posts by GeetarJoe
Old May 07, 2012, 10:56 PM
Evan03 is offline
Mtn Home, Idaho
Joined Feb 2010
Thanks for the tips.
I'm not after performance just want it to idle.
Ill try your Guy's advice
Old May 07, 2012, 10:58 PM
furballll is offline
Find More Posts by furballll
lost in the addiction of flyin
furballll's Avatar
Canada, BC, Kelowna
Joined Dec 2009
definitly looks lean to me too, i am also wondering why you took the baffle out of the muffler. its there by design and the bit of back pressure it provides to pressure your tank more is worth alot more than the mayby 500rpm and 10Db of noise it cuts out is worth alot more to the neighbors of your field.
furballll is offline Find More Posts by furballll
Old May 08, 2012, 08:22 AM
Evan03 is offline
Mtn Home, Idaho
Joined Feb 2010
i reinstalled bafle and it hasnt helped low end tuning you are correct it mae plenty of power with the baffle and i couldnt see any increase with it off.
just the need to tinker made me do it
Discussion tower .46 prop suggestions on escapade Evan03 Fuel Plane Talk 37 Apr 24, 2012 10:43 PM
Found Tower hobbies .46 muffler PMAXX Aircraft - Fuel - Engines and Accessories (FS/W) 3 Apr 13, 2012 05:50 PM
For Sale Tower Hobbies .46 R/C ABC engine IMaflyer Aircraft - Fuel - Engines and Accessories (FS/W) 0 Mar 31, 2012 01:43 AM
Sold NIB Tower Kaos and Used TT Pro 46 Engine - LPU mt_100 Aircraft - Fuel - Airplanes (FS/W) 2 Mar 23, 2012 08:12 AM
Sold Tower Hobbies PRO .46 :: A Pair of 'em! N925WB Aircraft - Fuel - Engines and Accessories (FS/W) 3 Mar 16, 2012 02:45 PM
