Old Jul 16, 2012, 04:38 PM
Aviefly is offline
Find More Posts by Aviefly
Aviefly's Avatar
United Kingdom, Aviemore
Joined Feb 2005
The real REAL question is...is that your painted toe nails?
Aviefly is offline Find More Posts by Aviefly
Old Jul 16, 2012, 04:46 PM
SD One. is offline
Find More Posts by SD One.
My hovercraft is full of eels.
USA, TN, Gallatin
Joined Aug 2009
That is a good question.
I screwed up long ago and used the polarized Micro Deans plugs on all of my light foamies. Now I have the added cost of a new set of plugs for every two packs which isn't bad, but it sucks when you are out of them and none of your buddies use them. I kinda wish I had just stuck with JSTs since learning that the protruding positive pin on the Micro Deans plug can short against the ground in the balance tap and we all know what comes after that.
SD One. is offline Find More Posts by SD One.
Old Jul 16, 2012, 05:02 PM
Aaeolien is offline
Find More Posts by Aaeolien
3d addict
United States, NY, Rochester
Joined May 2011
Lol avie no those are not my painted toenails. My wife thought it would be fun to play nail painting with our 3 years old son last night. So those are his.
Aaeolien is offline Find More Posts by Aaeolien
Old Jul 16, 2012, 05:07 PM
Aviefly is offline
Aviefly's Avatar
Joined Feb 2005
I'm beginning to think my Crack Pitts is jinxed. First I splash out on quality servo's only to have one of them go dead on the maiden. Got that sorted and then the z bend comes off the carbon rod on the rudder. Fixed it by getting it back inside the heat shrink and wicking thin CA in, seemed to do the trick till I got out to the field tonight and it went again on the first flight. I was right bummed as I've been waiting to have a real good go on 3S Anyway got home took the rod right out and carefully cut off the heat shrink and the old CA with a scalpel, got it right down to clean carbon. Cleaned off the z bend, gave both the z bend and the carbon a good roughing up and did it again from scratch. Would you believe that with the z bend in the rudder horn that the carbon is flexible enough to allow you to bend it round and thread it back through the guides up to the servo. Hopefully that should be it now, it's odd I've not had a single one go on any of the others. I did manage to get out the back and give it a test flight as it was dropping dark, gota say I think I'm gona like 3S on this, can't wait to give it a better go now.
For anyone interested here's the results of testing my different motor combinations. First the X Series 1800kv on 2S with an eight inch prop, didn't test that one on 3S as I didn't think it would be the right motor for it, I may do so though just to see what numbers it gets and see if the motor can handle it. Then the Crack Series motor on 2S with a nine inch prop then 3S with eight inch. We also have some X Series 1480kv motors and although they aren't rated for 3S they seem to handle it so I tested it with both 2S and nine inch prop and 3S with eight, I flew it on my Edge with 3S tonight after my upset with the Pitts and the power was amazing and the motor still came down stone cold. It could be a fine option for 3S but it would need some work on the throttle curve unlike the Crack Series motor. Both the Crack Series motor and the X Series motor hit three figure watts on the initial burst
Old Jul 16, 2012, 05:17 PM
Jboy90277 is offline
Find More Posts by Jboy90277
United States, CA, Palos Verdes Peninsula
Joined Dec 2011
If it goes again, I would wind thread or unwaxed dental floss around the metal and carbon fiber before hitting it with CA for a more secure connection than shrink tubing (method I learned from building my PA Ultimate AMR).
Jboy90277 is offline Find More Posts by Jboy90277
Old Jul 16, 2012, 05:19 PM
Aviefly is offline
Aviefly's Avatar
Joined Feb 2005
Yeh never though about that at the time but I've used that method before. I'll go for that if it goes again, Cheers.
Old Jul 16, 2012, 05:52 PM
JohnRB is offline
Find More Posts by JohnRB
United States, NC, Raleigh
Joined Oct 2011
I assume you were talking about the X Series 1450kv motors.
I made some measurements with one of those motors near the end of June using the same brand meter. My results are below and they are in line with what you have found.
Outrunner "Crack Series" 24g 1450KV Brushless Motor
9x4.7 Tuff Prop
2S 450mA 7.87V at start of test
5100 RPM 7.3A 50W
8x4.3 Tuff Prop
2S 450mA 7.33V at start of test
6850 RPM 4.677A 33W
8x4.3 Tuff Prop
3S 450mA ?V at start of test
9340 RPM 7.76A 88W
JohnRB is offline Find More Posts by JohnRB
Old Jul 16, 2012, 07:31 PM
nkhamlue is offline
Find More Posts by nkhamlue
Build em lite......
Joined Apr 2012
Winding thread is a very good idea. I have had 3 of the Z bends come off the CF pushrod. Since winding with thread and soaking with thin CA, no problem. My last Crack build I used thread during the initial build. Well worth the peace of mind with absolutely no downside.....
nkhamlue is offline Find More Posts by nkhamlue
Old Jul 16, 2012, 08:40 PM
Aaeolien is offline
3d addict
Joined May 2011
Doh I had one pop off tonight and forgot you guys were talking about using the thread. Put it back together without it. Well next time. Lol.
Old Jul 16, 2012, 08:45 PM
pugsam is offline
Find More Posts by pugsam
LiPo-Sucker & Airframe EMT
pugsam's Avatar
Charlottesville, Virginia, USA
Joined Aug 2010
For those into truly *twisted* hobbies.........
pugsam is offline Find More Posts by pugsam
Old Jul 16, 2012, 08:52 PM
Aaeolien is offline
3d addict
Joined May 2011
Lol. You guys crack me up.
Did a bunch of flights tonight. The gens ace batteries are definetly decent. Bought the 450mah 2s ones from hobbypartz. Was getting a solid 5 minutes of flight with plenty of power left. Charging now so will see how much actually goes back into them.
Couple of cartwheels tonight due to KE a little low. Haha. Worked on a lot of that and a bunch of inverted harrier flying. Finally getting comfortable with both. New favorite thing is inverted a foot off the ground with a roll to land. Pretty awesome.
Perfect night tonight. No wind at all. Wish I hadn't busted off an aileron connecting rod or I woulda flown a whole bunch more.
Old Jul 17, 2012, 05:48 AM
Gravitycheat is offline
Find More Posts by Gravitycheat
Don't give in to gravity
Gravitycheat's Avatar
USA, FL, Palm Harbor
Joined Dec 2009
Originally Posted by Aaeolien View Post
I think I should have enough now. Wel maybe.
Thats only twelve?? What if something happens to one? Then there would only be eleven! You have to think ahead man!!
Gravitycheat is offline Find More Posts by Gravitycheat
Old Jul 17, 2012, 06:12 AM
Aaeolien is offline
3d addict
Joined May 2011
I'm pretty sure hobbypartz will send me more when I give them money. I case something happens to one. Hahaha.
Old Jul 17, 2012, 09:16 AM
KamikazePilot is offline
Find More Posts by KamikazePilot
Twisted Do Nut!
KamikazePilot's Avatar
Joined Dec 2010
I'd send you some of mine but my planes wouldn't like me very much. Oh wait, with how I fly they don't like me anyways.
I been flying in wind for so long I forgot what it was like to fly in calm weather. Got about a hours worth before the winds came up Sunday. Man it's much more fun when you're not fighting 15 to 25 mph winds.
KamikazePilot is offline Find More Posts by KamikazePilot
Old Jul 17, 2012, 09:21 AM
SD One. is offline
USA, TN, Gallatin
Joined Aug 2009
Well it didn't take long before mine hit the ground in an unintended way. I was practicing rollers too low in the yard last night and bounced it pretty good. No damage to plane or prop.
This is what I use for my O-rings. It's cheap and will make more rings than I'll ever need. It lasts a lot longer than the green tubing and doesn't dry rot as fast. If you need it tighter, just slice off a thicker ring. I use it on all of my foamies, my quadrotor and it holds the wings together nicely on the larger Skywing/Hokusei/3DHS hybrids... good stuff.
Cool Twisted Hobbys - 32" Crack Yak - Build Thread (Lots of new pics!) hercdriver7777 3D Foamies 6697 Jul 17, 2016 11:17 AM
Discussion Official-Twisted Hobbys Extra Slick 32" Slickinsaneness Build/Fly Thread Tom K. 3D Foamies 1377 Apr 06, 2016 06:24 AM
Build Log Twisted Hobbys - Telink 3D Buster EPP Bipe Build Thread, Flight Video just posted!!!! aerofundan 3D Foamies 578 Apr 21, 2015 04:01 AM
Wanted Twisted Hobbys - 32" Crack Yak Wanted Moparbob Aircraft - Electric - Airplanes (FS/W) 32 Jul 10, 2012 06:36 PM
Sold Twisted Hobbies Crack Yak isenbed Aircraft - Electric - Airplanes (FS/W) 4 Apr 16, 2012 10:43 PM
