Old May 04, 2012, 06:26 PM
iCrap is offline
Find More Posts by iCrap
iCrap's Avatar
United States, MD
Joined May 2012
Building my first quad, some questions.
Hi guys,
So im building my first quadcopter today, ive got it all done but i am REALLY confused on how to wire this thing. I am using the blueskyrc quad frame, and the KK v5.5 board.Ive connected the throttle, rudder and aileron connectors from the KK board to the spektrum receiver, connected the 3 pin ESC connectors to the KK board.
So now i'm left with 2 wires from each ESC and nowhere to plug the power in. My assumption is a solder the positive and negative from each ESC together, then to a battery connector? Is this correct? I figured i should ask before i try it and blow something up.
Thanks in advance. I really want to get this thing flying today!
EDIT: My second question, is how do i properly flash the KK board for the quadcopter firmware? And which is the best firmware to use? ( i know there are lots)
iCrap is offline Find More Posts by iCrap
Old May 04, 2012, 06:45 PM
reelflyt is offline
Find More Posts by reelflyt
reelflyt
Edmonton, Alberta, Canada
Joined Mar 2010
Hi ICrap.
Here is an example of a power distribution board. http://www.hobbyking.com/hobbyking/s...ion_Board.html
Here is the best way to flash your board http://lazyzero.de/en/modellbau/kkmulticopterflashtool
Gordon
reelflyt is offline Find More Posts by reelflyt
Old May 04, 2012, 06:58 PM
iCrap is offline
iCrap's Avatar
United States, MD
Joined May 2012
So i looked at the power distribution board, it just looks like it would be the same as soldering the leads together then connecting them to the battery. Is that correct? So i would be fine then doing that?
Old May 04, 2012, 07:12 PM
mikemijal is offline
Find More Posts by mikemijal
Westland Michigan.
Joined Jan 2012
Not as neat. But still funtional
mikemijal is offline Find More Posts by mikemijal
Old May 04, 2012, 07:44 PM
scub is offline
Find More Posts by scub
United States, MA, Springfield
Joined Dec 2010
i also think most only use one 5v wire from 1 ESC.
basically remove the red wire from 3 of the ESCs, only keeping black and signal (white).. maybe someone can correct me if im wrong.
scub is offline Find More Posts by scub
Old May 04, 2012, 08:14 PM
iCrap is offline
iCrap's Avatar
United States, MD
Joined May 2012
I haven't heard that before..... is this true? can anyone confirm?
Also, now that i have the program to flash the KK, what firmware should i use on it?
Old May 04, 2012, 09:46 PM
a2j812 is offline
Find More Posts by a2j812
Joined Apr 2012
Can you post a picture of your ESC?
I'm not sure where the two extra wires are coming from.
Basically, your 4 ESCs should plug into the M1, M2, M3, M4 headers on the KK board. The black wires should be toward the edge of the board.
Then you have your Throttle, Elevator, Aileron and Rudder headers that should go to your receiver. After that its a matter of hooking up your motors and you're good to go.
Here's a video that I used to make my power harness, and It's worked really well for me.
power spider (13 min 59 sec)
a2j812 is offline Find More Posts by a2j812
Old May 05, 2012, 01:56 AM
scub is offline
Joined Dec 2010
here: http://www.rcgroups.com/forums/showthread.php?t=1097355
-TIP 8: It is recommended as a best practice for multicopters not to run ESC 5v BECs power wires in parallel. They will run hotter, be less efficient and can potentially induce noise into multicopter flight controller boards causing performance issues. This applies to both switching and linear type ESC BECs. Best multicopter practice: Only connect one 5v ESC power wire. Remove the other ESC 5v wires from the plastic connector by lifting the tab and then shrink wrapping the wire for protection. Do keep and connect the other ESC ground servo connections as removing them can cause performance issues with some ESCs and flight controllers.
Old May 05, 2012, 01:57 AM
vineet_p is offline
Find More Posts by vineet_p
vineet_p's Avatar
India, Telangana, Hyderabad
Joined Aug 2011
NOT necessary if the ESCs have a linear BEC. You need to use only one 5V wire if the BEC is switching type.
vineet_p is offline Find More Posts by vineet_p
Old May 05, 2012, 08:32 AM
iCrap is offline
iCrap's Avatar
United States, MD
Joined May 2012
I'm using these ESCs http://www.blueskyrc.com/index.php?m...products_id=39
Old May 05, 2012, 09:11 AM
iCrap is offline
iCrap's Avatar
United States, MD
Joined May 2012
Another question... i can't get the kk board to arm. the motors are beeping at me but no go. I have the regular spektrum receiver and a Dx7..
Old May 05, 2012, 09:49 AM
sirbow2 is offline
Find More Posts by sirbow2
Emress
Joined Nov 2011
you probably need to adjust your TX trims
sirbow2 is offline Find More Posts by sirbow2
Old May 05, 2012, 10:04 AM
iCrap is offline
iCrap's Avatar
United States, MD
Joined May 2012
What should it be set to?
Old May 05, 2012, 12:49 PM
iCrap is offline
iCrap's Avatar
United States, MD
Joined May 2012
No matter what i do, i can't arm it.. ive messed with the trim and i just cant get it to do anything.
The motors are twiching slightly and the ESCs are beeping, i assume this means its ready but not armed (the blue light isnt on either)
Old May 05, 2012, 01:31 PM
sirbow2 is offline
Emress
Joined Nov 2011
this should help http://rcexplorer.se/page14/kkguide/kkguide/tri.html
Discussion First Quad some questions Jack Daniels Multirotor Talk 7 Apr 12, 2012 04:19 AM
Question Thinking of building my first quad Marvos Multirotor Talk 39 Apr 06, 2012 12:56 PM
Build Log First Quad-X build: Need some advice PyroPanda Multirotor Talk 3 Dec 02, 2011 04:57 PM
Discussion First quad - some questions (HK-Board) mardimardigras Multirotor Talk 2 Sep 13, 2011 11:13 PM
