Old May 05, 2012, 07:42 PM
wowhobbies is offline
Find More Posts by wowhobbies
Joined Jan 2009
Turbo Ace X88 octocopter oktokopter official site
Turbo Ace X88-J Octocopter RTF w/ Devo 7: CNC Aluminum/Carbon Fiber I-Beam, DJI WK-M, GPS/Carefree Modes, BL Motors, 8x 35A ESCs, $2995.95 RTF. Preorder Now at www.WowHobbies.com ETA 5/28.
SINGLE FLIGHT CONTROLLER TURBO ACE X88-J OCTOCOPTER
Pay 10% deposit now and the remaining balance to be paid when the Turbo Ace X88-J is ready to be shipped. California shipping location is required to pay sales tax on deposit as it is a partial payment of the purchase.
TURBO ACE X88-J comes in a RTF (ready to fly) package. To reducing shipping size and prevent damage, propellers and landing skids are dismounted after individual flight test and prior to shipping. End user can easily re-install them in about 15 minutes.
See Video
Aerial Video San Francisco with Octocopter (3 min 18 sec)
A day in the Life of Paul Mudd Photoflight Productions (2 min 58 sec)
Turbo Ace X88 Octocopter - Largest drone commercially available in April 2012 (3 min 10 sec)
GPS Demo Video
Turbo Ace X88-J Octocopter GPS Demo (4 min 38 sec)
Camera mount auto stabilization (Included with X88-JS and X88-JSD, optional for X88-J)
X88 Camera Auto-Stabilization Demo (3 min 13 sec)
X88-J FEATURES
* Super Rigid Expanded Carbon Stacked Structure is extraordinarily lighter and stronger than all current designs based on sandwiched booms and plastic molds. At 4.8 pounds without the battery, X88's super structure features (1) an expanding CNC aluminum reinforced carbon fiber stacked central main frame anchored by 4 sets of radiating carbon fiber arms that will not sag and bounce under heavier payloads (2) optimized boom distance with lighter square aluminum tubing with anti-twist mounts that extend out to the motors significantly reducing weight around the parameters for excellent maneuverability (3) spacing within each carbon fiber arm provides propeller cooled ESC locations (4) sturdy CNC mounting locations at the end of each arm facilitate an extra wide landing skid (5) foldable joints for portability, traveling and shipping.
* Care Free Home Lock Flight Mode utilizes the octocopter's take off home position as a reference point for orientation/heading. The pilot no longer needs to maintain a tail-in (tail towards the pilot) orientation to keep track of the octocopter's heading. Pushing the cyclic stick up will always result in the helicopter flying forward and away from the pilot. Pulling the cyclic stick down will result in the octocopter backing up towards the pilot which in turn provides a very reliable "come home" solution. Similarly the roll (left & right) controls will correspond to the pilots home position without any mental acrobatics. Although the pilot can still use yaw to turn or spin the octocopter, it will not affect the pilot's flight orientation from the home position. After activation, this Home Lock mode will be effective when the octocopter is beyond 30 feet from the take off position. Home Lock mode is the most convenient and preferred mode for pilots who like to fly facing the octocopter.
* Care Free Course Lock Flight Mode utilizes the octocopter's initial take off heading direction as a reference direction for the duration of the flight. For example if the octocopter and the pilot's transmitter is facing north in the take off position, the octocopter will always treat the north as the direction (heading) for forward flight even if the yaw has rotated the front of the octocopter to a different direction. After activation this Course Lock mode will be effective when the octocopter is beyond 30 feet from the take off position. The best way to use the Course Lock mode is to keep the transmitter facing the initial take off heading direction during the entire flight even if this means the pilot has to turn his head to see the octocopter.
* GPS Lock enables the X88-J to lock into a self sustaining hover at a fixed GPS location with a flip of a switch on the transmitter. Even when the octocopter is pulled away from its locked location, it will return to that original location. This a very useful and precise locking function that operates within a few feet (about 1 foot vertical and up to 6 feet radius) depending on the quality of GPS satellite signals and the flying environment.
* Dual Stage Fail Safe Mode offers a backup plan when the octocopter receiver looses connection with the transmitter. When this occurs, the octocopter will automatically return to the point above the home GPS position. Hovering at about 60 feet, the pilot may be able to re-established connection and manually land the octocopter. If connection is not re-established, then the octocopter will automatically lands in fail safe mode. Also, if the octocopter battery is low, it will start an auto landing sequence before it runs out of power.
* Dynamically Balanced Brushless Motors reduces high frequency vibrations at the source. This can only be accomplished at our motor factory using a specialized motor balancer to spin up each individual motors to its operating RPM range. Similar to balancing tires, tiny weights are positioned along the edges of the rotating motor drum to achieve smooth rotations.
* 35A ESCs with Cooling Algorithm offers extra capacity for continued operation without a fan or cooling-off periods between flights.
* 7° Inclined Arms for exceptionally fast and agile maneuverability with minimum tilt or roll.
* Foldable Arm Joints for safer transportation and traveling.
* Anti-static Design prevents video signal interference and catastrophic electronic damage. Although carbon fiber is an excellent choice for many structural solutions, it's the #1 cause of static electricity under spinning propellers. For a safer design without interference, X88's carbon fiber central main frame seamlessly transitions to square aluminum booms under the propellers.
* Professional Aluminum Carrying Case is customized to ship the X88-J octocopter with the arms folded up without any gimbal or camera attached. However, after you have installed a gimbal/camera on the bottom of the octocopter, you can use the aluminum case to carry the octocopter with the arms folded down around the gimbal/camera.
* Modularized Design for ease of maintenance and repair. With strategically placed connectors and brackets, all individual components on the X88 can be easily disconnected or removed.
* USA Parts Support for fast and easy continued access to parts, upgrades and accessories.
* Optional Telemetry for transmitting updated battery voltage and temperature on board readings to the transmitter (for DEVO 8S/10/12S only)
* Optional 2 or 3-axis Camera Mounts for a variety of cameras and camcorders.
* Optional Automated Gyro Compensation for the camera mount: Requires a secondary Xaircraft flight controller and 3-axis gyro.
* Optional Dual Pilot with secondary receiver and transmitter for the camera man.
* Optional single way point and multiple way point GPS with PC connections can be purchased separately.
OPERATING PARAMETERS
* Total Weight: Without battery, camera mount and camera is only 4.8 pounds for super responsive performance.
* Payload Capacity: Up to 3.2 pounds of camera gimbal and camera.
* Flight Time: 15-30 minutes depending on the battery size, the weight of the camera gimbal and camera.
PRIMARY FLIGHT CONTROLLER, 3-AXIS GYRO AND GPS SPECIFICATION
DJI WooKong-M controller with 3-Axis gyro
Multi Rotor Types: Quad-Rotor / Hex-Rotor / Octo-Rotor
Supported ESC output: 400Hz refresh frequencies
Recommended Power Supply: DC 4.8 ~ 12V
Power Consumption: MAX 5W (0.9A@5V, 0.7A@5.8V,0.5A@7.4V,0.4A@8V)
Operating Temperature: -5°C to +60°C (You have to keep the IMU warm if you want to use it under low temperature, could be -5°Cor lower.)
Flight Modes: GPS Lock & 2 Care Free Flight Modes
Hovering Accuracy: Vertical: ± 0.5m, Horizontal: ± 2m
Suitable Wind Condition: < 8m/s (17.7mph)
Max Rotate Angle: 35°
Vertical Speed: 6m/s
Packaging & Shapes
Dimensions:
Main Controller: 51mm x 39.6mm x 15.8mm
IMU: 40mm x 31mm x 26mm
GPS & Compass: 50mm (diameter) x 9mm
LED Indicator: 25mm x 25mm x 7mm
Total Weight: <= 150g
Built In Functions:
Auto-pilot
Fail-safe Hover
Voltage monitor (not telemetry)
FRAME SPECIFICATION
* Expanded carbon fiber stacked central main frame and arms
* Carbon fiber skid landing with extra wide foot print suitable for auto landing
* Square anti-twist mounted aluminum booms reduce static interference to video and prevent electronic damage
* Extensive CNC aluminum bracket integration for extra durability and structural integrity.
* Customized central hub for outstanding protection and ventilation.
* Fitted with 10" propellers.
* Optional 12" carbon fiber propellers will be available soon.
* Extended wingspan diameter of 90cm from motor to motor on opposing sides
* Foldable arms for easy transportation and traveling
* Weight with all electronics (without battery and camera mount): 4.8 pounds
* Professional Aluminum Carrying Case for easy traveling. Dimensions: 42cm X 42cm X 46cm
ELECTRONIC COMPONENTS
* 8 x 35A ESC 4s input with 2mm spring-loaded motor connectors for ease of maintenance
* 8 x Dynamically Balanced Brushless Motors to reduce high frequency vibrations
* 4 GB USB Flash Drive for set up, upgrade and electronic manual
* Walkera Devo 7 Transmitter with 7 channels
* Walkera RX802 Receiver with 8 channels
DEVO 7 SPECIFICATIONS
1). Encoder: ARM micro computer system
2). Frequency: 2.4Ghz(DSSS)
3). Output power:-5dBm~20dBm
4). Battery: 1.2VX8 NiCard or1.5VX8 AA dry batteries
5). Current Drain: ≤170mA
DEVO 7 FEATURES
1). Quad-bearing design: Improved quad-bearing design of the Radio sticks makes the control silky smooth.
2). Adopts core DEVO 12 technology: Versatile functions and high performance .
3). 2 Model Type: Compatible with helicopters and airplanes. Improved programming with more mixes and better interface Program MIX ,MIX to Throttle. Long range.
4). 7-point throttle curve: For outstanding feel, control and reliability.
5). 15 (Fifteen) programmable model memory.
6). Online updatable software: Enjoying the versatility keeping your transmitter updated and the convenience of copying model data online.
For optional upgrade rechargeable Lipo battery for this transmitter go to
http://www.wowhobbies.com/transmitte...5cbattery.aspx
PACKAGE INCLUDES FULLY ASSEMBLED X88-J OCTOCOPTER WITH THE FOLLOWING FEATURES
* DJI Flight Controller for octocopter operation
* DJI IMU 3-Axis Gyro for octocopter operation
* DJI GPS with GPS Lock & 2 Care Free Flight Modes
* Walkera Devo 7 Transmitter (Devo 10 and 12s transmitter on photo are not included.)
* 8 x 35A ESCs
* 5,300mAh 4s Lipo Battery
* 4 GB USB Flash Drive containing test flight video with serial number of the Octocopter ordered and
instruction manual
* Foldable X88-J Octocopter Carbon Frame
* Carbon Fiber Super Wide Skid Landing (dismounted for shipping)
* 8 x 10" Propellers (dismounted for shipping)
* DSLR 3-Axis camera mount is not included.
* Preorder promotion does not apply to this model.
For optional upgrade camera mount and camera mount auto compensation module go to
http://www.wowhobbies.com/cameramoun...tallation.aspx
Please stay on the topic X88 octocopter. Wow Hobbies has been aggressive pursuing the best deals for our customers and as a result we have created many jealous competitors, shielding or highjacking our threads. Please note that any such violation will be reported to RC Group mediator. This thread is created to support and better inform about the X88, not for you to mention and sell your product which you should post in your own product thread. There are about 5-7 guys who have been posting negative comments under different names and they go through all Wow Hobbies threads to discredit us. Often these are the people who are on the edge and will discredit you if you come to the defense, please ignore them and report to the mediator. Don't believe everything you read and make your own judgement. Thanks for your cooperation in making this a friendly and inform thread.
Jonathan
www.WowHobbies.com
wowhobbies is offline Find More Posts by wowhobbies
Old May 05, 2012, 07:51 PM
Joined Jan 2009
The X88-J has 8 rotors so it has the redundancy to protect your invetment. We have tried to fly with 7 rotors and landed safely each time.
Here are some reference pointers about octocopter verses hexa and quads for video footage. These are the reasons owning an Octocopter instead of a Hexacopter or quadrocopter.
Octocopter is are more stable and very easy to train.
Octocopter can lift much more weight, the X88-J2 can easily lift the 6 pound payload such as Mark iii with lens plus a 2.5 pound gimbal.
Octocopter has redundant rotors, so if one goes out, your equipment won't tumble down and be damaged.
Octocopter, particularly the X88-J2 is intelligent, it flies hands off and will be able to come home if it loses transmission.
Octocopter is more predictable and safer than quad and hexa due to its redundant rotors.
Octocopter will fly under heavier windy condition
Octocopter will produce more stable video
Octocopter is easier to do FPV due to more stability
Jonathan
www.WowHobbies.com
Old May 05, 2012, 09:41 PM
BenHayat is offline
Find More Posts by BenHayat
Always Excel >>>
BenHayat's Avatar
United States
Joined Mar 2012
Jon, the third video cannot be seen, because it's rated private.
BenHayat is offline Find More Posts by BenHayat
Old May 06, 2012, 12:48 AM
Joined Jan 2009
It has been fixed. Thanks,
Jonathan
www.WowHobbies.com
Old May 06, 2012, 01:00 AM
BenHayat is offline
Always Excel >>>
BenHayat's Avatar
United States
Joined Mar 2012
Jonathan
www.WowHobbies.com
Nice flight.
Can you also provide a video of the bird with no camera and gimbal (just LG) and fly it acrobatically to show how the octo behaves in that flight pattern rather than in hover mode mostly?
BTW, in that last video, are you using 12" props or still 10"? And what's the size of motor and KV?
Old May 08, 2012, 01:42 PM
Joined Jan 2009
Nice flight.
The demo is done with 10 inch prop. 12 inch carbon blades are available as an option. For the X88-JS model, 14 inch carbon blades are optional. Flight pattern is same as Mikrokopter. I will see if we can squeeze time out for this video. There is no difference on the stability between the advanced models.
Jonathan
www.WowHobbies.com
Old May 28, 2012, 03:21 PM
Joined Jan 2009
Turbo Ace dream team presents our first film. The film was shot with our X88 octocopter, X830 quadrocopter with Canon 5D Mark iii, M52 and GoPro. It was completed in only 3 days with little sleep, goes to show that how our team is all about passion and no fear, ha ha. This is our first film as we are completely new to script writing, directing, 5D Mark iii camera, recruiting and video editing which we have to learn all of them in one week, so if itn't to your dream, wait for the next round. We only knew how to fly before.
Turbo Ace X88 Octocopter and X830 aerial film with Canon 5D Mark iii M52 Sony Nex 5N GoPro hero2 (2 min 46 sec)
A surprise prize awaits for the second place winner in end of the video, to be continued!
Jonathan
www.WowHobbies.com
Old Jun 24, 2012, 09:10 PM
Joined Jan 2009
New footage from Turbo Ace X88-J
Our field team just got back from Europe with some new footage.
Turbo Ace X88 octocopter with Canon 5D Mark ii presents aerial view of Leeds Castle (1 min 38 sec)
Turbo Ace sales and support
714-938-0189
Jonathan
www.WowHobbies.com
Old Jun 27, 2012, 12:37 AM
filthBOX is offline
Find More Posts by filthBOX
Crash Dummy
United States, CA, South Lake Tahoe
Joined Mar 2009
Are there any videos from the stabilized gimbal, for the duration of the flight, to demonstrate the stability? are the videos from the dream team shot with the auto-stable? they feel rather jittery. perhaps it's the pilot? (teasing...) : p
i am looking to buy a hex or octo for av, in high elevation (6-10k ft). has anyone (I can only find walkera sponsored threads/videos) purchased or flown one of these in a professional sense? what are your observations? the video with the castle at leeds (i think) looked like vibrations were reaching the camera, and possibly like it was underpowered (or heavy...). does the x88-jsd with 14in props handle the load a little more smoothly?
thanks
filthBOX is offline Find More Posts by filthBOX
Old Jul 15, 2012, 09:14 PM
Joined Jan 2009
thanks
Here is another video, we static balanced the blades before we traveled from London to Rome so the video came out better. The X88 had the modified plastic blades because at the time we did not have the custom carbon blades in Europe. 14 pounds was a lot of weight for 8 plastic blades and they did quite well under the circumstance. The motors are dynamically balanced and if the blades are carbon and balanced, it will be the best setup up possible for the video. All eight motors came back quite cool so these motors are over powered, not under.
Turbo Ace X88-J2 Octocopter & Canon 5D Mark ii aerial tour of Palatine Hill and Colosseum, Italy (1 min 46 sec)
Jon
www.WowHobbies.com
Old Aug 26, 2012, 02:04 AM
Joined Jan 2009
We are now shipping the X88-J2. It will only take a couple of days to custom prep yours.
Jonathan
www.Wowhobbies.com
Old Sep 23, 2012, 05:48 PM
Joined Jan 2009
Gigantic octocopter sale
Special holiday octocopter promotion includes $500 to $800 coupon.
go to
www.WowHobbies.com
The X88-J2 is the choice of the Hollywood producers due to its extreme payload and stability but you don't need to be a producer to own one now. Sale price for RTF starts at $2995. Great for FPV.
Remember to click on APPLY after coupon code is entered.
We have new stunning video releasing soon.
Thanks for your continue support,
Jonathan
www.WowHobbies.com
Old Nov 21, 2012, 08:17 PM
Kerbob is offline
Find More Posts by Kerbob
Kerbob's Avatar
Knoxville, TN
Joined Apr 2008
Here's a link to a post I made about my X88-J2. Very happy with it!
http://www.rcgroups.com/forums/showp...97&postcount=6
Kerbob is offline Find More Posts by Kerbob
Old Dec 13, 2012, 04:50 PM
Joined Jan 2009
Turbo Ace shooting with the Canon 6D and Nikon D600
Some footage taken with the Cinewing X88-J2 using the Canon 6D and Nikon D600.
Canon 6D vs Nikon D600 vs 5D Mark III (7 min 30 sec)
Ed
www.TurboAce.com
Old Feb 19, 2013, 07:32 PM
soniceden is offline
Find More Posts by soniceden
soniceden's Avatar
Joined Dec 2012
Wookong Voltage Monitor Question
Hey Gang.
I’ve had my X88-J2 for a few weeks now and I need some help with the wookong battery monitor.
I have the AV200 gimbal and I’m lifting a Lumix GH2.
I fly with two MG Power 5300mAh 14.8volt batteries in parallel.
The voltage measured from the two batteries together with no load before flying is 16.7 volts. Both my multi meter and the transmitter’s sensor read this.
In the Wookong software, the first stage warning led is to flash at 14.4 volts and the second stage warning is to flash at 14 volts.
When I’m flying, the transmitter’s sensor is reading 15.1 volts when the first stage warning starts flashing and the second stage flashes at 14.7.
The ending voltage from the two batteries together with no load is 15.52volts
This is giving me about 5 minutes of flight time taking it to the self landing point.
I thought with this setup I would get about 10 – 12 minutes.
These figures are also with me doing minimal flying around. Not shooting up and down or anything. Just practicing flying around my backyard filming.
I don’t want to lower the wookong settings and risk ruining the batteries.
Any suggestions are appreciated.
Cheers,
John
UPDATE: I also tried flying without the camera and the best time I got was 8.5 minutes from a full battery to the self landing point.
First warning light came on at 14.7 volts and the second stage led came on at 14.4 then it self landed.
Tried to contact DJI in Austin TX to ask why the led's were not coming on as per the software values but no luck there.
soniceden is offline Find More Posts by soniceden
Discussion Turbo Ace X830-S quad official site wowhobbies Multirotor Talk 1413 Jun 06, 2015 02:38 PM
Discussion How to best approach State or Local officials for a slope site? Zenmaniac Slope 20 Apr 12, 2012 05:21 AM
Discussion Suggestions for Turbo Ace X830S BlimpGuyG Multirotor Talk 3 Mar 09, 2012 01:01 AM
Discussion Suggestions for Turbo Ace X830S BlimpGuyG Aerial Photography 1 Mar 07, 2012 09:14 PM
Sold Walkera 4g6 RTF with wow hobbies turbo ace motor austinhlg Aircraft - Electric - Helis (FS/W) 2 Feb 28, 2012 05:50 PM
