Old Jun 22, 2012, 03:23 PM
Janusz Jawien is offline
Find More Posts by Janusz Jawien
Janusz Jawien's Avatar
Los Angeles Van Nuys, California, United States
Joined Apr 2002
Sorry it did not go as planed.
I think that you tried to tackle too many good things at the same time.
IMHO it would be a good idea to start from scratch and may be focus on profile RC glider
with the shapes of a seagull and add the propulsion later....
Just my two rupies...
BTW you have a really great place for maidens!! Gentle slope with tall grass! WOW!
Janusz Jawien is offline Find More Posts by Janusz Jawien
Old Jun 23, 2012, 07:33 AM
Johannez is offline
Find More Posts by Johannez
Amsterdam
Joined Sep 2005
thnx guys..!
It was definitely tail heavy. strange because the CG was where some flight tests with the wings on another airframe had told me it should be..
I've repaired the wing, the rest is going to take some time. a new inverted-V tail wont take long, but to make the wings stand up more is going to be quite complicated, since the whole structure is build around a straight wingspar.. well, building is the best part anyhow!
Johannez is offline Find More Posts by Johannez
Old Jun 23, 2012, 11:13 AM
Johannez is offline
Amsterdam
Joined Sep 2005
well, that didn't take too long..! I cut out the spar holder from the fuselage, and made a new one with a 15 angle. this brings the wingtips just above the birds centre of gravity. I guess that's what made it tumble upside down so easily, wingloading below the CG.... idiot me.
Old Jun 27, 2012, 05:24 AM
Johannez is offline
Amsterdam
Joined Sep 2005
This is the new body
since I had to cut away the old wingspar, AND wanted to embed the flight controller in the hull more to avoid that 'bulge' on it's back, the foam around the wingspar had seriously weakened. So i decided to make it carbon-reinforced..! I had ordered some carbon thread before, which is very strong but weighs virtually nothing. it litteraly floats in the air like spidersilk! I wrapped it around the spar and the body, and soaked it in superglue. That turned it into little rigid carbon rods.. feels quite strong now!
decide to do the same with the new tail:
I wanted to make it lighter then the previous tail, especially since the bird seemed 'tail heavy', but also stronger. so I used 2 mm depron sheets, instead of 3 mm which i used before, and applied the carbon thread reinforcements.
It came out weighing about the same, they are both around 4.5 grams. But the new one is stronger, and it definately looks better!
I had ordered some new servo's for the wings. they were supposed to have a lot more torque, as advertised on the HobbyKing website.
But when they arrived (very quickly, I must say!) the package mentioned somethnig else. So i decided to test them, just to see if they would be any use.
This is what it revealed...
As you can see the Turnigy 4.4 gr servo, which is advertised as having more than twice the amount of torque, is actually WEAKER than the Hobby King 3.7 gr servo..
I guess what I really need is these .. I have contaced HK and hope they are willing to change.. then I can finnish the wings and it will be time for TEST FLIGHT II.. fingers crossed!
Old Jun 27, 2012, 11:14 AM
hanzie is offline
Find More Posts by hanzie
Fear me, I'm a space-duck.
hanzie's Avatar
Joined Nov 2011
That's a lot of carbon...
hanzie is offline Find More Posts by hanzie
Old Jun 28, 2012, 05:43 AM
G-LO is offline
Find More Posts by G-LO
G-LO's Avatar
Va.Beach VA.
Joined Aug 2007
I think your wings need more dihedral.
G-LO is offline Find More Posts by G-LO
Old Jul 02, 2012, 10:58 AM
Johannez is offline
Amsterdam
Joined Sep 2005
More dihedral, yes, that was the word i was looking for, thanks!
well, she's got more dihedral (about 15 more), she's got a new tail, she's got a carbon re-inforced body and lots of other minor improvements... but I'm still waiting for stronger servo's to build into the wings (No thanks to Hobby King, who send me weaker servo's...).
Beatiful weather today though.... hmmm
..Guess I really need to do some gliding tests!
glijvlucht (1 min 16 sec)
Old Jul 02, 2012, 12:09 PM
Joined Apr 2002
Looks like you are now heading into the right direction !
This chicken is going to be a great flier!...:-)
Old Jul 02, 2012, 04:37 PM
G-LO is offline
G-LO's Avatar
Va.Beach VA.
Joined Aug 2007
Woooow! That was great! Ill say she's ready ...
Old Jul 02, 2012, 06:18 PM
Ken41 is offline
Find More Posts by Ken41
Ken41's Avatar
United States, PA, Clarksville
Joined Aug 2006
Johannez,
Nice work, looks good now, keep up the great work!
Ken
w3kmp
SW PA
Ken41 is offline Find More Posts by Ken41
Old Jul 12, 2012, 08:52 AM
Johannez is offline
Amsterdam
Joined Sep 2005
just thought of something today! very stupid that i didn't think of it before...
Since the CG had to move forward I put 20 grams of lead on the nose, and wrapped it in teflon tape. The CG's on the right spot now but the bird looks quite ridiculous. Like it's muzzled. I hate that..
When I changed the dihedral of the wings, there were some much connection things (like the magnets) allready build in the body, that I could not at the same time move the wings back a bit (instead of moving the CG forward)... I also hated that because I don't like having to ADD weight. but there was no other option. or so I THOUGHT...
Because today I realized I can also make the wings SWEEP BACK a few dergrees, just enough to make the wings' CG aligne with the body's CG!
...should have thought of that when I changed the dihedral. guess now I'll just have to cut the spar out of the wing, move it a few degrees and glue it back in!
At least it'll give me something to do, while im STILLLLLL waiting for those metal gear servo's to replace the wingtwisting thingy..!
Old Jul 12, 2012, 04:24 PM
G-LO is offline
G-LO's Avatar
Va.Beach VA.
Joined Aug 2007
No Johanez! Don't cut the spar! If you want something to do, just make another set of wings. You have a masterpiece.... don't mess it up! Try to find another creative way to add weight. It don't have to look like a muzzle .
This may be weird but just get some heavy duty wire cutters and cut -longe ways- the lead weights; shape then, and apply. What do you think?
Old Jul 12, 2012, 05:11 PM
imyohero is offline
Find More Posts by imyohero
F-OFF
imyohero's Avatar
Joined Mar 2007
Amazing work!
I agree, your glide test looked great leave the wings as is, atleast until a test under power.
Keep up the good work! love it, Fantabulous lol
imyohero is offline Find More Posts by imyohero
Old Jul 12, 2012, 11:42 PM
jj604 is online now
Find More Posts by jj604
ancora imparo
jj604's Avatar
Melbourne, Australia
Joined Jul 2005
Johannez, that's an easy problem. Round here in the city every second seagull you see is snatching a chip (French Fry for the Americans). Model that for instant forward weight.
John
jj604 is online now Find More Posts by jj604
Old Jul 13, 2012, 03:04 PM
Johannez is offline
Amsterdam
Joined Sep 2005
HAHA I like the idea of a chip in its beak..!
But seriously guys, I feel warmed by your pasionate pleas, but now Im hesitating again.. Sure I can find some creative way to hide the weight, but I just dont like the idea of 20 grams of extra added dead weight, when I've done everything I can to build it as light as possible..!
And I wont mess up the wings, I promise.
I can cut out the spar, stuff the hole with foam, sand it back to invisibillity, and then gently carve out a neat new groove using a dremel..
And the wings just needs to sweep back a few degrees. Without the weight, the CG is now like 1,5 cm off. that means (if my wet finger estimations are correct), when I turn the wingtips about 4 cm back, it's CG will be right on the spot. doing so the trailing edge of the wing will dig about 3 mm into the fuselage, and the leading edge will stay 3 mm clear of the fuselage. nothing that is not easily fixed..!
as for the looks; it will look pretty much the same. (The wings are actually slightly swept forward now, so i might just look even better!) It'll just be 20 grams lighter..
Another thing: I recieved my replacement ThunderPower 3S Lipo (last one had a bad cell), and I hooked it up today. The difference in thrust is simply AMAZING..!
With throttle at 1/3, it sounds and feels more or less the same like full throttle with the standard 2s lipo! and then you go up.. slowly.. more and more and more, it just wont stop! Full throttle with the 3S is like holding your own private hurricane! I let it blow in my face and I couldn't breath. It blew my kid away, too. literally! (she's 1,5..
So maybe you're right. lets just hook this baby up and watch it fly first.
Just STIIILLLLL waiting for Hobby King to deliver my new and improved metal gear micro power servo's...........
thanks guys!
Discussion Showdown! Micro EDF Sabre Vs. Micro EDF Mig NitroCharged Micro EDF Jets and Power Systems 132 Dec 16, 2012 11:25 PM
Sold MIG-29 twin 35mm EDF Micro Jet BNF ScottTomasello Aircraft - Electric - Jets (FS/W) 1 Mar 26, 2012 08:54 PM
Discussion MIG-15 a-RC / EDF 70mm - Build and mods.... MADISONMaster Electric Ducted Fan Jet Talk 2 Feb 16, 2012 01:25 PM
Sold Kamdax Mig-15 EDF & Kamdax Mig-15 Pusher Jets Yardbee Aircraft - Electric - Jets (FS/W) 6 Nov 26, 2006 09:40 PM
MiG-15 for EDF 50: micro EDF action! Thomas B Parkflyers 2 Dec 27, 2001 08:27 AM
