Old May 04, 2012, 09:59 PM
rpm3 is offline
Find More Posts by rpm3
rpm3's Avatar
Pleasanton, California
Joined Nov 2000
Hitec X4 Plus AC/DC-Tanic Packs
Is there an adapter plug out there I can use with the X4 plus to charge AND balance these tanic packs?
I am not sure that even though you can charge 4 packs independently, I want to be the guinea pig on charging the individual cells on 3 separate "ports"....
thanks
Ralph Matile
rpm3 is offline Find More Posts by rpm3
Old May 05, 2012, 07:34 AM
PGR is online now
PGR
Find More Posts by PGR
PGR
Low AltiDude
PGR's Avatar
United States, CA, Costa Mesa
Joined Jun 2004
Why?
Pete the Perplexed
PGR is online now Find More Posts by PGR
Old May 05, 2012, 10:43 AM
rpm3 is offline
rpm3's Avatar
Joined Nov 2000
WHY you ask to this?
"I am not sure that even though you can charge 4 packs independently"
My Answer:
I don't know enough about the circuitry of the charger, and the configuration of the Tanic taps..maybe sharing a common ground?,..not sure if thats a problem...and I've read some other posts....granted..for other chargers, that warn against this process ....
not sure I "want to be the guinea pig on charging the individual cells on 3 separate "ports".
My answer
Frying a $200 charger...thats a bad day...if i can find out from the forums its a risk in advance...thats my goal...
thanks
Old May 05, 2012, 05:07 PM
typeRA is online now
Find More Posts by typeRA
Zero Expo
typeRA's Avatar
San Diego, CA
Joined Mar 2009
Ask Tanic, it's their bastard.
typeRA is online now Find More Posts by typeRA
Old May 05, 2012, 05:51 PM
rpm3 is offline
rpm3's Avatar
Joined Nov 2000
Well ok then...
thanks
Old May 06, 2012, 04:20 PM
FlyingW is offline
Find More Posts by FlyingW
Build more, websurf less
FlyingW's Avatar
Long Valley, NJ, USA
Joined Dec 2001
rpm3,
A few years ago I bought an adapter from Tanic Packs to take the individual JST connectors into a single JST-HX plug. I had a few old Tanic Packs and got more life from them with the adapters.
Good luck,
Paul
FlyingW is offline Find More Posts by FlyingW
Old May 08, 2012, 10:53 PM
rpm3 is offline
rpm3's Avatar
Joined Nov 2000
Tanic 3s Adapter for Hitec X4 AC
ok...I used 3 JST males plugs, and a Hyperion adapter part number
HP-EOSLBA-MC-P4
Yes..you need to be careful when soldering, not to short out anything....and yes..you should number each JST plug so you insert it into the correct cell.....but after looking at it...I tried it....works great.
So now i can balance charge a Tanic pack no problem....if anyone is interested in more photos...let me know...
It almost feels like I have found 3 new batteries (Tanic)...since i can take care of them better!!
Ralph Matile
Discussion Hitec X4 AC Plus AC/DC Four-Channel Multi-Charger rpm3 Batteries and Chargers 199 Yesterday 07:07 AM
Discussion Hitec X4 Plus AC/DC-Tanic Packs rpm3 Batteries and Chargers 0 May 04, 2012 09:57 PM
Help! Need Help programming Hitec X4 AC/DC charger scphoto Batteries and Chargers 4 Apr 13, 2012 11:03 PM
Discussion Hitec X4 Plus AC/DC rpm3 Batteries and Chargers 5 Apr 11, 2012 04:53 PM
Discussion Q6 AC/DC vs Hitec X4 Plus AC/DC rpm3 Batteries and Chargers 0 Jan 21, 2012 10:33 AM
