Old May 03, 2012, 03:24 PM
soprano1 is offline
Find More Posts by soprano1
RES flyer
Portland, OR
Joined Feb 2009
Brushless ESC with a brushed motor
I have an old Speed 480 sailplane that I originally flew on Nmih. It has an old Jeti brushed ESC. I want to switch to Lipos to save the weight. I plugged in a Lipo pack to the old ESC and it worked fine - until the next day when I went to charge the Lipo pack and discovered 2 dead cells. I have a new brushless ESC. I would rather use it now that than replace the old 480. Will the old 480 work with the brushless ESC if I just connect the + and - and leave the white lead from the ESC unconnected?
soprano1 is offline Find More Posts by soprano1
Old May 03, 2012, 04:57 PM
Marion is offline
Find More Posts by Marion
Marion
USA, NC, Hillsborough
Joined Oct 2003
No. It doesn't work that way at all. Do not try it, please.
Marion is offline Find More Posts by Marion
Old May 03, 2012, 04:58 PM
slipstick is offline
Find More Posts by slipstick
Staffs, UK
Joined Nov 2003
No. There is no + and - output from a brushless ESC,. All 3 wires do the same thing and it doesn't include driving a brushed motor....the way the ESC works is completely different.
Steve
slipstick is offline Find More Posts by slipstick
Old May 03, 2012, 05:00 PM
Bruce Abbott is offline
Find More Posts by Bruce Abbott
We want... Information!
Bruce Abbott's Avatar
Hastings, New Zealand
Joined Jan 2001
No, it won't work.
If you are worried that your Jeti might be over-discharging the Lipo, limit your motor run time to 2 or 3 minutes, then check that the battery hasn't gone below 11.1V. If your radio doesn't have a timer then just count off the seconds for each motor run (eg. 30 seconds x 4 runs = 2 minutes).
Bruce Abbott is offline Find More Posts by Bruce Abbott
Old May 03, 2012, 05:04 PM
Piece is offline
Find More Posts by Piece
Wake up, feel pulse, be happy!
Piece's Avatar
Joined Aug 2009
You could also get a brushed ESC with a lipo cutoff function. They're pretty inexpensive these days.
Piece is offline Find More Posts by Piece
Old May 03, 2012, 06:01 PM
soprano1 is offline
RES flyer
Portland, OR
Joined Feb 2009
Thanks for the input folks! I think my brushed ESC may have killed my Lipo pack. I'll use my Nmih until I get the motor replaced.
Old May 04, 2012, 02:25 AM
abenn is offline
Find More Posts by abenn
Letchworth, Great Britain (UK)
Joined Jul 2004
You didn't leave the pack plugged in until you went to charge it next day, did you? That could drain any battery.
The older Jeti ESCs are programmed to shut down (lvc) when the battery voltage reaches 68% (I think) of what it was when the battery was plugged in. For a fully charged LiPo at 4.20v that'll be 2.86v for lvc, which is far too low. It's even worse if the battery wasn't fully charged when it was plugged in.
Other than that, there's nothing about the ESC that makes it unusable with a LiPo. If you want to use LiPo you simply need to time your flights so that you stop flying before 80% of the battery capacity has been used. In fact, that's true even for "LiPo friendly" ESCs, for lvc should only be regarded as a safety feature, not as your regular indicator to stop flying.
abenn is offline Find More Posts by abenn
Old May 05, 2012, 01:10 PM
soprano1 is offline
RES flyer
Portland, OR
Joined Feb 2009
Thanks abenn. Very valuable info. I think I may have left the batteries plugged it
Sold Brushed motors, Brushed ESCs darmar Aircraft - Electric - Power Systems (FS/W) 0 Jan 30, 2012 11:00 AM
Found WTT: My Pro Boat Brushless ESC for your Pro Boat Brushed ESC Diegoboy Boats (FS/W) 12 Dec 23, 2011 09:48 PM
Sold Zagi XT Twin NIB complete with zagi brushed motors, esc, & battery $45 phoneguy Aircraft - Electric - Airplanes (FS/W) 5 Oct 19, 2011 08:16 PM
Sold Zagi XT Twin NIB complete with zagi brushed motors, esc, & battery (LPU) $50 phoneguy Aircraft - Electric - Airplanes (FS/W) 1 Oct 16, 2011 03:33 PM
