Southampton, Ontario CA
Joined Feb 2005
I had the SpyHawk out this morning for a test flight. I'm getting some poor video but I think it's a mismatch in polorization. I tried the pre-amp but it made it worse. The problem with the pre-amp is, if you get a poor signal, it will amplify the interference. I'll try again when I have a cp antenna on the plane. I have the vtx out of the spyhawk already. I'll add an extension and then a female sma adaptor. I'll post pics after completion.
Here is an unedited video, of a flight this morning, I recorded with my GS DVR.
Joined Feb 2005
I was able to remove the vtx from the SpyHawk. Make sure you take some pics and mark each wire where it came from. Much easier to reassemble. I removed the stock cable/antenna from the vtx and added an RG174 extension with a sma female on the end. I just ran the cable forward and up onto a hole I made. It came out very clean looking.
Here is a test video after both CP antennas have been installed. I did not try the pre-amp yet. The results were great! I had the tx pointed down our runnway the whole time.
Joined Feb 2005
Here is a link to the Lawmate av cable that I use to plug into the Hubsan tx. I use the audio channel(white RCA plug) on the lawmate cable and plug it into the video in on the glasses. http://www.readymaderc.com/store/ind...roducts_id=755 |
| Thread Tools | |
| Discussion 60C Gens Ace batteries now in stock | Shortman | Batteries and Chargers | 9 | Oct 19, 2012 04:34 AM |
| New Product Hitec Waterproof Servos now in stock! | ServoCity | ServoCity.com | 0 | Apr 09, 2012 03:34 PM |
| Alert HK-5320 back in stock now! | nemoskull | Indoor and Micro Models | 18 | Mar 19, 2012 08:55 PM |
| New Product Hitec Eclipse 7 Pro (2.4Ghz) now in stock! | ServoCity | ServoCity.com | 0 | Feb 23, 2012 09:22 AM |
