Old May 05, 2012, 12:54 AM
runner2k's Avatar
Canada, ON, Toronto
Joined Jun 2011
4-Cell 5000mAh 45C with EC3 connector?
Hello,
I have a question for you guys. I've some EC3 connectors and I would like to modify my 4S pack.
The EC3 can handle up to 60A and EC5 can handle up to 120A.
Some people have said the EC3 can easily handle 100A. Is that true?
The battery pack I will use has the following info:
Max Charge Current: 30A
Max Cont. Current: 225A
Max Burst Current: 450A
Based on the information above, would you use the EC3 connector? What should I look for before buying any connector? The Max cont. current?
Thank you!
runner2k is offline Find More Posts by runner2k
Old May 05, 2012, 01:30 AM
Expo/DualRates = Lack of Skill
typeRA's Avatar
San Diego, CA
Joined Mar 2009
It depends on the average current. What is the battery powering?
typeRA is online now Find More Posts by typeRA
Old May 05, 2012, 03:37 AM
**** 37130 ****
RobC(UK)'s Avatar
Joined Aug 2007
I use EC3 on 6S 5000 mAH packs up to 60A and they stay cold. I don't think I would want to pull 100A through them.
One thing to watch is the wire gauge on your pack, anything over 12 ga will need to be trimmed down to fit into the connector cup.
RobC(UK) is offline Find More Posts by RobC(UK)
Old May 05, 2012, 04:16 AM
Joined Dec 2011
Deans rated 40A continuos
EC3 rated 60amps continuos
EC5 rated 120Amps continous
vlad_vy is offline Find More Posts by vlad_vy
Old May 05, 2012, 06:31 AM
runner2k's Avatar
Canada, ON, Toronto
Joined Jun 2011
@typeRA
The plane is a FMS F4U Corsair 1400mm and the stock ESC is rated 65A / 3A BEC if I'm not mistaken.
The motor is a 4215-500Kv.
The battery pack has the following info:
4-Cell 5000mAh 45C
What I don't understand is the Max Burst. Could it reach the 450A even for a second?
@RobC(UK)
Which C packs do you use?
30C ?
Old May 05, 2012, 03:36 PM
**** 37130 ****
RobC(UK)'s Avatar
Joined Aug 2007
Originally Posted by runner2k View Post
@RobC(UK)
30C ?
25C and 35C.
I have seen the occasional spike of 80A on my EagleTree, but mostly below 60A in flight
Old May 05, 2012, 09:38 PM
runner2k's Avatar
Canada, ON, Toronto
Joined Jun 2011
I'm able to fit 12 AWG into the EC3 connector.
Should I use EC3 or EC5?
Old May 05, 2012, 10:28 PM
Joined Feb 2008
You should be basing this off your amp draw, not some numbers on the battery. For accuracy, wattmeter it, but I'm guessing if the ESC is 65A max, then EC3s will be fine. (Assuming the ESC was appropriately chosen,)
Dave H. is offline Find More Posts by Dave H.
Old May 05, 2012, 11:23 PM
runner2k's Avatar
Canada, ON, Toronto
Joined Jun 2011
Hello Dave,
Thanks for your answer.
For Sale MINT ThunderPower 2250 mAh 3S 45C G6 Pro Performance Battery WITH EC3 Connector Left Coast DJ Aircraft - Electric - Batteries & Chargers (FS/W) 9 May 21, 2012 11:01 AM
For Sale ThunderPower 2250 mAh 3S 45C G6 Battery w/ EC3 and Balance Board Left Coast DJ Aircraft - Electric - Batteries & Chargers (FS/W) 3 May 04, 2012 09:40 PM
Sold Thunder Power 45C 5000mAh 5-Cell/5S 18.5V Lipo Battery markusvt Aircraft - Electric - Batteries & Chargers (FS/W) 4 Oct 04, 2011 09:08 PM
Sold 4 - ZIPPY 5000mah 30C 6-cell Battery Packs!! Nogahyde Aircraft - Electric - Batteries & Chargers (FS/W) 0 Sep 23, 2011 03:18 PM
For Sale Trinity e-fuse (blue/white) with brand new 4S 5000mah 45C Thunder Power lipo Toby W Aircraft - Sailplanes (FS/W) 1 Dec 24, 2009 09:30 PM
