Old May 05, 2012, 06:48 PM
buster7467 is offline
Find More Posts by buster7467
morgantown, wv
Joined Mar 2004
I got mine ordered this morning and it already shipped out. I will get it on monday. I also was going to wait to order the power system combo in a week but went ahead and just ordered it. It will probably not get shipped until monday and i will receive it on weds. That will work out alright because i am off work on weds. I hope to get it built and ready to fly that day.
buster7467 is offline Find More Posts by buster7467
Old May 05, 2012, 07:05 PM
STLAV8R is offline
Find More Posts by STLAV8R
STLAV8R's Avatar
United States, MO, St Louis
Joined Jan 2009
Originally Posted by e-gull View Post
Is the Beacon 527 better than Beacon Foam-Tac? The guys in the group I fly with use Foam-Tac so that is what I bought.
Was wondering the same thing...At Michaels they had 527 but didn't have Foam-Tac...
STLAV8R is offline Find More Posts by STLAV8R
Old May 05, 2012, 07:53 PM
jetinteriorguy is offline
Find More Posts by jetinteriorguy
Burke, VA
Joined Sep 2009
I have used them both and they both work excellent, I would say that the 527 has a better consistency for gluing EPP but the odor is stronger and setup time is a little longer.
jetinteriorguy is offline Find More Posts by jetinteriorguy
Old May 05, 2012, 08:01 PM
morgantown, wv
Joined Mar 2004
Does anyone have an idea what the flight times should be with the 2s setup and the power system from twisted hobbys? Just kinda curious.
Old May 05, 2012, 08:02 PM
hone1er is offline
Find More Posts by hone1er
Team Twisted!
hone1er's Avatar
United States, CA, Hercules
Joined Dec 2011
I don't know but i want to see a 3s video. This thing will be cracked out on 3s
hone1er is offline Find More Posts by hone1er
Old May 05, 2012, 08:39 PM
STLAV8R is offline
STLAV8R's Avatar
Joined Jan 2009
Think I will just stick with the Welders then.
Old May 05, 2012, 10:33 PM
Burke, VA
Joined Sep 2009
It's the best, I keep several tubes on hand at all times. I even use it to assemble balsa's. I use it as a filet on the wings and stab for added strength.
Old May 05, 2012, 10:40 PM
toolman18 is offline
Find More Posts by toolman18
toolman18's Avatar
United States, TX, Portland
Joined Apr 2008
Originally Posted by Gravitycheat View Post
Also, this plane has so much side area that you will need some rudder to turn. The nose will stay high if you just bank and yank...this is good training and it will help you get used to using the rudder. If you are a newer pilot and you are having trouble making coordinated turns, you can do an aileron -> rudder mix of about 40%...so left aileron gives 40% left rudder, and right aileron gives 40% right rudder. This will help with your turns as you learn...put it on a switch though; it will really screw up harrier rolls if you try to fly those with the mix on!
It's a little like saying "It's a great boat but it dosen't float very good..this is good training for those trying to learn to swim".
The bipes i have flown have not needed rudder input to achieve a good turn and if they had, i would have landed and looked for a cause.
Can CG be adjusted to combat this? or is there any other way to eliminate the need for rudder input during a turn??[/QUOTE]
Anyone have a reason for this????? Is this a misunderstanding??? I would like to buy this as my first Biplane but i dont want to have to add mixing to get it to turn. Thats just silly.
toolman18 is offline Find More Posts by toolman18
Old May 05, 2012, 11:12 PM
cwojcik is offline
Find More Posts by cwojcik
Extremely Twisted
cwojcik's Avatar
United States, NH, Epping
Joined Oct 2005
Most EPP planes keep the nose high in turns...someone who was learning with, I think, a Twisted Hobbys Edge programmed a mix for rudder to aileron and said it helped him greatly to get used to it.
If you are comfortable using the rudder in any capacity you will have no issues with this airplane.
cwojcik is offline Find More Posts by cwojcik
Old May 05, 2012, 11:34 PM
asosestrom is offline
Find More Posts by asosestrom
United States, CA, Santa Rosa
Joined Mar 2011
I put the fuse together tonight and installed the rudder and elevator servos and the trusses.
Goes together very nicely and squares right up.
The only suggestion I would offer is to install both sevos and rout the wires before glueing the trusses. The manual suggests routing the wire through the first hole in the truss and this build suggests that you trim the front of the truss for the wires to exit. Either way it will be much easier to sort out the servo wires before gluing the truss.
I like the look of the truss tapering into the fuse so I put my wires through the hole.
asosestrom is offline Find More Posts by asosestrom
Old May 06, 2012, 12:59 AM
cdee is offline
Find More Posts by cdee
Team Twisted!
cdee's Avatar
United States, CO, Denver
Joined Jun 2011
The "Pitts" Build....
goes well... if you have built any of the other Crack Series planes you will notice that Twisted Hobbys is continually improving and really getting dialed in on the fine details to make things go together as easily as possible.
As an option to the above post, you can also leave the last 2 inches or so free of glue until the very end, makes for a very nice and clean radio install.
cdee
cdee is offline Find More Posts by cdee
Old May 06, 2012, 03:59 AM
Aviefly is offline
Find More Posts by Aviefly
Aviefly's Avatar
United Kingdom, Aviemore
Joined Feb 2005
+1 on cdee's method, or even a combination of this and Cody's method, i.e. cut 2 inches off the tip and glue it back in place once your ready and have routed your cables and done a rough balance. This way you can adjust the position of your rx and esc to aid your balancing and getting the pack to sit in a suitable place. On the rest of the Crack series it was the Aileron servo we had to watch out for, on this I can imagine it's the extra wood bracing in the vert fuse.
PS had me all confused for a moment there cdee till I realised your pics had the Pitts, the Slick and the Yak
Aviefly is offline Find More Posts by Aviefly
Old May 06, 2012, 06:53 AM
cwojcik is offline
Extremely Twisted
cwojcik's Avatar
Joined Oct 2005
Great ideas guys, that's a clean looking install on that Crack Yak.
One thing I found is that unless you are having issues getting max aileron throw (some radios won't drive the servos as far as others) there is no reason to use the outermost hole on the aileron arm. The inner holes give me all the throw I could want. So unless you are missing out on some throw with your ATV's maxed, use the inner holes and you'll get better resolution and power from your aileron servo.
Old May 06, 2012, 08:12 AM
Gravitycheat is offline
Find More Posts by Gravitycheat
Don't give in to gravity
Gravitycheat's Avatar
USA, FL, Palm Harbor
Joined Dec 2009
Guess i'll wait and see then what everyone thinks of it's flying characteristics. ANyone shoot any video yet??
Gravitycheat is offline Find More Posts by Gravitycheat
Old May 06, 2012, 08:47 AM
Twisted Realm is online now
Find More Posts by Twisted Realm
Twisted Realm's Avatar
United States, FL
Joined Aug 2008
GC, This one is much different than our last bipe which needed mixing for ke control. We took our time tweaking the Pitts and removed many bad flight characteristics associated with biplanes. No mixing on mine, do not feel its needed. Biggest noticeable tweaking for KE control would be the amount of expo on the rudder, yup thats about it. Its easily becoming my favorite TW model I'm flying to date you'd be surprised to say the least. Have a stronge feeling others will enjoy just the same.
Twisted Realm is online now Find More Posts by Twisted Realm
Site Sponsor
Cool Twisted Hobbys - 32" Crack Yak - Build Thread (Lots of new pics!) hercdriver7777 3D Foamies 6697 Jul 17, 2016 11:17 AM
Discussion Official-Twisted Hobbys Extra Slick 32" Slickinsaneness Build/Fly Thread Tom K. 3D Foamies 1377 Apr 06, 2016 06:24 AM
Build Log Twisted Hobbys - Telink 3D Buster EPP Bipe Build Thread, Flight Video just posted!!!! aerofundan 3D Foamies 578 Apr 21, 2015 04:01 AM
Wanted Twisted Hobbys - 32" Crack Yak Wanted Moparbob Aircraft - Electric - Airplanes (FS/W) 32 Jul 10, 2012 06:36 PM
Sold Twisted Hobbies Crack Yak isenbed Aircraft - Electric - Airplanes (FS/W) 4 Apr 16, 2012 10:43 PM
