Espritmodel.com Heli Air
Old May 05, 2012, 03:01 AM
TheLeabres's Avatar
India, DL, New Delhi
Joined Sep 2010
Build - GWS Pico Tiger Moth NPS Version (white) spray paint
Save time and use time lapse when spray painting the GWS Pico Tger Moth Slope Glider version. Comes all white so the paint scheme options are infinite. Spray about 12 inches away so the propellant loses its sting before hitting the foam. Otherwise, the propellant eats the foam and you get tiny pits, more air drag but like a golf ball, more lift too! LOL!
TheLeabres is offline Find More Posts by TheLeabres
Old May 06, 2012, 07:14 AM
TheLeabres's Avatar
Joined Sep 2010
Update - using the AX 2308N 1100kv brushless Micro Motor from HobbyKing
I've used 5 of these motors, all with good results.
Factory Spec.
Kv: 1100rpm/v
Lipo Range: 2-3 cell
Suggested prop: 8x4 ~ 9x5
Best current range: 6~10A
Weight: 44g
Shaft diameter: 3mm
Stator: 23 x 8mm
Test Data.
Battery: 11.5v
Current: 9.7A
Propeller: 8x3.8
Thrust: 550g
Speed: 8520rpm
I'm using the upper 10mm hole and with the stick mount it lines up perfectly with the cowling.
Old May 18, 2012, 09:07 AM
TheLeabres's Avatar
Joined Sep 2010
Then and Now - difference between noob and experience
Finished the second GWS Pico Moth (2nd kit) and starting the GWS Corsair. Builds always go better the second time around. The maiden and subsequent flight of this 2nd Pico Moth was 100% better than the first.
You know you're a bad pilot when your own kid laughs at your skills and lets you have it with the honest feedback!
Destroyed GWS Pico Tiger Moth Early Noob Flights Total Wrecks Repaired Crashes Again! (0 min 44 sec)
Old May 18, 2012, 09:28 AM
TheLeabres's Avatar
Joined Sep 2010
Pico Moth Done - Corsair Starting
Pics of the completed Pico Moth and the GWS Corsair test fit of pieces (no glue)
Old May 22, 2012, 11:40 PM
Houng-wen Lin
GWS4CEO's Avatar
Shijr, Taiwan. DungGwan, China. City of Industry, California.
Joined Sep 2001
Thanks for choose GWS!
GWS4CEO is offline Find More Posts by GWS4CEO
Old May 22, 2012, 11:43 PM
Houng-wen Lin
GWS4CEO's Avatar
Joined Sep 2001
However, looks like the 550g thrust will be too much than what she need!
Old May 25, 2012, 03:10 AM
TheLeabres's Avatar
Joined Sep 2010
Good to see you
Nice of you to make it to this thread. I love GWS for their quality but affordable ARF kits. I'm not a discerning "scale enthusiast" but more into just flying and seeing something built so easily fly so gracefully, whether slowly or warbird fast. I hope GWS not only survives but grow and capture more of the RC market customers. I don't think there are any other RC foam plane companies out there that can put a quality foam kit in a box with a motor, rods, LG, decals, for the same affordable price as GWS.
One suggestion:
Because the Pico Moth, F version Stick, J3F are for beginners... it would be nice if they came with a pack of 6 propellers because as beginners you know they will break the prop a dozen times before getting comfortable,
Old May 25, 2012, 03:15 AM
TheLeabres's Avatar
Joined Sep 2010
btw, I'm using a Rhino 2S 610mAh lipo and a GWS 9 X 4.7 SF prop for the Pico Moth and it keeps her nice and slow but with enough power in case I need it. You don't need a 3S for the Pico Moth, too fast a speed and high G turns all the time will eventually loosen the wing struts. Besides, she was designed to be admired gracefully floating around and then coming in for the smoothest landings.
Wanted GWS Pico Tiger Moth NEW IN BOX supi7 Aircraft - Electric - Airplanes (FS/W) 1 Mar 10, 2012 11:27 PM
Discussion What to get instead of a GWS Pico Tiger Moth foobarbaz Foamies (Kits) 10 Dec 17, 2011 10:33 AM
Discussion GWS Pico Tiger Moth CG? 1jet14 Foamies (Kits) 5 Nov 29, 2011 11:04 PM
Sold GWS Pico Tiger Moth & Extras Rayk Aircraft - Electric - Airplanes (FS/W) 2 Nov 15, 2011 12:20 PM
Found GWS Pico Tiger Moth nps/slope pidgeoto Aircraft - Electric - Airplanes (FS/W) 2 Jun 17, 2007 08:06 PM
