Old Feb 16, 2013, 09:53 PM
kaptondave is offline
Find More Posts by kaptondave
Joined Jan 2010
Originally Posted by Maximilionalpha View Post
I have great regard for your ability to achieve such high altitudes with your Radian. I cannot hope to match that, partly because I would be unable to see the plane at those altitudes. Your video however are hard to watch because they are so jerky. I don't think there are two consecutive seconds where the image is stable. Is that because of turbulence? Have you tried any stabilization devices, such as the 3-Axis Flight Stabilizer from Hobby King or the Eagle Tree Guardian?
kaptondave is offline Find More Posts by kaptondave
Old Feb 16, 2013, 10:10 PM
Maximilionalpha is offline
Find More Posts by Maximilionalpha
Maximilionalpha's Avatar
United States, NJ, Rahway
Joined Mar 2012
To be honest with you, kapton, I don't know of any flight video, where there is no form of aided flight, where the video is at all, smooth. I don't use any form of flight stabilizing devices, yet, but have been eyeing the Orange 3-axis flight stabilizer at Hobby King. Not certain if I'll break down and buy it, though, because I tend to enjoy the art of natural un-aided, soaring. I do think that once I get back out into the country-side, where it's more opened at, that I can start back soaring farther out and not in such tight circles, as i do now.
Maximilionalpha is offline Find More Posts by Maximilionalpha
Old Feb 17, 2013, 12:04 AM
Joined Jan 2010
So do I, but natural unaided video - not so much.
Old Feb 17, 2013, 03:08 PM
flohio117 is offline
Find More Posts by flohio117
DroneWorksUSA.net
flohio117's Avatar
United States, TN, Clarksville
Joined Dec 2011
It seems like there's not many people that have used there radian for Fpv. It's a great Fpv platform. I think I'll just buy another one and put tape on the leading edge of the wings and a lil back like the video showed, and maybe a carbon fiber spar. I don't get how people are putting huge batteries in them and still gliding. I added a gopro to my radian once when I was a Fpv noon and it sucked and deff couldn't glide. So how are people adding huge batteries and still gliding?
flohio117 is offline Find More Posts by flohio117
Old Feb 17, 2013, 03:21 PM
DroneWorksUSA.net
flohio117's Avatar
Joined Dec 2011
Old Feb 17, 2013, 03:31 PM
coreman is online now
Find More Posts by coreman
Kit Manufacturer
coreman's Avatar
United States, MA, Southbridge
Joined Feb 2010
weight inside (think ballast) just helps the plane penetrate with everything else the same (ballast up on windy days). The GoPro adds significant drag hanging out in the wind
coreman is online now Find More Posts by coreman
Old Feb 17, 2013, 03:46 PM
DroneWorksUSA.net
flohio117's Avatar
Joined Dec 2011
So if I added a 3300 3s battery can it still glide or will I need to be on the motor? And will oration be able to gain altitude withought using the motor?
Old Feb 17, 2013, 04:15 PM
Kit Manufacturer
coreman's Avatar
Joined Feb 2010
I see no reason why it won't continue to glide fine. It will fly faster and have more inertia when you crash but it should be fine. Your biggest issue with a battery that size is getting it back far enough so you can get the CG reasonable. Drag is the enemy and so you need to deal with that when you start sticking things like a GoPro up in the air flow. If your CG is too far off you will glide worse as well. Many of us have pushed the CG back further than the recommended position and it has improved the glide. I have gone back to about 84mm from the LE (stock is 70mm). If you fly the plane as a glider and not as a power plane you can get about 5 good climbs to a decent altitude on a 1300mah battery from my experience (and still have plenty left for an emergency go around if needed on landing). I regularly get 25 minute flights without even trying hard
Not sure what "oration" is
Old Feb 17, 2013, 04:25 PM
Joined Mar 2012
UPDATE!!! I've made a new cockpit canopy for my Radian! Got tired of the shiny black canopy and made a clear see-through canopy. Vid and stills coming up as soon as I edit and upload them!
Old Feb 17, 2013, 05:13 PM
tlar633 is offline
Find More Posts by tlar633
Joined Aug 2010
The 3300 3S battery will give you a longer motor run. If you mount it as near the CG as possible (still balancing there it will not change your glide ratio (how far forward the plane travels per foot of altitude. So a 20 to 1 glide ratio the plane would travel 20 feet for every foot of altitude lost. What it does do is change the sink rate, that is even though it still goes 20 feet forward for every foot lost in altitude it does not stay up as long conservation of energy laws say it will fly faster but flying faster generates more drag and down it comes. I doubt very seriously if we are even talking 1 minutes difference.
tlar633 is offline Find More Posts by tlar633
Old Feb 17, 2013, 05:28 PM
Kit Manufacturer
coreman's Avatar
Joined Feb 2010
But there's the trick, there isn't a lot of room under the CG to add batter there unless you remount things like moving the Rx under the canopy and removing some foam in that area for the battery to get into
Old Feb 17, 2013, 07:52 PM
Joined Mar 2012
Here's a video of my homemade canopy.
Parkzone Radian's Homemade Clear Canopy (12 min 49 sec)
Old Feb 18, 2013, 12:28 AM
DroneWorksUSA.net
flohio117's Avatar
Joined Dec 2011
Yeah I going to hollow the hull out like crazy
Old Feb 18, 2013, 07:00 AM
Kit Manufacturer
coreman's Avatar
Joined Feb 2010
which will make it more fragile so keep that in mind
Old Feb 18, 2013, 10:11 AM
6Sally5 is offline
Find More Posts by 6Sally5
6Sally5's Avatar
United States, CA, Lincoln
Joined Jan 2011
Good job, Max! Ya know....not everybody has the luxury of a nice shop with special tools and the like...especially when you are first starting out in this hobby. I love seeing people that have the creative ability to figure out how to make things work. I made a vacuum molding machine (see YT vids) and now make alll kinds of parts using that, but it's the same principle you have done on your kitchen table. BTW...good soda and water bottles are made from PETG and so you have a ready-curved, FREE source of plastic as well. Keep up the good work!
6Sally5 is offline Find More Posts by 6Sally5
Question I Need Competition Mods for a Radian Pro Kenny Sharp Electric Sailplanes 4 May 02, 2012 07:08 AM
Help! Lost post on Radian Pro mods - just found it! JBGROS Sailplane Talk 1 Apr 02, 2012 07:27 PM
