Old May 09, 2012, 10:04 AM
labrown is offline
Find More Posts by labrown
SSP ASP#88
labrown's Avatar
United States, PA, Hatfield
Joined Apr 2009
Originally Posted by skyhawk newbie View Post
Does anyone fly a no decalage mod , but has there CG set aft ? or it anyone flying Decalage with stock CG ?.
I turned the fuse into packing peanuts after losing my Radian in the sun and plan to experiment with rearward CG after I complete moving everything to the new fuselage I bought. Hopefully some results this weekend. If I have to crank a lot of elevator trim in to make the CG work at 3" - 3.5" I'll think about doing the decalage mod.
One thing I noticed: the new fuse is quite a bit stiffer vertically then the old fuse. The fiberglass stiffener must be glued in better.
--[Lance]
labrown is offline Find More Posts by labrown
Old May 09, 2012, 10:19 AM
Jovanx is offline
Find More Posts by Jovanx
Tossing planes into the snow
Canada, BC, Smithers
Joined Nov 2011
The last few posts have cleared up my mind considerably, and it is all about the way things are worded. It is one thing to say you change the decalage and then have to move the CG back to compensate, and another thing to say you move the CG back (just because you want to) and then change the decalage to compensate. The second one makes total sense to me.
Is it possible to get the CG back that much without putting weight on the tail?
Jovanx is offline Find More Posts by Jovanx
Old May 09, 2012, 10:21 AM
chickenwing is online now
Find More Posts by chickenwing
More Altitude, Less Attitude!
chickenwing's Avatar
United States, SC, Ninety Six
Joined Mar 2008
No question, an aft CG is the key to better thermal performance. You can certainly dial in enough down elevator trim to compensate, but the horizontal stab still has many times more surface area than the elevator and so has a greater influence on the pitch of the fuselage as force (downward force as air flows over the angled stab) is applied. This is acceptable only so long as the forces acting on the horizontal stab do not change the pitch of the fuselage in such a way as to cause the angle of attack of the wing to be come excessive. This would explain why the stock Radian has a tendency to loop under power, balloon up in a head wind, and porpoise in flight whenever optimum gliding speed is exceeded. Moving the CG aft seems to exacerbate those tendencies, as even less force acting on the stab is required to pitch the nose up. My opinion is that the stock decalage angle is perfect for stable flight with the CG set at 2.5 from the LE, within a certain speed envelope. The modified decalage angle seems to allow better performance over a wider variety of flight conditions with the CG set aft to as much as 3.5. Nothing dogmatic here. Its not for everyone. Purely a matter of preference.
chickenwing is online now Find More Posts by chickenwing
Old May 10, 2012, 08:37 AM
kaptondave is offline
Find More Posts by kaptondave
Joined Jan 2010
Does anyone fly a no decalage mod , but has there CG set aft ? ... or it anyone flying Decalage with stock CG ?
The stock horizontal stabilizer setting is the equivalent of having constant up-elevator trim. Flying the mod without moving the cg is like applying down elevator trim as suggested by Kenny. The plane will take a gentle dive attitude, and the offset elevator will add some drag. Neither is good. On the other hand if you just move the cg back without the mod it becomes "tail-heavy" and unstable, as with any plane.
The key is AoA. The goal is to achieve the AoA that will result in the optimum glide angle. AoA is influenced by three things; horizontal stab incidence, elevator trim and CG. Applying various combinations of the three can achieve exactly the same AoA. Thus moving the CG back after doing the mod applies a nose-up force that offsets the nose-down affect of changing the stab angle.
The difference in performance comes from the plane's dynamic response to thermals. The stock decalage acts sort of like a shock absorber in a car's suspension. It damps the pitch-up moments caused by thermals (and wind gusts). The reason for having decalage is exactly that - to make the plane more stable. Removing it makes the plane more sensitive to thermals but also more likely to stall in certain conditions. That is why some say that the mod is not for everyone, or for more experienced pilots only.
kaptondave is offline Find More Posts by kaptondave
Old May 10, 2012, 08:48 AM
Kenny Sharp is offline
Find More Posts by Kenny Sharp
turn, turn, turn.
Athol, Massachusetts
Joined Oct 2005
Thing is, if you move the cg back and re-trim, you've accomplished the same thing.
The extra drag is negligible, and is not noticed.
Kenny Sharp is offline Find More Posts by Kenny Sharp
Old May 10, 2012, 09:06 AM
Radio.Active is offline
Find More Posts by Radio.Active
Closed Account
Joined Aug 2011
Servos
Pulling info from the Radian thread... a recent post mentioned this servo data base site of over 2000 servos
http://www.servodatabase.com/servos/all
Great reference for those who might build their Radians from parts or need to replace a stripped PKZ1060. Unfortunately there are no Parkzone servos in this database.
So... from another post
http://www.rcgroups.com/forums/showthread.php?t=693395
The PKZ 1060 used on the Radian and Radian Pro is speculated to be 28 oz/in"
I've now used the HTX900 HK specials for a couple of weeks in high wind, loops and snap rolls and one nose snapping crash on my Radian and they work fine even though they spec out at about 80% of the PKZ1060's torque.
I'm also using used DSV130M digital metal gear Parkzone servos from a dead Stryker which I suspect is way over spec of the PKZ1060, but, as with all PKZ servos, it is hard to get a spec on them.
Radio.Active is offline Find More Posts by Radio.Active
Old May 10, 2012, 10:18 AM
skyhawk newbie is offline
Find More Posts by skyhawk newbie
Not a newbie anymore..
skyhawk newbie's Avatar
Ireland, Cork
Joined Oct 2010
Thanks for the reply guys...
I was just wondering
As you know one of my Rads does have the Dacalage Mod with CG @ 80mm
While the other one does not and the CG is stock..
I'm still waiting for the right day when I can get a friend to fly my stock Rad and
I'll fly my Decalage moded one at the same time
He's tryed to fly my moded one but found it hard
Yeah... It's not for the inexperienced Radian flyer..
Sean
skyhawk newbie is offline Find More Posts by skyhawk newbie
Joined Jan 2010
The result is not the same. If so Paul Nation, who knows a lot more about the subject than I (and you perhaps?), would not have gone to so much work. However, if it is satisfactory to you that is all that matters.
Old May 10, 2012, 11:17 AM
turn, turn, turn.
Joined Oct 2005
I've done it to my hotliners.... And it is good to understand why and how things happen.
Paul has taught me a lot through his videos... It is why I started going to contests.
I will always defer to Paul.
He's a great guy, and a friend.
Old May 10, 2012, 12:04 PM
Jovanx is offline
Joined Nov 2011
The DSV130M is also used for the flaps on the Radian Pro. Do you know why the flaps would have digital metal-gear servos, and the ailerons have plastic analog ones? I've been wondering about that for a while.
Old May 10, 2012, 01:09 PM
peterlngh is offline
Find More Posts by peterlngh
Joined Apr 2012
Jovanx,
They put stronger servos on flaps because they take a pounding from long grass, or even short grass, when landing. A small plastic geared servo won't hack it.
peterlngh is offline Find More Posts by peterlngh
Old May 10, 2012, 01:32 PM
Jovanx is offline
Joined Nov 2011
It makes sense that metal can take more abuse than plastic, but why digital? I thought that digital servos were supposed to be faster and more precise than analog. Wouldn't that extra precision be of more use on ailerons? It doesn't really matter how fast the flaps go down.
Old May 10, 2012, 01:42 PM
Closed Account
Joined Aug 2011
Old May 10, 2012, 01:49 PM
Closed Account
Joined Aug 2011
Old May 10, 2012, 01:50 PM
Joined Apr 2012
I don't know why they would go digital. Perhaps they don't make an analog with metal gers? Or, perhaps, they just don't make an analog metal geared servo that's the right size?
Question I Need Competition Mods for a Radian Pro Kenny Sharp Electric Sailplanes 4 May 02, 2012 07:08 AM
Help! Lost post on Radian Pro mods - just found it! JBGROS Sailplane Talk 1 Apr 02, 2012 07:27 PM
