Old May 05, 2012, 12:52 AM
golden77 is offline
Find More Posts by golden77
Joined May 2012
Quadcopter, 1 motor runs a lot faster than other 3
Im attempting to build a quadcopter for the first time using the microchip PIC18. I successfully programmed the 6-amp ESCs using a 1-2ms pulse every 20ms. The only problem is when I try to run all motors, only 1 is as fast as i need it to be, the other 3 are very sluggish and eventually stop altogether even when sending all ESCs the same pulse. Also, other times all 4 motors will seem to go there max speed for a little bit on start up and then quickly level off to a speed that does not lift the copter.
Could it be a battery problem? I'm new to LiPos but the one we are using is a 11.4V 1500mAh 25C battery. The voltage across the battery is very close to 11.4V still even with repeated use.
Any help or suggestions is appreciated!
golden77 is offline Find More Posts by golden77
Old May 05, 2012, 01:39 AM
sirbow2 is offline
Find More Posts by sirbow2
Emress
Joined Nov 2011
you should read this and hope that you dont screw up your LiPos(you probably haven't yet). a full charge would help(12.6v)
sirbow2 is offline Find More Posts by sirbow2
Old May 05, 2012, 04:16 AM
sg1anubis is offline
Find More Posts by sg1anubis
sg1anubis's Avatar
United States, AL, Huntsville
Joined Sep 2011
Try to calibrate your throttle range:
1) remove all props
2) connect esc to throttle channel of rx
3) turn tx on, apply full throttle
4) plug in battery and wait for esc to beep
5) reduce throttle to zero and wait for confirmation
6) repeat for each esc
Maybe reflash your ESCs with Simonk firmware
sg1anubis is offline Find More Posts by sg1anubis
Old May 05, 2012, 04:32 AM View Post
sidkof
A moderator felt this post violated the following rule: Off Topic Advertisement. Show it to me anyway.
Old May 05, 2012, 04:38 AM
MAMOARMIN is offline
Find More Posts by MAMOARMIN
Joined Feb 2008
Well, i would suggest to check the k/v of each motor first, at the end, you may sit on some wrong delivered or produced motors, sold with the same kv. Also check if they do not have a short in windings.
kr
www.mamo-models.com
MAMOARMIN is offline Find More Posts by MAMOARMIN
Old May 05, 2012, 11:51 AM
golden77 is offline
Joined May 2012
What are the the recommended programming settings for the ESCs?
I'm using 4 of these: http://www.hobbyking.com/hobbyking/s...idProduct=4318
and these are the motors: http://www.hobbyking.com/hobbyking/s...otor_19g_.html
Also for the ESCs I've read that all get hooked up to the battery terminals and all get a signal line and ground but only 1 gets a 5V line? Is this correct?
Old May 05, 2012, 12:00 PM
sirbow2 is offline
Emress
Joined Nov 2011
Brake off
Ni-xx
Soft-Cut
Low Cut off
Normal start up mode
Timming depends.
get a battery monitor, or make sure the battery doesn't drop below the recommended voltage. or use Li-xx on the ESCs which enables low voltage cutoff.
if your ESCs have linear BECs, then you can leave all the +5v connected, if they are switching BECs, you need to unconnect all but one +5v. yours are linear.
Old May 06, 2012, 10:04 AM
GTASouthPark is offline
Find More Posts by GTASouthPark
Joined May 2012
Originally Posted by sirbow2 View Post
Brake off
Ni-xx
Soft-Cut
Low Cut off
Timming depends.
Why set the ESC's to Ni-xx when the battery is LiPo? Also does it matter that he's not using a BEC?
GTASouthPark is offline Find More Posts by GTASouthPark
Old May 06, 2012, 01:54 PM
sirbow2 is offline
Emress
Joined Nov 2011
so that the ESC deosnt limit the motor speed when the battery is low( can cause quad crashes). so Ni-xx disables that, and then use a external battery monitor(something like http://www.hobbyking.com/hobbycity/s...idproduct=7223) to notify you when the battery is low that way the motors can still go 100% if need be on the way down.
the bec normally supplies power to the FC; if you are using another source to power your FC, id unconnect the red(+5V) from the ESCs
Old May 06, 2012, 10:24 PM
golden77 is offline
Joined May 2012
ok guys so I tested the motors again without the battery, using 2 power supplies, 1 supply for 2 motors... each supply has a max current o/p of 5.5A. 1 supply was providing 1.9A and the other was providing 2.3A when under load, all ESCs were receiving the same pulse...any ideas?
I also charged my Lipo 3 cell battery today to 12.2V, I don't have a charger so i used a bench supply, the charger connector on the battery has 3 black wires and 1 red. I connected the red wire to positive and grounded the closest black wire to red, giving it 4.2V and a constant current of 1.49A... when the supply switched to constant voltage mode i then switched the ground to the next black wire over and set the supply to 8.4V, 1.49A... rinse and repeat but with 12.6V on the last. Is this the correct way to do it? After I was finished the battery terminals read 12.08V.
After this i tried running all 4 motors with the battery and they still performed poorly... I must be missing something!
Old May 06, 2012, 10:44 PM
sirbow2 is offline
Emress
Joined Nov 2011
seems like you have some miss winded motors maybe(check the Kv). also, did you calibrate them with the TX yet?
Old May 06, 2012, 10:57 PM
golden77 is offline
Joined May 2012
Alright I will definitely check the Kv soon, thanks for the suggestion I shouldn't have ignored the first user that said that. Also, I have calibrated the ESCs a couple times, since I'm using a microchip and not a transmitter, my calibration method involves sending a 20ms signal with a 2ms duty as "max throttle" and then a 1ms duty is "lowest throttle" I don't have an ESC programmer but the beeps match perfectly for what the instructions say.
Old May 07, 2012, 01:15 PM
mattcro is offline
Find More Posts by mattcro
KK Tri Flyer
mattcro's Avatar
United Kingdom, Scotland, Glasgow
Joined Feb 2012
You MUST use a proper charger to safely charge LiPo batteries. Get one that runs on 12V DC and you can power it from your bench PSU - they're not that expensive. LiPos have strict limits on max cell voltage and you've probably overcharged the battery using just a bench PSU. If you insist on using the bench PSU, then charge each cell separately to exactly 4.2V using limited current. You were charging the first cell by itself, but then charging it again with the second cell in series, then charging the first 2 cells again in series with the third. Not good. Serious overcharging can actually cause LiPos to burst or catch fire, and even mild abuse can shorten their life substantially.
mattcro is offline Find More Posts by mattcro
Old May 08, 2012, 11:48 PM
golden77 is offline
Joined May 2012
Alright guys, so I re-charged the Li Po today the correct way and got all cells to about 4.1V, and guess what? All motors work great now! some are still faster than others but I'm guessing that's just the crappy Chinese manufacturing.
By the way, has anyone worked with Wii sensors in nunchuck pass through mode? I aways get all 1s returned over the i2c bus...
Old Jan 17, 2014, 12:00 PM
shubham001 is offline
Find More Posts by shubham001
Joined Jan 2014
i make quadcopter par wo fly nhi kar pa raha hai wo ek taraf se upar uth raha hai please help
shubham001 is offline Find More Posts by shubham001
Sold Price Reduced-DA-170 w/ Manifolds with less than 3 Hours running time!!! unclegeorge Aircraft - Fuel - Engines and Accessories (FS/W) 7 Apr 30, 2012 04:46 PM
Discussion Cheaper Faster Than MM Rustler XVL Wa7sh Electric Power Cars 3 Feb 28, 2012 05:07 PM
Discussion Accucel 6 charging cells 1 and 2 faster than 3? Supercubflyer Batteries and Chargers 2 Nov 11, 2011 12:17 AM
Discussion BCX2 Spins faster one way than the other(video) Krash3k Coaxial Helicopters 5 Jun 28, 2007 01:13 PM
Discussion biplane faster than my other one bazookie Micro Ready-to-Fly 4 Nov 05, 2006 01:09 AM
