Old Oct 30, 2012, 04:24 PM
Jovanx is offline
Find More Posts by Jovanx
Tossing planes into the snow
Canada, BC, Smithers
Joined Nov 2011
Is there anyone who has successfully replaced the shaft of the stock motor? I have a slightly bent shaft on the Radian after the last ski hill incident. I can still fly it but there is some vibration, and with the prop removed, it can be seen that the shaft is bent when it is spinning.
I have a Corsair that uses the same motor except the shaft is reversed so it can be mounted in the usual way in front of the firewall. That motor started making funny sounds a few months ago. so I figured I would take it apart to see if the problem could be solved. With a lot of work I was eventually able to loosen the 2 allan screws on one end, but the third one on the other end will not budge. If I could get it apart, I might be able to figure out what is making the noise, and if not, it would at least work in the Radian with the shaft reversed.
Jovanx is offline Find More Posts by Jovanx
Old Oct 30, 2012, 04:26 PM
t.edwards is offline
Find More Posts by t.edwards
Joined Aug 2005
The stock fuse stiffener isn't stiff enough. So, while replacing it (I'm looking at getting and using a CF tube since I need to order a wing spar anyway) wouldn't it make sense to "pull" the fuse into position so the decalage is zero while glueing in the stiffener rather than dealing with decalage and fuse stiffening as seperate issues? Seems both could be dealt with in the same operation.
t.edwards is offline Find More Posts by t.edwards
Old Oct 30, 2012, 04:42 PM
Joined Aug 2005
Might look at http://www.horizonhobby.com/webapp/w...pe=productgrid The shaft has 4 set screw flats you don't see in the pic and is 1 29/32" long.
Old Oct 30, 2012, 04:55 PM
Jovanx is offline
Joined Nov 2011
The Radian 480BL and the Park 480 are two different motors. I will have a closer look and thank you for the link.
Yes the stock stiffener is definitely not stiff enough, and yes you can pull the fuse to wherever angle you want while installing a better stiffener. They can both be dealt with at the same time. It is just a matter of fine-tuning the slot before gluing the arrow shaft into place. If you make the slot an even depth all the way along, and tape the ends while the glue is drying, it will reduce the decalage.
In my case, the decalage was already good, so I made the slot deeper in the middle than the ends and ended up not changing the decalage by very much.
Here is something to keep in mind...the existing fuselage keel can be replaced with an arrow shaft without a weight gain, and the arrow shaft has a thin wall and is very light. The wing spar should be replaced with something stiffer, such as a standard CF tube that has a thicker wall. If this doesn't make sense, I could upload a picture that will show the difference in the wall thicknesses.
Old Oct 30, 2012, 05:13 PM
Joined Aug 2005
It looks like the "common" .375" OD CF tubes are .290" ID or ~.040" wall. What's the OD and wall thickness on an arrow shaft? I hadn't decided on a dia. for the fuse stiffener, or if round or box or two pieces of flat seemed better.
The fuse stiffness really seems pretty good until you get back to the thin section just before the tail surfaces
I also have a piece of .028" wall .375" OD 4130 chrome moly tube for a really stiff wing par should ballast be desirable.
Old Oct 30, 2012, 05:30 PM
Radio.Active is offline
Find More Posts by Radio.Active
Closed Account
Joined Aug 2011
Radio.Active is offline Find More Posts by Radio.Active
Old Oct 30, 2012, 05:46 PM
Manonthegrassyknoll is offline
Find More Posts by Manonthegrassyknoll
United Kingdom, England, Windermere
Joined Oct 2010
When you remove the original FG spar, cut about 8" off and glue it in the slot above the wing saddle, stiffens it up a treat..
Chris..
Manonthegrassyknoll is offline Find More Posts by Manonthegrassyknoll
Old Oct 30, 2012, 05:49 PM
Joined Aug 2005
Originally Posted by Radio.Active View Post
horizonal stabilizer
Is your horizontal stab just balsa and monokote or light ply or fiberglassed and monokote? I really don't like the stock horiz stab/elev.
Old Oct 30, 2012, 05:54 PM
Jovanx is offline
Joined Nov 2011
Chris..
I was thinking about shoving a 3mm CF rod in there as a skewer. There is something about that spot that looks weak, although I have not had a problem yet. Are there people who have had a failure in that location?
Old Oct 30, 2012, 07:53 PM
Closed Account
Joined Aug 2011
Old Oct 30, 2012, 08:11 PM
eckace1 is offline
Find More Posts by eckace1
OFF TOPIC POSTER
Des Moines IA
Joined Dec 2005
Would these blades work on the stock spinner?
http://www.bphobbies.com/view.asp?id...03&pid=W898906
eckace1 is offline Find More Posts by eckace1
Old Oct 31, 2012, 03:14 PM
Joined Oct 2010
I always thought it looked weak and it was one of the places that broke when i crashed once.. it was easy to insert as they hadn't even put any glue in on my Radian.... I think it can only help and since I had a spar sat there it seamed stupid not too..
Chris..
Old Nov 11, 2012, 04:59 PM
Joined Oct 2010
Originally Posted by Gohmer View Post
I fly mine with a lighter motor that lets me have a 3.25" CG without adding weight to the tail. No need to hack up the tail section.
which motor do you use..?
Old Nov 12, 2012, 01:39 PM
Closed Account
Joined Aug 2011
Old Nov 12, 2012, 04:45 PM
Gohmer is offline
Find More Posts by Gohmer
Owatonna MN 55060
Joined Sep 2005
axi 2212/20
Gohmer is offline Find More Posts by Gohmer
Question I Need Competition Mods for a Radian Pro Kenny Sharp Electric Sailplanes 4 May 02, 2012 07:08 AM
Help! Lost post on Radian Pro mods - just found it! JBGROS Sailplane Talk 1 Apr 02, 2012 07:27 PM
