Old May 05, 2012, 08:51 AM
Frank S is offline
Find More Posts by Frank S
sewing machine thumb
United States, CA, Palo Alto
Joined Jul 2001
Third vector says thermal is thataway, but how far?
I'm hoping that I learned a bit about air reading at the IHLGF last weekend. I've been reviewing JW's third vector diagram, and trying to put it into practice, but now I'm hung up on the question of how far to look for a thermal once I've gotten an idea of what direction to search.
I assume the velocity of the thermal inflow is a function of both the size of the thermal and its distance.
I can see how spatially separated signs (trees, streamers, etc) would help triangulate, but what if don't have those?
Frank S is offline Find More Posts by Frank S
Old May 05, 2012, 09:33 AM
Joe W is offline
Find More Posts by Joe W
launch low, fly high
New Zealand, Hawke's Bay, Havelock North
Joined Dec 2004
Rate of change of the wind provides a strong indication of size and distance.
Joe W is offline Find More Posts by Joe W
Old May 05, 2012, 03:01 PM
sporter is offline
Find More Posts by sporter
Come out swinging
sporter's Avatar
San Diego
Joined Mar 2005
Joe,
Can you explain why you want to fly along a straight path and how to interpret model response and what it means in terms of the thermal's position?
Sean
sporter is offline Find More Posts by sporter
Old May 05, 2012, 04:32 PM
RCPC is offline
Find More Posts by RCPC
Throw it like you hate it
RCPC's Avatar
United States, CA, Castro Valley
Joined Apr 2007
weird double post
RCPC is offline Find More Posts by RCPC
Old May 05, 2012, 04:33 PM
RCPC is offline
RCPC's Avatar
Joined Apr 2007
if i assume the thermal is tracking downwind with the prevailing wind, and the prevailing wind is constant in both velocity and direction, then can i tease apart both the size AND distance of the thermal?
for instance, if the thermal is close to me the third vector will rotate quickly, while if the thermal is very far off, the third vector will rotate slowly. this is like looking at a commercial jet high in the sky, and it looks like its going very slowly, but in reality it is moving fast. only because we are far from it, does it look to move slowly.
is this a correct way to determine distance?
magnitude and direction of the third vector gives information on both size and distance, but from this alone i cannot determine both the size AND location independently. correct? we need look at how the third vector evolves?
paul
Old May 05, 2012, 06:08 PM
Tmfury is offline
Find More Posts by Tmfury
up from the skies
Tmfury's Avatar
United States, CO, Fort Garland
Joined Jul 2011
What's a vector-sorry I don't know that stuff
Tom
Tmfury is offline Find More Posts by Tmfury
Old May 05, 2012, 06:42 PM
xbted is offline
Find More Posts by xbted
American Exile
Germany, BB, Nauen
Joined Jan 2009
Tom
A vector is magnitude and direction.
xbted is offline Find More Posts by xbted
Old May 05, 2012, 06:55 PM
RCPC is offline
RCPC's Avatar
Joined Apr 2007
Tom
this is the diagram to which Frank was referring. this should help relieve your confusion.
paul
Old May 05, 2012, 11:33 PM
Joe W is offline
Joined Dec 2004
With sufficient integration time, one "should" be able to sort out both the relative distance and strength of a passing thermal. A close but very strong thermal results in a very large change in wind direction and wind velocity. A distant but very strong thermal results in a gradual and weak change in the wind direction and wind velocity. A close but very weak thermal results in a quick but weak change in the wind direction and velocity. A distant and weak thermal results in almost no change (what little change that happens, happens slowly). The mathematician looks at the inputs/outputs, and concludes that there are two independent variables, and two dependent variables. Therefore there is a closed form solution. The independent variables are thermal strength and thermal distance. The dependent variables are wind change, and rate of wind change. The art is in the determination of the closed form solution!
Old May 06, 2012, 07:31 AM
Phil Barnes is offline
Find More Posts by Phil Barnes
Germantown, Maryland
Joined Apr 2004
Joe
Could you please check the last two sentences of your last post. It looks like a typo, where you wrote independent when you meant dependent for one of them.
On another topic; what confuses me the most is when there are multiple thermals. I have no idea how to work that situation out. All I observe is that the vectors are lying because they don't really indicate where the lift is anymore.
Phil Barnes is offline Find More Posts by Phil Barnes
Old May 06, 2012, 07:50 AM
lesterpk is offline
Find More Posts by lesterpk
lesterpk's Avatar
Australia, WA, Perth
Joined Oct 2003
Translation for JW's last post:
I go where the squirrel in my pocket tells me to ;-)
lesterpk is offline Find More Posts by lesterpk
Old May 06, 2012, 09:08 AM
DBSkyout is offline
Find More Posts by DBSkyout
Will fly for Bourbon
DBSkyout's Avatar
Monroe, Wa
Joined Aug 2005
Amen
DBSkyout is offline Find More Posts by DBSkyout
Old May 06, 2012, 09:13 AM
Joe W is offline
Joined Dec 2004
Phil,
Yes, a "typo", or just sloppiness... The multiple thermal scenario is a bit more challenging. Poway has lotsa multiple thermal cases. And Poway can be a bit more challenging than average for reading due to the occasional very small but very strong thermal that doesn't really register very well on the vector radar.
Old May 06, 2012, 09:26 AM
sporter is offline
Come out swinging
sporter's Avatar
San Diego
Joined Mar 2005
Joe,
It seems the solution involves third vector interpretation coupled with model response.
Sean
Old May 06, 2012, 11:54 AM
Joe W is offline
Joined Dec 2004
The rationale for flying in a straight line is so that I can better evaluate the wind that the plane is flying through. If I fly a meandering course, I have poor luck with seeing local wind changes. For example, if I am flying a direct crosswind heading, I can see fairly easily if the crosswind is decreasing (thermal upwind), or increasing (thermal downwind). If my flying is more of a meandering course, it is more difficult to determine the wind change. You will see this in my flying style. I'll make a pre-launch air read, then fly directly towards the initial call. En route, I'll evaluate the relative wind as based on the airplanes response. If my initial vector was a bit off on the heading, I'll fly along until I notice a change in the crosswind, then turn downwind as determined by the crosswind change. Ideally, you wait until the rate of change of the crosswind drops to zero, then turn 90 degrees. This is somewhat difficult to evaluate in the real world!
If you get nothing else from this thread, remember these words, "listen to your plane"... Your plane is trying to tell you far more things than just "I'm going up (or down)". The art of dlg IMO is in learning to listen to your plane.
Discussion Duo5800v2+600mw, how far can you go ? zaguruinzasky FPV Talk 0 Feb 22, 2012 06:47 PM
Discussion Ryan - 'If We Compromise Too Far, We Can Win But We Still Lose the Country’ D B Cooper Life, The Universe, and Politics 9 Dec 03, 2011 08:44 AM
Experienced, but new to sailplanes: looking for slope/thermal plane; how to slope? Ninjak2k Electric Sailplanes 3 Dec 10, 2001 06:27 PM
