Closed Thread
Old May 05, 2012, 10:08 AM
Beaumont tx
BL cogging
I smacked an eflite 400 BL into the ground yesterday; broke the prop and destroyed the plane. Now it won't turn freely; I think the term is "cogging" but at any rate it turns maybe 15 degrees, then a hitch, then 15 more. Have i destroyed it completely? If not, what do I do NOW?
thanks
howell
gwinhh is offline Find More Posts by gwinhh
Old May 05, 2012, 10:20 AM
Wake up, feel pulse, be happy!
C₄H₁₀'s Avatar
United States, AK, Fairbanks
Joined Aug 2009
Does it make any noise or notceable mechanical grinding, or does it just feel like the usual magnetic cogging?
Have you tried running it?
C₄H₁₀ is online now Find More Posts by C₄H₁₀
Old May 05, 2012, 03:03 PM
Inspiration
modisc's Avatar
中国, 江西省, 南昌
Joined Aug 2011
24 cogging per revolution (15 degree each), is normal for a 12N8P motor
modisc is offline Find More Posts by modisc
Old May 05, 2012, 10:14 PM
Beaumont tx
No noise; ddin't want to run until I was sure it wouldn't be hurt worse.
howell
Old May 06, 2012, 05:35 AM
Jack
USA, ME, Ellsworth
Joined May 2008
If you have a multimeter set it for Rx1 and touch the probes together, you should see a low resistance of a fraction of an Ohm or so.
Check two motor leads with the probes and check all three pair combos (1-2, 1-3, 2-3). All should read about the same as the shorted probes and have steady values. It one is way higher or the numbers are dancing around you have a short somewhere and don't want to power it up. A shorted motor can kill your ESC if it is still alive.
If you pass that test and the motor will turn, short the three motor leads together. The cogging should become a little lighter and be the same all the way around.
At this point you have a chance that it is OK. Connect to the ESC and power up, if the ESC arms itself it is seeing a apparently normal motor connected. It it will not arm itself, there may be a problem. I would quit there and take the motor apart...
If it armed itself, open the throttle one click and close it immediately. If it ran momentarily and there is not heat or smells you may be OK. Try adding click one at a time and for longer periods check for smells and heat in the motor and ESC.
If the bearings are damaged you might not hear that until you have a prop on it that pulls a load on the bearings.
Jack
jackerbes is offline Find More Posts by jackerbes
Old May 08, 2012, 03:46 PM
Beaumont tx
Thanks for all the advice; I will file it away for future reference.
As far as this one is concerned, the ESC armed normally, but the vibration was not to be believed. Time to remove the connectors and wire, and toss the motor.
howell
Closed Thread
For Sale '''lipo , roller , bl esc , bl motor , servo , 2.4ghz radio""" milenko_78 Cars - Cars and Parts (FS/W) 8 Sep 22, 2011 04:33 PM
Sold 4000KV BL inrun , 250 BL motor & 20 amp ESC $20 for all rolis12 Aircraft - Electric - Power Systems (FS/W) 2 Sep 15, 2011 10:57 AM
Help! PKZ Super Decathlon BL, CoG? ci_phon Parkflyers 4 Sep 08, 2010 02:53 AM
I have a motor with a brass cog on the end/How do i remove the cog and replace it? mortonj69 Power Systems 25 Mar 24, 2003 06:07 AM
