Old May 04, 2012, 09:00 PM
kenh3497 is online now
Find More Posts by kenh3497
Don't fear the reaper
kenh3497's Avatar
United States, IA, Rockwell
Joined Jul 2011
looking for a compariable engine to a Laser 150
As stated, I looking for an engine that would compare power wise to a Laser 150 from back in the mid to late 90's. I'm building a 20% scale Zlin 526 AS from plans, well I do have a short kit but you get the idea. Anyway I'm sure there are engines today that will equal or surpass power wise the Laser. Smaller displacement is not a requirement but would be welcome in an effort to reduce weight. This is a scale airframe so it will see acrobatics in the theme of the time (mid 70's).
I guess I would prefer a 4C glow at this point as I like the sound and think it would fit the airframe well. Gas MIGHT be considered. The cowl of this plane is very narrow as the full scale version used an inverted in-line six cylinder. I noticed the Saito 150 has a "rear" exhaust which would help in hiding everything.
Thanks for the help!!
Ken
PS. The prototype model had the Laser in it, hence the question.
kenh3497 is online now Find More Posts by kenh3497
Latest blog entry: A letter from my other senator
Old May 04, 2012, 10:09 PM
ScooterInVegas is offline
Find More Posts by ScooterInVegas
Village Idiot!
ScooterInVegas's Avatar
United States, NV, Las Vegas
Joined Apr 2011
DLE-20 with a wrap around pitts. Vess 18x6 14lb. 3oz thrust. It would hang out the bottom of the cowl and would need to be painted the same color.
4 stoke? I would go with the Saito 150 or a YS 140. YS's are stump pulling mo-fo's!
http://www.amainhobbies.com/product_...gine-w-Muffler
ScooterInVegas is offline Find More Posts by ScooterInVegas
Old May 05, 2012, 06:21 AM
AndyOne is offline
Find More Posts by AndyOne
Oxford Panic
AndyOne's Avatar
United Kingdom, Oxford
Joined Feb 2003
The Saito180 is actually lighter than the 150 as it's in the same casting just more metal removed to make a bigger displacement. The 150 is 890g vs the 180's 880g not sure if this includes exhaust but the Laser 150 is 914g with exhaust. There's not much in it but the Saito180 will have all the power you need.
A.
AndyOne is offline Find More Posts by AndyOne
Old May 05, 2012, 10:49 AM
kenh3497's Avatar
Joined Jul 2011
A.
That's interesting and it make perfect sense!
I know the Saitos are a good engine but I have a "little" problem with the head and cylinder being one piece. With that said, I'm still leaning to the Saito, unless there is something out there that compares power wise to the Laser. I know of one Zlin flying on a .90 2C just fine but I want a 4C. I'm told it's a 12 to 14 pound plane, depending on how you build. I can't think for the life of me now what the wing area is.
Ken
Old May 05, 2012, 01:14 PM
I TOBOR is offline
Find More Posts by I TOBOR
I TOBOR's Avatar
Joined Feb 2007
The head and the cylinder being a unit is a non issue, it is a plus though eliminating four or five bolts and a potentially leaky head gasket.
I TOBOR is offline Find More Posts by I TOBOR
Old May 05, 2012, 05:59 PM
AndyOne is offline
Oxford Panic
AndyOne's Avatar
Joined Feb 2003
Laser Engines are still available...
http://www.laserengines.com/index.htm
A.
Old May 05, 2012, 07:04 PM
earlwb is offline
Find More Posts by earlwb
earlwb's Avatar
USA, TX, Grapevine
Joined Dec 2008
I'd go for a Saito engine too. But you can still find good Enya R155 engines too. I have both a Saito 1.50 and a Enya R1.55, but I think their performance is much better than the Laser 1.50 though.
The latest Saito engines weigh quite a bit less, so much so that they tend to weigh a little less than a same displacement 2 stroke engine even. The one piece head and cylinder is really not a problem and you don't have to worry any about the head leaking at the cylinder/head joint either.
earlwb is offline Find More Posts by earlwb
Old May 05, 2012, 07:10 PM
I TOBOR is offline
I TOBOR's Avatar
Joined Feb 2007
In my estimation the Saito 1.25 would be the closest match to the LASER 150. Having owned a LASER .70 I can vouch for their high quality being in league with the Saitos.
Old May 06, 2012, 10:28 AM
The PIPE is offline
Find More Posts by The PIPE
The PIPE's Avatar
USA, MA, Weymouth
Joined Mar 2004
That model of Zlin had a CLOCKWISE rotating prop, just like a Tiger Moth does!
Dear Kenh3497:
The PIPE Here...and as I suspected when I Googled for "images" of your model of Zlin aircraft that you're building an RC scale model of, that aircraft in full scale actually had a CLOCKWISE rotating prop on it, when seen from "nose-on"...
...have you ever considered giving it a clockwise-spinning model engine to match, as I would definitely be doing if I was in your situation???
If you give a good read at the recent response I wrote up to "splinterz25" concerning the left side engine on his P-38 Lightning WW II RC Scale model, he's somewhat in agreement with me on the issue...he's intending to check out getting a pair of the Laser 100 single-jug four stroke mills for his P-38, to be able to reverse its rotation for the left-side model engine, just like the full-scale one did.
Luckily, both the engine you've got for your Zlin - the Laser 150, and the Saito 150 you were thinking of using in its place, can BOTH be reversed for clockwise running, but in differing ways. The Laser series of single-jug four stroke mills has one feature that is EXACTLY like Enya's line of single-jugger four strokers, and that's the fact that each valve is operated with a separate camshaft, allowing the mill's twin camshafts to simply be RETIMED with respect to the crankshaft drive gear that spins them to do the reversing. The link to spinterz25's response here actually HAS an old, and enlargeable HTML-origin graphic attached to it, showing how some of the Enyas get retimed for reversed rotation, just like the Zlin would use in full-scale...even the venerable deHavilland Tiger Moth used a clockwise-running engine in full-scale, and if I can ever get one of the Flair quarter scale Tiger Moth kits someday, either a Laser OR Saito mill can be used and converted to clockwise running for the Tiggie's needs, too.
Unlike reversing the Laser, though, reversing the Saito 150 single-jug mill WILL need a new camshaft, and it's the camshaft from the left cylinder of the base model Saito FA-300T opposed twin mill that's needed to do the reversing with, in replacing the stock Saito 150 camshaft with the linked part.
Zinger has plenty of clockwise rotation props available to suit that need, so you've already got that taken care of as well, after the engine gets its reversing work.
I'm just not certain if you've even thought of it before...it's certainly something I'd do, and perhaps splinterz25 seems to be considering it as well for his P-38's left side engine.
Hope it's something that appeals to you, even a small bit...
Yours Sincerely,
The PIPE....!!
The PIPE is offline Find More Posts by The PIPE
Old May 06, 2012, 10:49 AM
Gary Cee is offline
Find More Posts by Gary Cee
Censor yourself
Gary Cee's Avatar
Joined Apr 2010
The venerable Enya big blocks are superstars in the scale arena . Good , solid engineering and design executed with quality and precision . Not so readily available in the US but worth looking in to .Since they are whittled from bar stock , the Lasers are quite heavy for the amount of power they produce . Castings have certain advantages from the perspevtive of weight anyhow.
As mentioned , the integral head / cylinder design that some makers use is actually an advantage . The YS small blocks have used that form as well. Actually , a YS from the .91 to 1.10 size could be a fine choice too . Very easy engines to learn and real steady performers .
The ENYA does lend to simple re-phasing of the intake/exhaust cams for CW rotation . It would be a bit more involved for the Saito IMHO .
Gary Cee is offline Find More Posts by Gary Cee
Old May 07, 2012, 12:46 PM
kenh3497's Avatar
Joined Jul 2011
all good advise. i was thinking of a slightly smaller displacement engine for the zlin. my thinking a newer design would make as much hp/torque as an older model. save some weight in the process.
excuse my typing..... stuck my hand in a prop yesterday
Old May 07, 2012, 09:26 PM
Village Idiot!
Joined Apr 2011
In that case, I say a YS115. Really good engine.
9900RPM 14.2lb thrust with a 14X12 apc!
YS FZ115S Engine Test (2 min 47 sec)
Old May 08, 2012, 10:49 AM
Gary Cee is offline
Censor yourself
Gary Cee's Avatar
Joined Apr 2010
Yep, I should have included the 1.15 in that range . Thanks ! Real powerhose and an incredibly fine running all around engine . Unmatched transition and you have a great deal of added flexibility in fuel tank layout. The pressurized fuel delivery makes fuel tank placement very easy, this is a HUGE plus in scale planes . In fact , you could probably use a single, central tank for both engines . Have not tried this personally but it should work well . I would first bench test for proof of concept however .
Old May 08, 2012, 12:36 PM
kenh3497's Avatar
Joined Jul 2011
i'm not going to mess with cw rotation. while i've looked at the ys brand, i've never considered one. maybe now is the time??? is the exhaust port on the ys 1.15 on the side or rear? i want to get all the exhaust inside the cowl. thinking rear or even at 45 degrees off would be better than out the side.
ken
Old May 09, 2012, 06:37 AM
Gary Cee is offline
Censor yourself
Gary Cee's Avatar
Joined Apr 2010
The YS is an absolute gem of an engine . Some good photos are shown in these independent reports:
http://www.centralhobbies.com/Engine...YS%20FZ70S.pdf
http://www.centralhobbies.com/Engine...ine%20Test.pdf
(My comments RE: CW rotation and a single tank were in response to the P-38 comment from The Pipe . Should have made that more clear at the time )
Wanted Looking for a Laser 200 model .40 size too 30cc Dallas101 Aircraft - Fuel - Airplanes (FS/W) 9 Nov 22, 2014 07:49 PM
For Sale Laser Engines Silencer /Muffler redball8 Aircraft - Fuel - Engines and Accessories (FS/W) 5 Jan 01, 2013 09:10 PM
Sold SOLD _ Laser type glass fuse with built up stabs and rudder $150 shipped CONUS be69ar Aircraft - Sailplanes (FS/W) 3 Dec 05, 2011 09:13 AM
Sold Laser Engines for sale 300V Twin and 80 BigJilm Aircraft - Fuel - Engines and Accessories (FS/W) 3 Oct 31, 2011 10:39 PM
Look out someone chasing you, Dive! Anyone ready for laser tag combat?!! jas_Qfix Power Systems 2 Jun 30, 2001 01:40 AM
