Old May 04, 2012, 12:19 AM
scottieusa is offline
Find More Posts by scottieusa
scottieusa's Avatar
United States, OR, Albany
Joined Oct 2011
Question
Welders glue
So I'm about to build my first 3D foamie. The instructions call for welders glue so I went to my LHS and they have never heard of welders glue. Can I pick up this glue somewhere else? Home Depot? Is there anything comparable? I want to get started on the build tomorrow.
scottieusa is offline Find More Posts by scottieusa
Old May 04, 2012, 12:28 AM
hone1er is offline
Find More Posts by hone1er
Team Twisted!
hone1er's Avatar
United States, CA, Hercules
Joined Dec 2011
Lowes or OSH have it.
hone1er is offline Find More Posts by hone1er
Old May 04, 2012, 12:29 AM
hone1er is offline
Team Twisted!
hone1er's Avatar
Joined Dec 2011
http://www.lowes.com/pd_74526-1168-7...lue&facetInfo=
This is what you are looking for. It also comes in a red tube. Same stuff different color tube for some reason.
Old May 04, 2012, 12:32 AM
JBinAZ is offline
Find More Posts by JBinAZ
JBinAZ's Avatar
United States, AZ, Phoenix
Joined Jun 2011
I have never used welders, but for EPP you can use a product called E-6000 which I hear is very similar. E-6000
You can find this stuff virtually anywhere. Walmart, Ace, Home Depot, etc...
JBinAZ is offline Find More Posts by JBinAZ
Old May 04, 2012, 12:38 AM
scottieusa's Avatar
Joined Oct 2011
Is this stuff different than CA glue?
Old May 04, 2012, 12:43 AM
hone1er is offline
Team Twisted!
hone1er's Avatar
Joined Dec 2011
Yes. CA is very brittle compared to the very flexible welder glue. I used it to build 4 different twisted hobbys 3d epp foamies and it works great. For a more instant stick you smear the welder glue on the surface to be attached put the two pieces together then pull them apart and leave them like that to let the glue tac up for 2 minutes and put the pieces back together. If you put it together wet it takes longer to dry. Welder glue is better for durability.
hone1er is offline
Team Twisted!
hone1er's Avatar
Joined Dec 2011
Works great for repairs too
Old May 04, 2012, 11:53 AM
maxxnut is offline
Find More Posts by maxxnut
Hoarding balsa is a sickness
smokey point, wash.
Joined Dec 2003
Scottie, look at your other thread U started...
http://www.rcgroups.com/forums/showthread.php?t=1645808
maxxnut is offline Find More Posts by maxxnut
Old Sep 17, 2012, 11:32 AM
AZimmerer is offline
Find More Posts by AZimmerer
AZimmerer's Avatar
Joined Jul 2012
My TH Extra slick has a rip on one of the ailerons at the hinge. Any particular or preferred method on using this glue to re-secure. Thanks.
AZimmerer is offline Find More Posts by AZimmerer
Old Sep 17, 2012, 11:37 AM
hone1er is offline
Team Twisted!
hone1er's Avatar
Joined Dec 2011
Just put some welder glue on the hinge and smear it across in a thin layer. Let it dry and you're good to go.
The Welders Glue Hinge (3 min 0 sec)
Old Sep 17, 2012, 12:20 PM
AZimmerer's Avatar
Joined Jul 2012
Excellent. Thanks for the quick response. Hopefully this goes as smooth for me as it does in the video.
Old Sep 17, 2012, 05:05 PM
maxxnut is offline
smokey point, wash.
Joined Dec 2003
Another tip is ti cut a 1 inch long piece of dental floss, cut a slit across the hinge line, near each end, and imbed the floss with welders glue across the hinge line. The floss will stop the tip of the control surface from starting to tear out again.
Old Sep 17, 2012, 08:08 PM
AZimmerer's Avatar
Joined Jul 2012
Nice. I will have to do that as my bird is getting worn and brittle.
Old Sep 17, 2012, 09:09 PM
maxxnut is offline
smokey point, wash.
Joined Dec 2003
I managed to dork my EPP Slicko Saturday, and a dab of welders and it's good as new. If you are getting really beat up, take a look at the Slicko....They should be back in stock before long, and I did a build thread for mine...
http://www.rcgroups.com/forums/showthread.php?t=1681786
Discussion Welder Glue? tdriedger 3D Foamies 36 Nov 15, 2015 06:08 PM
Discussion Welder Glue werlec Foamies (Scratchbuilt) 2 Apr 03, 2010 10:50 AM
For Sale Homax Welder glue Lammergier Aircraft - General - Miscellaneous (FS/W) 1 Sep 11, 2009 03:21 PM
Discussion Welder Glue For Hinges on Grayson Sukoi Glenn L 3D Flying 1 May 18, 2009 02:17 PM
