Old Aug 02, 2012, 06:50 PM
Jboy90277 is offline
Find More Posts by Jboy90277
United States, CA, Palos Verdes Peninsula
Joined Dec 2011
Originally Posted by docbrew View Post
Noob with a few questions. This is my first foamy and my first electric so bear with me.
Since the motor has been out of stock I've been looking at the rim fire 250. Will this be a good motor for this plane?
I'm not sure how to fix this but the directions recommended putting a thin layer of glue on the hinge so I did. I thought well if one side recommended the other side would be better. Umm...not really. Now my hinge joints are very tight and dont seem to want to move much even after flexing them quite a bit. Any ideas on how to resolve this?
I will say I'm very excited to get this bird in the air after reading this thread. I'm a decent park flier and this is my first 3Der. Heck prior to this summer the last time I flew an RC plan 3D flying wasn't heard of.
You may want to seek additional advice, but one thought about the hinge issue is to cut the hinge completely through with a blade, butt the 2 pieces together and reapply welder to just the top side so the dried welder between the pieces becomes the hinge. The welder makes a strong hinge from my experience fixing hinge tears on a number of planes (EPP and EPO).
Jboy90277 is offline Find More Posts by Jboy90277
Old Aug 02, 2012, 06:53 PM
KamikazePilot is offline
Find More Posts by KamikazePilot
Twisted Do Nut!
KamikazePilot's Avatar
Joined Dec 2010
Welcome to the club and forum Doc.
Can't help you with the motor. But I can with the hinges, if you have some acetone handy it will soften up the hinges. It's how I do it, plus it's how I reuse parts when the airframe is shot.
KamikazePilot is offline Find More Posts by KamikazePilot
Old Aug 02, 2012, 06:56 PM
IndyMatt is offline
Find More Posts by IndyMatt
Indianapolis, IN
Joined Oct 2010
I switched my motor/esc out with a working combo from another foamy, all is well. Weird thing is that it worked fine without a prop, once the prop was on it cogged or stuttered. I put it on another plane with a different/smaller propellor and it works just fine with the smaller prop.
Not sure what all this means but I will be ordering more batteries!
Also I have been using some 500mah batteries that are around 31grams, I have some two cell 1000mah batteries that weight in at 57grams but I wasn't sure whether the greater weight would kill the flying characteristics of the plane.
IndyMatt is offline Find More Posts by IndyMatt
Old Aug 02, 2012, 07:35 PM
Stark is offline
Find More Posts by Stark
Don't worry be happy :)
Stark's Avatar
Joined Sep 2001
Originally Posted by KamikazePilot View Post
...But I can with the hinges, if you have some acetone handy it will soften up the hinges. ..
Wouldn't that destroy the graphics?
Stark is offline Find More Posts by Stark
Old Aug 02, 2012, 07:44 PM
Stark is offline
Stark's Avatar
Joined Sep 2001
...Since the motor has been out of stock I've been looking at the rim fire 250. Will this be a good motor for this plane? ....
I do think the 250 is to small. The Rim fire 300 on 3 or maybe 2 cell lipo is a much better choice as I see it.
Old Aug 02, 2012, 08:15 PM
Twisted Do Nut!
Joined Dec 2010
Thanks for pointing that out Stark. I should have mentioned apply the acetone to a rag and rub the inside hinge. It'll take some of the welders off and soften the hinge enough to work smoother. Working the hinge back and forth afterwards will help as well. The outside of the hinge is really the only place that could use the welders to help from tearing.
That is strange Matt. Maybe the prop not balanced could be the cause. What size prop were you using? Adding weight does effect the flying. More weight better windy day flying, less weight more floaty it flys.
Old Aug 02, 2012, 08:23 PM
carr52 is offline
Find More Posts by carr52
carr52's Avatar
United States, SC, Irmo
Joined Mar 2012
I bought one of these just for the heck of it. Thought it might be worth a shot.
http://www.headsuprc.com/servlet/the...ushless/Detail
carr52 is offline Find More Posts by carr52
Old Aug 02, 2012, 08:34 PM
Joined Dec 2011
Sounds like your magnets may not be strong enough to swing the bigger prop. Have you ever gotten them very hot - they tend to demagnetize after a certain temp.
The heavier batteries will change the way the plane flies. The biplane can probably handle it in flight, but you will be carrying more inertia if you crash, and it will likely cause more damage than you normally would see.
Old Aug 03, 2012, 08:01 AM
IndyMatt is offline
Indianapolis, IN
Joined Oct 2010
I tested two motors right out of the box they are these:
http://www.hobbyking.com/hobbyking/s...idproduct=8618
I just think it is a stretch for the bigger props. I found a good replacement, I think, for the TH motor. It is at value hobby:
http://www.valuehobby.com/power-syst...or-1660kv.html
Should work fine and still be lightweight. I like the 300 size motors but most of the time you need to step up the size of your ESC. I think the added weight would kill the handling and cause more damage in a crash.
Originally Posted by Jboy90277 View Post
Sounds like your magnets may be strong enough to swing the bigger prop. Have you ever gotten them very hot - they tend to demagnetize after a certain temp.
Old Aug 04, 2012, 04:50 PM
3171scott is offline
Find More Posts by 3171scott
3171scott's Avatar
United States, OH, Youngstown
Joined Apr 2011
I love the 250 and will be installing one on my Crack Slick, not sure if it will have all the pullout power you might want with the Pitts. I flew this on a 6oz monoplane and it was blistic on 2S. If you dont need all the power in the world i wouldnot be afrade to try it. If you are used to Gobs of power i would look in to something else.
3171scott is offline Find More Posts by 3171scott
Old Aug 04, 2012, 05:11 PM
STLAV8R is offline
Find More Posts by STLAV8R
STLAV8R's Avatar
United States, MO, St Louis
Joined Jan 2009
Originally Posted by Twisted Realm View Post
There will be a small delay since we requested the factory to revise the hub diameter. They should ship early next week.
The revised motor just came in the mail. I think I am one of the last houses in the area to get the mail. Anyway...it's here. The prop fit a little loose without the prop saver on. I was thinking, oh no! But after the prop saver was put on, no slop was noticeable.
Will screw the motor on and have enough daylight to get in several flights. Woo-hoo!
STLAV8R is offline Find More Posts by STLAV8R
Old Aug 04, 2012, 05:50 PM
Twisted Do Nut!
Joined Dec 2010
That motor looks interesting Tom. Going try it out on your Pitts?
STLAV8R, I thought the prop saver was built into the can. Got any pics to clarify what you mean?
Old Aug 04, 2012, 06:24 PM
carr52 is offline
carr52's Avatar
Joined Mar 2012
Me? If so the answer is no. I just saw it and thought it looked like a really strong other choice. I plan touse it on a wing I'm building. As for my TH planes I use the TH power combo only. Big fan here. But I should have the wing up and flying mid week with that motor.
Tom
Old Aug 04, 2012, 06:54 PM
carr52 is offline
carr52's Avatar
Joined Mar 2012
If your looking for a cheap replacement motor till the TH motors come back in stock this looks pretty good. Not sure how it'll work out but for the price what the heck.
Tom
http://www.headsuprc.com/servlet/the...-Slofly/Detail
Old Aug 04, 2012, 08:50 PM
docbrew is offline
Find More Posts by docbrew
docbrew's Avatar
United States, TN, Gallatin
Joined Aug 2012
I did put the 250 on the pitts and it seems to fly it well but I don't have anything to compare it to. The problem I'm having now is balance. The tail is heavy even with the battery mounted all the way forward.
docbrew is offline Find More Posts by docbrew
Cool Twisted Hobbys - 32" Crack Yak - Build Thread (Lots of new pics!) hercdriver7777 3D Foamies 6649 Yesterday 11:50 AM
Discussion Official-Twisted Hobbys Extra Slick 32" Slickinsaneness Build/Fly Thread Tom K. 3D Foamies 1377 Apr 06, 2016 06:24 AM
Build Log Twisted Hobbys - Telink 3D Buster EPP Bipe Build Thread, Flight Video just posted!!!! aerofundan 3D Foamies 578 Apr 21, 2015 04:01 AM
Wanted Twisted Hobbys - 32" Crack Yak Wanted Moparbob Aircraft - Electric - Airplanes (FS/W) 32 Jul 10, 2012 06:36 PM
Sold Twisted Hobbies Crack Yak isenbed Aircraft - Electric - Airplanes (FS/W) 4 Apr 16, 2012 10:43 PM
