Old May 04, 2012, 05:25 PM
skyhawk newbie is offline
Find More Posts by skyhawk newbie
Not a newbie anymore..
skyhawk newbie's Avatar
Ireland, Cork
Joined Oct 2010
Parkzone Radian..Decalage and other Modes..
Paul Naton Decalage Mod.
http://glidefast.typepad.com/glidefa...d-set-ups.html
This is how I did mine..
As it was stock..
Remove the plastic..
Mark 6mm..
On both sides..
Cut it out and make new hole..
Do not throw away..
Stick it back in on the lower part..
Refit plastic..
Move elevator horn closer in..
Move rudder horn..
Cut rubber gap to fit new angle..
My CG set @ 80mm
Sean
skyhawk newbie is offline Find More Posts by skyhawk newbie
Old May 05, 2012, 12:08 AM
Keenan smith is offline
Find More Posts by Keenan smith
was geht , müssen unten kommen
Keenan smith's Avatar
United Kingdom, London
Joined Dec 2010
and how'd she fly Subbed BTW
Keenan
Keenan smith is offline Find More Posts by Keenan smith
Old May 05, 2012, 04:43 AM
Ireland, Cork
Joined Oct 2010
Keenan
Hi Keenan.
The Moded Radian flys very well.
Longer , slower glides.
Theres been a debate going on ( far to long )
on the main Parkzone Radian thread about this mod..
For me it works , the mod is not for every one..
I have two Radian that I fly , one stock the other moded.
A friend at our flying club can fly my stock Radian ,
but cann't fly the moded one as he says its far to sensitive .
Sean.
Old May 05, 2012, 04:46 AM
Joined Dec 2010
so'd you put Dual rates and/or Expo on the Elev?
Old May 05, 2012, 05:23 AM
Ireland, Cork
Joined Oct 2010
You could . .
My settings for the Moded Radian , Flys off my Futaba 9c
Full rate on Aileron / Elevator
D/R 100%
Expo -50%
Half rate
D/R 60%
Expo -50%
Old May 05, 2012, 04:01 PM
Joined Dec 2010
i love gliders with lotsa elevator authority (i hate a mushy elevator response) that way when mixed with plenty of throw you can save yourself from sitcky situations ie a stall and an effective control surface moiving a tiny amount is more effiecient than an uneffective one which needs alot of throw
just my $0.2
Keenans
Old May 05, 2012, 06:03 PM
Ireland, Cork
Joined Oct 2010
just my $0.2
Keenans
CG helps as well..
Old May 05, 2012, 06:14 PM
Joined Dec 2010
@Sean is it as rearward as possible for a more efficient Longer Glide?? and more effective elevator?
Where do you Reccomend i place the CofG on my Venom ?? (it has the same wing shape as the CMpro Ventus minus winglets) and better yet its soon to come Bigger brother the Venom II?
Keenan
Old May 05, 2012, 06:19 PM
Ireland, Cork
Joined Oct 2010
Keenan
What have you got it set at now ?
Old May 05, 2012, 06:23 PM
Joined Dec 2010
i have just Dry fitted both wings and balanced it useing a 4cell nimh 2000mah Rx pack right up near the nose and the CG is at at 43mm From the LE at the mo (my Wings have a lil more Forward Sweep)
all thats left to do is Cut and hinge the Ailerons, Run some Extensions to the aileron servos, Pull a Canopy, Cover the Wings, sheet the Boom balance And Fly!
Keenan
Old May 05, 2012, 06:29 PM
Ireland, Cork
Joined Oct 2010
Keenan
PM sent..
Old May 05, 2012, 06:40 PM
Joined Dec 2010
PM replied too ...
Old May 05, 2012, 07:42 PM
ronht is offline
Find More Posts by ronht
ronht
Joined Sep 2009
I've done this mod and love the difference in performance I now get out of my Radian.
For everyone doing the CG balancing, don't forget to balance the wings horizontially as well. Any trim you have to use to keep the wings level because one wing is heavier than the other is wasting away your energy.
One Chinese Yuan ( about the size of a quarter) in the right wing balanced my wings perfectly.
Ron
ronht is offline Find More Posts by ronht
Old May 06, 2012, 08:15 AM
Radio.Active is offline
Find More Posts by Radio.Active
Closed Account
Joined Aug 2011
Radio.Active is offline Find More Posts by Radio.Active
Old May 06, 2012, 08:35 AM
Closed Account
Joined Aug 2011
Question I Need Competition Mods for a Radian Pro Kenny Sharp Electric Sailplanes 4 May 02, 2012 07:08 AM
Help! Lost post on Radian Pro mods - just found it! JBGROS Sailplane Talk 1 Apr 02, 2012 07:27 PM
