Old May 03, 2012, 03:42 PM
*Centurion* is offline
Find More Posts by *Centurion*
Puddle Jumper
*Centurion*'s Avatar
San Diego
Joined Jul 2007
Suggestions on getting into DLG
I'm looking at getting into DLG after flying electrics for the past couple of years, and started looking into some of the competition level birds like the Stobel, SalPeter, ConceptX2 and Polaris to name a few. Please suggest others if you'd like. I've received some feedback from a couple guys associated with the IHLGF, and it appears I should be looking at the higher-end as apposed to some of the other lower-end like many hobby goers recommend for newbies. I know this is speculative, seeing that everyone's experiences are different, but I don't mind making a small investment if it means a better flying outcome.
Obviously, I don't want to break the bank, but I'm going to assume that any of the competition level planes will start at around $800 on up to the thousand dollar range. I don't mind used if I can find them, but my searches on the web have come up short. I've also noticed that finding a vendor, or manufacturer here in the states isn't always easy because a majority of the DLG makers are European. I've seen the list of glider makers here on the forum, so that is a good start, but I definitely feel like I'm shooting in the dark.
Seeing as I'm just getting into gliding, I was hoping you could explain what the different options are when buying a DLG.
What is a disser wing? What are the differences in a carbon vs a competition one?
What is a D Box?
What is RDS and is it important to have?
What is LE, GRP, HMS?
A lot of questions, I know, so if anyone can direct me through the ins-and-outs of DLG it would be greatly appreciated.
Burt
*Centurion* is offline Find More Posts by *Centurion*
Old May 03, 2012, 03:52 PM
ThomasLee is online now
Find More Posts by ThomasLee
Team Hong Kong F3K
ThomasLee's Avatar
Hong Kong
Joined Sep 2010
If you are new to DLG's, I would recommend starting with a bagged plane (or, a solid moulded plane), no matter how good you are with other RC disciplines.
Everyone makes mistakes when they're learning how to launch/etc, and the foam core wings just take a lot more beating than a hollow moulded wing. I've seen a lot of new DLG pilots tip strike, and..well....have fun repairing a hollow moulded wing after a tip strike! haha
Seriously though, I think you will have much more fun and much less frustration if you started off with a cheaper bagged/solid core wing. Some of those bagged planes are very high performance anyway, so you won't be missing too much. In fact, I doubt you will notice performance difference until you've flown DLGs for a while anyway (assuming it's a pretty nice bagged plane ) You can spend $300-$500 for a nice bagged plane, move up to a cool flashy solid/hollow moulded plane later.
Out of the ones you listed, the Polaris is is solid-core, and probably the best choice for you IMHO if you REALLLYYY need to get something expensive and high-performance.
Disser is a wing reinforcement method, using carbon tow placed diagonally across the wing to improve torsional stiffness while keeping the weight low.
D Box is a wing reinforcement method, typically a D-box wing will have carbon on the front 1/3 of the wing for better stiffness and torsional stiffness.
RDS is rotary drive system, really neat way of driving your flaperons as nothing sticks out in the airstream. Personally I like top-drive more.
LE is leading edge
HMS is high modulous *something*..can't remember exact wording...
Don't know GRP
ThomasLee is online now Find More Posts by ThomasLee
Latest blog entry: Vibe Assembly Instructions
Old May 03, 2012, 03:58 PM
Wazmo is offline
Find More Posts by Wazmo
Duane, LSF IV
Wazmo's Avatar
No. VA
Joined Nov 2004
GRP = Glass Reinforced Plastic, typically fiberglass/epoxy composite though it can be nylon or other plastics, as with propellors.
Wazmo is offline Find More Posts by Wazmo
Old May 03, 2012, 04:22 PM
davidjensen is offline
Find More Posts by davidjensen
Will fly for food
davidjensen's Avatar
Bellevue WA,
Joined Dec 2003
The learning process of assembly of a DLG is enough to get a lower end model. Nothing worse than screwing up a high $$$$ ship due to inexperience when building.
davidjensen is offline Find More Posts by davidjensen
Old May 03, 2012, 04:36 PM
glidermang is offline
Find More Posts by glidermang
Burt:
You can always go to the Classifieds, but be prepared to move FAST if you see an attractive one.
Like Mr. Lee says, look for a bagged wing (Taboo, Predator, TopSky) to start, if you're looking for F3K-compliant.
If you're just looking to have fun, look at the Gambler, the DL-50 or Quik-Flik. Not F3K, but still a huge amount of fun for the dollar. Several guys around htese parts have them, and once the serious flying is over, out they come! Kits for each are no more than $100.
Yours, Greg
glidermang is offline Find More Posts by glidermang
Old May 03, 2012, 04:44 PM
Puddle Jumper
San Diego
Joined Jul 2007
Hey guys,
I'm definitely not apposed to going with a lower-end model. I actually started looking at some of those, but they were all recommend against. I also don't want to be the guy who brings out the nice expensive Cadillac and crashes on the first flight.
I would like to hear some of your suggestions, please. Besides some of the competition grade, what do you recommend that will fly well enough, build somewhat easily, and get me flying sooner rather than later?
@ThomasLee: When you say bagger, I'm assuming you mean something you wouldn't mind making mistakes with? I do like the price range of $300-$500 much better for a starter.
Here are some of the others I found that might not pass for competition, but are very nice starters. Please feel free to amend.
Vandal
Blaster3
Elf
Gladiator II
Fireworks III Disser
Bob, from Soaring USA, told me that they are coming out with a DLG called the Dart with a kevlar molded foam core wing. Does anyone have more info on this?
TopSky 2.0
I'm sure the list could go on and on. Keep in mind that some of the birds in the list above were not recommended to get, so it does throw me for a loop. What are your thoughts?
Burt
Old May 03, 2012, 05:08 PM
Team Hong Kong F3K
ThomasLee's Avatar
Hong Kong
Joined Sep 2010
Hi Burt,
Bagged planes are made with a solid foam core (usually hot-wire cut), with skins applied over that and 'bagged' in a vacuum bag.
Moulded planes are typically hollow, and takes the shape of the mould rather than the foam core, and thus is more accurate. There are some really cool solid moulded stuff on the market now though.
Most of the planes in that list are hollow moulded and quite fragile.
I would recommend the following planes, in order of cost:
Predator 2 $240
Predator 2 Dbox $350
TopSky 2 super $320 (?)
Neos $399
Akcent 2 $475
Neos Dbox $499
Validol $595
Also, the Taboo GT and Vandal are great planes, I think you will need to look in classifieds for those though (please correct me if I'm wrong!)
Though I am biased!
Old May 03, 2012, 05:17 PM
austinhlg is offline
Find More Posts by austinhlg
United States, MD, Baltimore
Joined Feb 2007
Don't forget acksent 2 or validol reasonably priced moldie with rugged foam core and excellent fligh characteristics.
austinhlg is offline Find More Posts by austinhlg
Old May 03, 2012, 05:18 PM
Team Hong Kong F3K
ThomasLee's Avatar
Hong Kong
Joined Sep 2010
You're right! I'll have to add those to the list
Old May 03, 2012, 05:22 PM
bwill6 is offline
Find More Posts by bwill6
United States, CA, Tehachapi
Joined Jun 2011
I'll second the solid core wing recommendation. "Bagged" and "molded" are different construction methods. Molded gliders are built just as the name implies -- in a mold. This guarantees the most accurate airfoil shape possible. Now there are two distinct types of molded planes: solid core and hollow molded. Solid core is done by cutting out a foam wing with a CNC router and placing it in the mold between the carbon/fibeglass skins. Hollow molded wings are made with the skins being a sandwich -- glass/carbon, then thin foam (~1mm), then another layer of glass on the inside (look at the pictures of the Blaster's construction HERE). They're hollow inside, which is why they are so much harder to repair. "Bagged" planes are made by cutting the wing out of foam (usually with a hotwire cutter), covering with the fiberglass/carbon, and then placed in a bag under high levels of vacuum to press the skin to the core while it cures. This is a much cheaper method of production, but results in a slightly less accurate wing. It's not hollow, though, making it easier to repair.
It takes time to get up to speed with the F3K jargon, but you'll get there. There are a number of fine planes you can choose from, and since you seem interested in something that you can learn on while still being competitive, I'll suggest the following:
Solid Core Molded:
Polaris (made by Momentum Models if I remember correctly) ~$1000 I think
Helios (made by krikkens and distributed by Wave Glider in the US) -$665
XXLite (same manufacturer/distributer as Helios) - $730
Validol
Bagged:
Neos (I'm pretty sure it's bagged)
One of Seba's (prsly on RCG) kits (plane has no name that I'm aware of, but I've seen these up close and they're fine workmanship)
Predator II (never seen one, but I've heard good things about them)
Brandon
P.S.: Welcome to the addiction!
Edit: inlcuded Validol, too. Didn't realize it was solid core.
bwill6 is offline Find More Posts by bwill6
Old May 03, 2012, 05:36 PM
Puddle Jumper
San Diego
Joined Jul 2007
Guys,
Thanks so much for all the information. It is a huge help, believe me. There is a lot of good information so far, and will refrain from commenting individually until I've soaked it in a little more, but off the top, I do remember looking at the Validol and being very impressed. I also like the looks of the Neos, and from what their website says, has a brand new version out.
Please keep the information coming.
Burt
Old May 03, 2012, 06:34 PM
Will fly for food
Bellevue WA,
Joined Dec 2003
It will also take time on the sticks to learn what these DLG can do and more importantly what not to do. How do you fly in windy conditions? This is when 90% of the damage happens to DLG's. This is why you want a good inexpensive robust DLG. Just learning how to release smoothly without torquing on the launch peg takes some time when you start to really put the power to it. You don't want your peg ripped out of your steg. These lessons will be learned and the $$$$ to learn them is the decision. The Topsky 2 and Disser are very good for the AG series of DLG's.
Old May 03, 2012, 07:09 PM
tom43004 is offline
Find More Posts by tom43004
Father of Fr3aK, DLG Pilot
tom43004's Avatar
USA, OH, Worthington
Joined May 2002
Buy whatever gets you in the air quickly and fly fly fly fly fly. Worry about high performance and pretty later.
Used = cheap and fast.
Take it from a guy who spends HUNDREDS of hours making airplanes for other people... you'd rather be flying than building. As soon as you get your first one in the air, start building your second. This way you can take your time, do it right, and learn about construction and assembly WHILE you have a flyable airframe.
tom43004 is offline Find More Posts by tom43004
Old May 03, 2012, 08:15 PM
Mr. Wiz is offline
Find More Posts by Mr. Wiz
Time for me to Fly...
Mr. Wiz's Avatar
United States, MI, Fenton
Joined Jan 2000
Burt if you want to get your feet wet without breaking the bank take a look at this offer I made to another fellow that was refused.
Mr. Wiz is offline Find More Posts by Mr. Wiz
Old May 03, 2012, 11:08 PM
Puddle Jumper
San Diego
Joined Jul 2007
Originally Posted by ThomasLee View Post
Hi Burt,
Predator 2 $240
Neos $399
Akcent 2 $475
Neos Dbox $499
Validol $595
Though I am biased!
What is really setting the high-performance gliders apart from something in the nice $500 solid core range?
Is it worth the extra money to have the RDS installed? Is this option usually available on most gliders? What are the negatives if this isn't an option, or I don't install it?
Discussion Getting into Q500, need suggestions countilaw Pylon Racing 1 Apr 24, 2012 06:56 PM
Discussion Lessons on Getting Back Into R/C tdogg77 Beginner Training Area (Aircraft-Electric) 3 Feb 29, 2012 02:42 PM
Discussion Want to get into FPV - any suggestions for aircraft Adroc3905 Multirotor Talk 7 Feb 09, 2012 08:27 AM
Discussion Need help on getting into FPV VegasFreak FPV Talk 1 Jan 17, 2012 08:59 PM
Mini-HowTo Getting into RC flying on the cheap. lunarnexus Beginner Training Area (Aircraft-Electric) 17 Nov 18, 2011 06:42 PM
