Old May 04, 2012, 12:58 AM
elliott000 is offline
Find More Posts by elliott000
Canada, BC, Vancouver
Joined Feb 2012
help me make a mix on my aurora 9
I need to set up failsafe on my naza.... I had a switch on my dx8 setup mixing gear/gear by 30 points which offset my gear slector enough to land in failsafe from either flight mode, i cant mix gear to gear on the a9 any ideas?
elliott000 is offline Find More Posts by elliott000
Old May 04, 2012, 04:41 AM
A.T. is offline
Find More Posts by A.T.
Joined Aug 2002
enough to land in failsafe from either flight mode, i cant mix gear to gear on the a9 any ideas? Thanks
. Aurora 9 - TriCopter & MultiCopters has some information on multi rotor craft,
have not seen any NAZA units locally.
. NAZA user manual indicates that failsafe is set within the units own microprocessor.
Auto or Manual modes set separately page 15, so Tx switching does not appear to be
a requirement, nor other gear mentioned.
Need help with Naza failsafe.
Helifreak Multi Rotor - NAZA thread provides some insights on Failsafe but no thread
appears to mention offset between gear selectors with any system.
Perhaps you are referring to a separate item such as
Naza FlameGear Landing Gear in which case, unless you can advise more information
on how the setup works and perhaps what mixing is involved on the other Tx, or someone
else can step in with an answer, please refer to the manufacturer of that unit as it is unknown here.
. After Market Accessories
. An immediate answer may be forthcoming if question is re-posted under
rcgroups.com/multi-rotor-helis where it is more likely to be seen by other NAZA fliers.
Alan T.
Alan's Hobby, Model & RC FAQ Web Links
A.T. is offline Find More Posts by A.T.
Discussion Help my girlfriend make up her darn mind on a heli stevenator128 Beginner Training Area (Heli-Electric) 32 Apr 19, 2012 12:42 AM
Discussion hitec aurora 9 - nose wheel prog mix - TRIM avail ? rcfun2005 Radios 2 Mar 16, 2012 04:12 PM
Discussion Help me! Aurora 9 vs Futaba 8fg super Juan130 Radios 1 Dec 11, 2011 02:30 PM
Question Aurora 9- Heli- Swash mix function JoeR Hitec/Multiplex USA 5 Sep 24, 2010 04:12 PM
Discussion Limited No. of Mix-1,Mix-2 and Mix-3 on Evo-9 sirod Radios 3 Aug 11, 2006 12:35 PM
