Old May 03, 2012, 10:48 PM
Adidas4275 is offline
Find More Posts by Adidas4275
manual flying apologist
Adidas4275's Avatar
United States, CA, Fresno
Joined Mar 2011
Question
Do I need to/can I set the timing and LVC on SimonK's firmware
So I just got done installing my new DYS flashed firmware ESCs in my Y-6 and I hooked up my programming card to set timing to low and NICXX mode for LVC and it would not light up the programming card.
that is when it hit me....... does SimonK's firmware already have LVC turned off?
thanks guys
Adidas4275 is offline Find More Posts by Adidas4275
Old May 03, 2012, 10:53 PM
askman is offline
Find More Posts by askman
Destroyer of G-10
askman's Avatar
United States, OR
Joined Jul 2004
simonK is used as is. no programming. no LVC no calibration. LOL very simple.
askman is offline Find More Posts by askman
Old May 03, 2012, 10:56 PM
pug398 is offline
Find More Posts by pug398
VA
Joined Nov 2009
Nope, no program settings all preset. You do want to do the throttle range calibration on those DYS. Done the same way as before.
pug398 is offline Find More Posts by pug398
Old May 04, 2012, 12:05 AM
Adidas4275's Avatar
Joined Mar 2011
thanks guys.
did throttle range.... and well.... that was it
man it is amazing how much quiter my Y-6 was with the new flashed ESCs!!!!!!
it is like 1/2 the noise and 0 high pitch whine. I would recommend the flashed ESCs just for the noise abatement.
I cannot tell much if it flies better or not, i was doing some forward flight about 20mins ago in gusty wind and it seems to do okay, not like 1000x better than before, but it definitely is not worse....
I LOVE THE NOISE REDUCTION!!!!!
why is it that the noise is literally 1/2 what it is with normal ESCs?
Old May 04, 2012, 12:16 AM
timecop is offline
Find More Posts by timecop
Joined Dec 2010
8kHz vs ~16kHz PWM switching frequency. Openpilot ESC is even better, I think theirs is 40kHz, and CastleCreations firmware can switch between 8/16/24
timecop is offline Find More Posts by timecop
Reply With Quote  (Disabled)
Old May 04, 2012, 12:23 AM
Adidas4275's Avatar
Joined Mar 2011
Open Pilot ESCs!!!!
this is the first i have heard of such and thing.....
so in general the higher the switching frequency the more quite they are? Is there any downside to the higher frequency?
I would love to try out some CC but they are so damn expensive!!!
TC thanks for the info
Old May 04, 2012, 12:28 AM
timecop is offline
Joined Dec 2010
Its the whine that you hear of 8khz switching.
Sounds something like attached .wav
\16khz and above is less audible to human ears, so you don't hear it.
40k is above anyone's hearing capability.
There are other noise factors of course including commutation switching, wind/motor/etc noise, but at least the major source of problem is gone.
Old May 04, 2012, 12:31 AM
Adidas4275's Avatar
Joined Mar 2011
interesting. Thanks. I basically rebuilt my Y-6 tonight due to your recommendation to use reflashed ESCs or CC ones..... and the CC ESCs are like $99 a piece so reflashed it was.
Thanks, again.... i cant really tell a performance difference (yet) but the noise level change was worth the $$ and effort.
Discussion Report on CC's Phoenix 25 ESC's multi-rotor firmware & the WK-M Quad-Copter tkeeg Castle Creations 388 Dec 09, 2015 04:39 AM
Discussion How upgrade firmware (simonk) on Turnigy plush 30a esc slidins15 Multirotor Talk 20 Oct 15, 2012 08:01 AM
Question ESC LVC setting qualls6 Power Systems 3 Mar 21, 2012 03:18 PM
Discussion ESC's that can be set by .1 volts LVC? aman_74 Power Systems 15 Aug 01, 2007 06:02 AM
Discussion How do you set LVC on this controller ?? imxz28 Power Systems 0 Apr 15, 2006 12:31 AM
